Official Rythmik Audio Subwoofer thread - Page 772 - AVS Forum | Home Theater Discussions And Reviews
 4556Likes
post #23131 of 30527 Old 03-17-2016, 11:08 AM
PlasmaPZ80U's Avatar
Quoted: 2236 Post(s)
Liked: 685
Originally Posted by Carrick View Post
Everyone I have decided on the low priced FVX15 but need to know other people's actual experiences in the 12Hz realm. Other forums have said the FVX15 12Hz output is so little that it should not be considered (unlike it's bigger brother Fv15hp ) and I should only compare it against other brands in the 16Hz range. The only reason I want the FVX15 is to get 12Hz on the cheap. So that being said are there any experts here in AVS that have auditioned the FVX15 to assure me that it's worth getting or will I be disappointed.
Total volume for open living and dining rooms is 18x30x8 = 4320, but I can only afford one sub for now and if I need a second one I'll have to wait until almost Christmas.
Do slight differences in FR between 2 highly similar 15 inch ported Rythmik subs really matter? Even the LVX12 has a lot in common with those 2.
I would imagine the main appeal of the FV15HP would be more max output and the premium amp controls vs. the more basic compact amp controls on the FVX15.
Honestly, you have to ask yourself whether the significantly higher cost of the FV15HP including shipping is justified by any small differences in FR, which are likely far less significant than the effect of room acoustics and sub eq on FR.
(Of course, there can be other reasons to opt for the FV15HP than FR.)
PlasmaPZ80U is online now
post #23132 of 30527 Old 03-17-2016, 11:23 AM
Liked: 685
Actually, the FR is the same...
3dB more max output at 20Hz
200W RMS more power (and class H vs. class D on FVX15)
Different driver
More amp controls
(are the difference I can see based on the specs)
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
post #23133 of 30527 Old 03-17-2016, 11:28 AM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
Issue for me is bang for buck in that there are several other brands that do much better at 16Hz for under $1000. So the 12Hz extension parameter is paramount in my decision to get it.
Carrick is offline
post #23134 of 30527 Old 03-17-2016, 11:50 AM
enricoclaudio's Avatar
Quoted: 1451 Post(s)
Liked: 1562
Did you watch the FVX15 Youtube review? Check on minute 10:50 when the reviewer plays Edge Of Tomorrow intro and look at the driver. Not too many subwoofers are capable to do what the FVX15 and the FV15HP do at that frequency.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #23135 of 30527 Old 03-17-2016, 11:52 AM
Liked: 685
By much better do you mean max output? Because Rythmiks really shine with SQ more than just max SPL or extension. That's largely due to the direct servo technology that only Rythmik has.
post #23136 of 30527 Old 03-17-2016, 11:53 AM
JT78681's Avatar
Quoted: 1466 Post(s)
Liked: 976
In that size room I don't think 12hz will be perceivable. I would opt for one of the other brands if you are only after the most output for your dollar. With that said, there are other great features that separates Rythmik from the rest of the pack.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #23137 of 30527 Old 03-17-2016, 12:10 PM
Liked: 685
I agree that Rythmik brings more to the table than just max output and extension. SQ, damping, and various extension and LPF slope controls to name a few.
post #23138 of 30527 Old 03-17-2016, 12:17 PM
benhacker22's Avatar
Quoted: 13 Post(s)
I don't know where you found that information, aside from DIY, on data-bass the only thing that is close to the FVX15 at 16Hz (assuming -3dB from FV15HP and $1K cost) is the RA-PV15X or the HSU and there would be at best +/- 1dB which is a very small difference. If you are looking at getting another in the future, with the FVX15 you would increase the output below 16Hz whereas the others would be limited to their port tune.
All these are good subs and you can't go wrong with any of them. Pick the one that best matches your room, with the warranty you like and give it a go. I really like my FVX15 and am coming from a MFW-15 (not turbo) and think it was a great upgrade. Please post your thoughts on the sub you end up getting.
Receiver - Yamaha
Sub - Rythmik FVX-15
benhacker22 is online now
post #23139 of 30527 Old 03-17-2016, 12:36 PM
JimWilson's Avatar
Quoted: 1503 Post(s)
Liked: 1991
That's an oxymoron I'm afraid, like "government intelligence" or "jumbo shrimp". 12Hz on the cheap would be d@mn near impossible even in the DIY realm, so if that type of depth is your main goal then you might want to explore building something yourself. Even then I suspect you would struggle mightily to achieve 12Hz with any reasonable degree of output in a room that size, but realistically it sounds like it might be the only shot at satisfying your requirement.
Billy p likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #23140 of 30527 Old 03-17-2016, 12:49 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
Originally Posted by JimWilson View Post
That's an oxymoron I'm afraid...
Jim I know you are an expert here, have you tested the FVX15? From what has been extrapolated from the Data Bass FV15hp measurements, is getting a FVX for 12Hz extension worth it?
Carrick is offline
post #23141 of 30527 Old 03-17-2016, 12:50 PM
Liked: 685
When I got my LV12R in October of last year, I also looked at offerings from SVS, HSU, RBH, Outlaw, etc. However, for me the Rythmik was the perfect choice and zero regrets to this day with the sub and customer service.
post #23142 of 30527 Old 03-17-2016, 01:29 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
https://www.youtube.com/watch?v=Oallm7RiMPI
Watching this guy's cam made me want to hurl so I could not watch it. I checked it out at 10:50 and it looks impressive. I called your 512 phone number to ask about shipping, why is it free on the FVX and not the FV15hp? Is the FVX on promotion?
OK here I see it after I read it a second time. It's not a review but a good indicator from an expert.
Does this mean you auditioned all of them or you just looked at the published numbers and stats like I have been doing for the last 6 weeks?
Carrick is offline
post #23143 of 30527 Old 03-17-2016, 01:32 PM
Liked: 1562
One thing is if a subwoofer is capable to reproduce 12Hz and another is if the subwoofer has enough output at 12Hz to fill a 4500 cu ft room. Is the FVX15 capable to reproduce 12Hz? Yes. Does the FVX15 have enough output at 12Hz to fill a 4500 cu ft room? No. I'm afraid that you won't be able to archive that with less than $3000 in subwoofers. Not even a single FV15HP has enough output at 12Hz to fill a 4500 cu ft room. You will need at least 3 x FVX15s to get decent output at 12Hz.
Billy p and dominguez1 like this.
post #23144 of 30527 Old 03-17-2016, 01:35 PM
Matt2026's Avatar
Quoted: 409 Post(s)
Liked: 16061
I've been reading this thread recently and it has me considering the F12. The servo technology really appeals to me, elegance vs brute force. Had a Velodyne S-1200-B until it died of old age. I have a small room so the size should be way more than enough sound for my needs
I'll probably bounce back and forth between the F12 and the SVS PC-2000 for a while but I find myself more drawn to the F12 each time I visit the website
My next acquisition will be the SVS Ultra bookshelves to go with my Ultra center and I suspect the F12 would match up nicely with ~70Hz crossover... Not an expert opinion just gut feel of an old engineer
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; R&LRS/L/R SVS Ultra BS,
Ultra Center; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-2, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #23145 of 30527 Old 03-17-2016, 01:37 PM
Liked: 1562
We offer free shipping on all entry level subwoofers, like the FVX15, LVX12, LV12R, L12 and L22. Both, the FVX15 and the FV15HP are on sale right now. The FVX15 regular price is $999 and it's on sale for $909. The FV15HP regular price is $1339 + shipping and the sale price is $1200 + shipping.
post #23146 of 30527 Old 03-17-2016, 02:17 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
One thing is if a subwoofer is capable to reproduce 12Hz and another is if the subwoofer has enough output at 12Hz to fill a 4500 cu ft room. Is the FVX15 capable to reproduce 12Hz? Yes. Does the FVX15 have enough output at 12Hz to fill a 4500 cu ft room? No. I'm afraid that you won't be able to achieve that with less than $3000 in subwoofers. Not even a single FV15HP has enough output at 12Hz to fill a 4500 cu ft room. You will need at least 3 x FVX15s to get decent output at 12Hz.
Thanks Enrico, now I have finally achieved clarity.
So for roughly the same money I can buy either (3) FVX15 or (2) FV15hp, would either choice theoretically achieve 12 Hz in 4500 cuft ?
Carrick is offline
post #23147 of 30527 Old 03-17-2016, 03:14 PM
Liked: 685
I just researched them online, reading professional reviews, customer reviews, and starting some threads here on AVS.
Ultimately, the direct servo and 19Hz extension of the LV12R appealed to me, plus having way more output than I will ever use (meaning I won't need to push it like with some smaller subs, especially sealed ones) with movies that have ample, loud low bass.
After getting it, I was not only fully satisfied with those attributes, but also, the damping control and LPF slope control, which lets me adjust the SQ of this sub to my tastes and the latter because it can allow more seamless integration with my speakers.
More than anything else, the SQ of these subs are like nothing else comparable and that's why Rythmik subs pair up nicely with just about any speakers on the market.
I'm sure the other brands of sub are also great, but having experienced the Rythmik vs. other similarly priced subs at some local electronic stores, I strongly feel my Rythmik is better.
post #23148 of 30527 Old 03-17-2016, 03:23 PM
Liked: 685
I have the prime bookshelves and center and my LV12R is blending great with them. In fact, I found setting the LPF on the sub to 80Hz and 24dB per octave and then applying sub EQ via REW and the MiniDSP produced excellent results with a 90Hz crossover in the AVR for all speakers. I was able to turn up the sw trim quite a bit this way and with absolutely clean bass. When the LPF was set to max (120Hz), I had to turn the sub down otherwise things sounded bloated. And when the LPF slope was at 12dB per octave, there was a constant annoying boominess in the crossover region that just wouldn't go away with movies like Furious 7.
So, proper integration is key. Otherwise, there is too much overlap between the sub and the very bass capable SVS speakers.
However, once you get it right, it's unbelievably good.
post #23149 of 30527 Old 03-17-2016, 03:30 PM
Liked: 685
I should add though that if you're looking at a PC-2000 (ported cylinder), the corresponding Rythmik would be the LVX12 (ported box).
The F12 while a premium model is sealed and a lot smaller, which means max output at 20Hz and under will be significantly lower and it will have a different kind of sound down low vs. ported designs.
You might actually prefer that but then you should compare it to the SVS SB-2000 (sealed box).
post #23150 of 30527 Old 03-17-2016, 03:49 PM
Quoted: 145 Post(s)
I know the FVX12 and LVX15 will offer far more output and deeper extension. However I feel the LV12R would offer enough extension at 19 and output for my room size. Would the aforementioned subs offer a cleaner, more articulate sound in comparison to the LV12R? For me quality of sound is more important that output or extension.
Sony XBR70 850
Pioneer SC-81
Martin Logan Motion 40's
Martin Logan Motion 8
Rythmik LVX12
primetime74 is offline
post #23151 of 30527 Old 03-17-2016, 04:23 PM
JimWilson's Avatar
Liked: 1991
Enrico beat me to it. His was the exact point I was making, but he conveyed it more eloquently than I did. You need a lot of subwoofer (or more precisely, subwoofers) to reproduce low teens with sufficient output for it to be worthwhile.
post #23152 of 30527 Old 03-17-2016, 04:26 PM
JimWilson's Avatar
Liked: 1991
Brian's stock in trade is SQ - he's actually a music fanatic, so a lot of his perspective is with that level of detail in mind. I very seriously doubt anything he sells would forgo that ethos.
PlasmaPZ80U and primetime74 like this.
post #23153 of 30527 Old 03-17-2016, 04:57 PM
grigorianvlad's Avatar
Quoted: 164 Post(s)
Liked: 623
that was very entertaining. Thanks, Enrico.
DAC: Wyred4Sound DAC1LE || Processor: Marantz AV8801 11.2 Ch || Power Amps: Audio Research VS110 (100W tube) || Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: PS Audio Premier || HP: HifiMan HE560
grigorianvlad is offline
post #23154 of 30527 Old 03-17-2016, 05:34 PM
dominguez1's Avatar
Quoted: 1109 Post(s)
Liked: 962
^^^This.
BUT, you're thinking the right way. Rythmik is the most affordable way to get decent output at 12hz compared to all other subwoofers including DIY.
dominguez1 is offline
post #23155 of 30527 Old 03-17-2016, 05:45 PM
Quoted: 145 Post(s)
Thanks Jim. Between your stellar review and this answer you pretty much sold me on the Rythmik LV12R. I really like the Rythmik servo technology, as well as the great reviews on their subs. I was considering some of their larger subs along with other brands. However I feel I could save money and get all the performance that I need in the LV12R which was always very high on my list. I just kind of got caught up on so many talking about deep extension and extra output. I doubt I'd come anywhere near pushing the LV12R to it's limits.
Now I just need to save up after unexpected expenses and slow work.
Matt2026 likes this.
Sony XBR70 850
Pioneer SC-81
Rythmik LVX12
post #23156 of 30527 Old 03-17-2016, 06:33 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 65
Originally Posted by dominguez1 View Post
... you're thinking the right way. Rythmik is the most affordable way to get decent output at 12hz compared to all other subwoofers including DIY.
So I have a new idea, what if i sat 2m from the FVX15 and had it facing my seat, would I be able to experience the 12Hz?
Carrick is offline
post #23157 of 30527 Old 03-17-2016, 06:56 PM
steveting99's Avatar
Quoted: 1840 Post(s)
Liked: 639
Might be interested in the thread started by Ross: MINT Rythmik F12 Black Oak subwoofer
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #23158 of 30527 Old 03-17-2016, 07:43 PM
Matt2026's Avatar
Quoted: 409 Post(s)
Liked: 16061
Thanks for the input Plasma,
Well, I'm hoping my 4520CI with Audyssey XT32 will take care of most of that If not, then I'll consider my next step...
post #23159 of 30527 Old 03-17-2016, 09:24 PM
DonH50's Avatar
Quoted: 2121 Post(s)
Liked: 1693
If SQ is your goal then Rythmik does a great job. I like the F12 a lot. Four times as much as most folk. I find it comparable to subs in the $3k to $5k range (my original target) albeit with less output (not needed in my small room).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #23160 of 30527 Old 03-17-2016, 11:57 PM
Matt2026's Avatar
Quoted: 409 Post(s)
Liked: 16061
Thanks for your input Don,
Looking at the frequency response on the website the F12 is only down 3db at 14Hz, my present sub is rated 29-120Hz frequency response (±3dB), 200WRMS. I don't listen to super loud stuff so I'm not worried about extreme levels of bass. My room is only 1100cuft with a door to the hallway, not hermetically sealed but pretty much the sub only has to pressurize the room.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
