Official Rythmik Audio Subwoofer thread - Page 787 - AVS Forum | Home Theater Discussions And Reviews
 3990Likes
post #23581 of 29392 Old 05-05-2016, 09:38 AM
PlasmaPZ80U's Avatar
Quoted: 2039 Post(s)
Liked: 587
Originally Posted by jedi1982 View Post
For the FV15HP, if sitting behind an acoustic transparent screen on carpet, are the rubber feet recommended or the spikes? Thx
placing it flat on carpet with no feet/spikes is also a perfectly valid option and I believe this is what Brian recommends usually... I don't know if behind a AT screen changes things though
Current Setup REW measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #23582 of 29392 Old 05-05-2016, 09:44 AM
JT78681's Avatar
Quoted: 1436 Post(s)
Liked: 958
My subs don't have feet, but that might change now with a little one about to be upright any day now.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #23583 of 29392 Old 05-05-2016, 10:28 AM
FLCanuck's Avatar
Quoted: 24 Post(s)
Originally Posted by Bluecow003 View Post
Bluecow
...jealous of your room and set-up! Very nice indeed!!
Slightly off topic, but how do you have the grey panels attached to the doors - looks like some sort of over-the-door bracket/hanger - mind sharing the details?
FLCanuck is offline
post #23584 of 29392 Old 05-05-2016, 10:40 AM
jedi1982's Avatar
Quoted: 69 Post(s)
Liked: 33
Place directly on the carpet you say? Interesting. Knowing this is in the basement in a dedicated home theater room, the vibrations won't go through the floor this way?
jedi1982 is offline
post #23585 of 29392 Old 05-05-2016, 10:43 AM
JT78681's Avatar
Liked: 958
Feet wont stop the vibrations from penetrating walls. Hell you could suspend the sub(s) in mid-air and that wouldn't help either.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #23586 of 29392 Old 05-05-2016, 11:30 AM
DonH50's Avatar
Quoted: 1945 Post(s)
Liked: 1499
Thx! Did that a few years back
Given your username, shouldn't Bond be holding a lightsaber? Jez' sayin'...
Flat on carpet is fine. If you use feet use spikes. Is the basement floor concrete under the carpet? If so, I would use none and forget about it.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #23587 of 29392 Old 05-05-2016, 12:16 PM
Liked: 587
Or perhaps Jedi Bond instead of James Bond, lol
post #23588 of 29392 Old 05-05-2016, 12:47 PM
jedi1982's Avatar
Quoted: 69 Post(s)
Liked: 33
Ooooh I like where this is going lol
Yes it is concrete under the carpet so am thinking will likely fuhgitaboutit.
However, if I do build a riser/stage under the screen area, then I'd be back to looking at using the rubber feet again correct? As well as looking into sand filling in the area between the stage boards
jedi1982 is offline
post #23589 of 29392 Old 05-05-2016, 01:14 PM
DonH50's Avatar
Liked: 1499
Putting a sub (or any speaker) on a riser can be problematic as the riser needs to be very stiff, well-dampened, or both to prevent it from becoming a "boom box" for the sub. Filling with sand can certainly help.If there is no carpet so the surface is smooth and "slick" then yes rubber feet unless you don't mind marring the finish with spikes. Or just lay down a rubber-backed carpet pad under the subs.
IMO - Don
DonH50 is offline
post #23590 of 29392 Old 05-05-2016, 02:56 PM
Liked: 0
Thumbs up
Originally Posted by Friday_Pattycake View Post
Rythmik has the chart updated on their website:
At 20 Hz, our subs vary in their maximum output capability. The output at 20 Hz is shown relative to F12.
F12: 0db (baseline)
F8/FM8: -1.5db
L12: -1db
LV12R: +2.5db
L22: + 4db
LVX12: +4db
E15HP: + 4db
F15HP: +4.5db
FVX15: +6.5db
FV15HP: +9.5db
F25: +8db
Cool , thanks for that! I was hoping for all the rest of the specs in the one chart as well (weight, dimensions, etc) but that helps
I've started my own spreadsheet, have to change dimensions and weight to metric for my brain anyway
Cheers
Paul
Aqueous76 is offline
post #23591 of 29392 Old 05-05-2016, 05:04 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
If the sub enclosure rocks a little when you push on it (due to the give of the carpet and/or padding underneath it), you may want to try the spikes. The movement of the woofer cone during extreme excursions can actually be enough to cause the enclosure to move in reaction to that force, potentially resulting in a loss of definition.
If you want to try something happening at the forefront of component isolation (yes, of even speakers and subs), look up Symposium Acoustics. They make a version of what are called roller bearings (naming them Roller Blocks), designed and claimed to keep seismic-level vibrations from entering components from terra firma, vibrations which can result in a blurring of detail and decrease in low-level resolution, the way a camera shutter can cause blurring in a photograph. The audibility of that blurring is determined by the transparency of your system, of course. Having a cement floor in your listening room is no guarantee of imperviousness to these very low frequency seismic vibrations, 3Hz and lower. The concept is now employed in the foundations of tall buildings in cities subject to earthquakes; when the ground moves, the building (or your Hi-Fi components!), rather than absorbing the waves of energy (vibrations, shaking) simply slides over them, riding across the top of the waves rather than being thrown to and fro by them. For more on the theory, read the writings of audiophile recording engineer Barry Diament on his website. Barry isolates his entire recording and monitoring chain (even his 6' tall Magneplanar MG 3.7 speakers!) with roller bearings.
BDP24 is offline
post #23592 of 29392 Old 05-05-2016, 06:32 PM
jedi1982's Avatar
Quoted: 69 Post(s)
Liked: 33
Cool thx all for the responses!
jedi1982 is offline
post #23593 of 29392 Old 05-06-2016, 07:11 AM
chriscmore's Avatar
Quoted: 137 Post(s)
Liked: 148
If your carpet is over concrete, I don't recommend spikes. The metal to concrete contact can cause buzzing.
Cheers,
Chris
Seymour AV
515-268-3369
Seymour-Screen Excellence
515-450-5694
chriscmore is offline
post #23594 of 29392 Old 05-06-2016, 11:23 AM
Bluecow003's Avatar
Quoted: 160 Post(s)
Liked: 107
Originally Posted by FLCanuck View Post
Bluecow
I used door hooks that I took from some hat racks I had (link below), then just used some framing wire. I thought about using some really strong 3M adhesive tape, but it would have taken a lot of tape and would have been permanent. Once I found the right door hooks, this solution worked great.
http://www.containerstore.com/s/hook...uctId=10031744
7.2.4 Setup | Display: Panasonic TC-P65VT50 plasma | Blu-ray: Oppo UDP-203 | Processor: Anthem AVM60 | Amps: Outlaw 7700, Emotiva XPA-5 Gen 2 | Speakers: Paradigm Prestige (2) 95F's, 55C, (4) 15B's, (4) CI-Elite E65-R (Atmos) | Subs: (2) Rythmik F25's
Bluecow003 is offline
post #23595 of 29392 Old 05-06-2016, 12:29 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Cheers,
Chris
That's true if you use four spikes, and the spikes aren't perfectly adjusted. That's why three are better than four! With three that problem cannot happen---three spikes (or cones) create a triangle of course, so no misadjustment (one of the spikes being not in intimate contact with the surface) is possible. I would use two spikes at the front (or back, your choice) and one cone in the back (or front). Or, if you're going to try the Symposium Roller Blocks (which come as a set of three), two bearings in front, one in back (or, again, visa versa).
BDP24 is offline
post #23596 of 29392 Old 05-07-2016, 08:36 AM
chriscmore's Avatar
Quoted: 137 Post(s)
Liked: 148
I've had three-spike speakers buzz like crazy on a carpeted concrete floor. There's no real advantage to spikes, so I recommend avoiding it. If it works for you, great, but it will be in spite of them, not because of.
Cheers
Chris
post #23597 of 29392 Old 05-07-2016, 12:04 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Cheers
Chris
What was buzzing? If the three spike tips stay in contact with the cement (assuming they poke all the way through the carpet and padding, as they should supporting the weight of a Rythmik sub---you must push down on the sub, to get the spike tip in direct contact with the cement in order to get mechanical grounding), and a locknut is tightened on each, right up against the bottom of the enclosure, what's to buzz? I've been using them for over thirty years without a single incident of buzzing. I consider them essential for a high resolution system installed on carpet, if you're going for mechanic grounding rather than isolation, via roller bearings or air bearings. It's doable with four, just harder to get all four spikes in perfect adjustment, thus making rocking impossible. Definitely audible---that's why people use them, and why Brian installs them on his subs!
BDP24 is offline
post #23598 of 29392 Old 05-07-2016, 12:32 PM
12B4A's Avatar
Quoted: 331 Post(s)
Liked: 202
Spikes work well to fix a subwoofer in place on carpet. Although, if the goal is high resolution/accuracy, I'm not sure why anyone would use them vs. isolation (plain rubber feet etc.) since you are mechanically coupling to the floor and turning the floor in to a passive radiator.
Life is Lambertian
12B4A is online now
post #23599 of 29392 Old 05-07-2016, 01:02 PM
jedi1982's Avatar
Quoted: 69 Post(s)
Liked: 33
I am still designing but will likely have no carpet on the stage behind the screen and will have the subs directly on the surface of the stage. Because of this, will probably use the rubber feet again
jedi1982 is offline
post #23600 of 29392 Old 05-07-2016, 03:34 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
I do prefer isolation (via roller bearings), whether on a wood/tile floor or carpet. But on carpet, rubber feet can allow a fair amount of rocking motion of the enclosure, the one thing you don't want. If I wasn't going to go for isolation and I had carpet, I would try spikes or cones. If the floor is not wood, how do spikes turn a slab of cement into a passive radiator? Cement is superior to wood for that very reason---it's relative non-resonance, and preferable for that and other reasons. We on the West Coast envy you in the Midwest and on the East Coast with your basements. Plus, you don't have our earthquakes!
BDP24 is offline
post #23601 of 29392 Old 05-11-2016, 06:56 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 264 Post(s)
Liked: 362
FV18 proto type.
Here is a photo. The driver is also a proto-type as you may notice the cone is not brushed. The production 15" is brushed.
The elbows and ports work very well. The tuning frequency I confirm is now about 5% lower than FV15HP. I can shave one inch in either height or depth to raise the tuning frequency by 5%. The size is currently 21"Wx23"Dx33"H. Let me know which dimension is more important.
Rythmik is offline
post #23602 of 29392 Old 05-11-2016, 07:06 AM
tvuong's Avatar
Quoted: 1662 Post(s)
Liked: 988
^^ how big are the ports? Is the 23" D include the amp in the back? Can it be laid on its side without causing amp heat? Most people don't have problem with height, it's the depth that could be a problem especially for folk planning to place sub behind an AT screen.
PlasmaPZ80U, newc33 and MrGrey like this.
tvuong is online now
post #23603 of 29392 Old 05-11-2016, 07:08 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 264 Post(s)
Liked: 362
The ports are 3-1/2", same as FV15HP. But it is two-port tuned to 12hz. We will not offer 1 port mode operation on this model.
It does not include amp depth. It can be laid side way as we will have criss cut on the heat sink.
Rythmik is offline
post #23604 of 29392 Old 05-11-2016, 07:15 AM
tvuong's Avatar
Liked: 988
^^ thanks. So it's probably 24"D with amp?
post #23605 of 29392 Old 05-11-2016, 07:29 AM
Bond 007's Avatar
Quoted: 2549 Post(s)
Liked: 2008
Originally Posted by Rythmik View Post
FV18 proto type.
Depth. Smaller footprint
PlasmaPZ80U and MrGrey like this.
Bond 007 is online now
post #23606 of 29392 Old 05-11-2016, 07:34 AM
enricoclaudio's Avatar
Quoted: 1224 Post(s)
Liked: 1295
BTW, I like the non brushed aluminum cone better
Nemesis.ie likes this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #23607 of 29392 Old 05-11-2016, 07:44 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 264 Post(s)
Liked: 362
That seems to be the consensus. That will be handy for FV25 because the tuning of that model is about 10% too low.
Rythmik is offline
post #23608 of 29392 Old 05-11-2016, 08:02 AM
eyecatcher127's Avatar
Quoted: 41 Post(s)
I think 3.5" ports might be a bit small and create a lot of chuffing. How about a slotted port? To increase the port area and reduce the velocity plus they add bracing. I think this would work very nice since only one tuning frequency. Or I would like to design a 22" cube that had dual 4" down firing ports that also offers boundary loading with large isolation feet. Something similar to the old av123 mfw-15 or epik pheonix with svsound isolation. Will you be offering DIY kit?
eyecatcher127 is offline
post #23609 of 29392 Old 05-11-2016, 08:21 AM
dominguez1's Avatar
Quoted: 1054 Post(s)
Liked: 834
FV18 proto type.
Looking good!
Why not just keep it with a 5% lower tune? An inch either way wouldn't be a show stopper I would think...but if I had to choose, definitely depth.
What does a 5% lower tune equate to?
dominguez1 is online now
post #23610 of 29392 Old 05-11-2016, 08:55 AM
Liked: 1295
Originally Posted by dominguez1 View Post
Looking good!
Around 11.4Hz tuning freq. We want to keep it at 12Hz like the FV15HP.
eyecatcher127 likes this.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
