Official Rythmik Audio Subwoofer thread - Page 790 - AVS Forum | Home Theater Discussions And Reviews
 3743Likes
post #23671 of 28972 Old 05-25-2016, 03:10 AM
dlynch34's Avatar
Quoted: 297 Post(s)
Liked: 122
Originally Posted by DonH50 View Post
I leave my subs on and use an X10 system to turn them off. You could also use a SmartStrip or similar, or professional (e.g. Furman) trigger-controlled output.
Nice Maggies, though the new-fangled base still shocks me when I see it. I am jealous of your DWM.
It seems the amp is clipping...I have never had a sub clip before..
Sent from my SAMSUNG-SM-G935A using Tapatalk
Don
Anthem AVM-60,Sunfire Cinema Grand Signature Five-Channel Power Amplifier, Emotiva XPA-1l x2,Outlaw 5000. Rhythmik DIY 15inch x2, Plus, Magnapan 3.7i, Magnepan CC5,Magnepan MC1,JVC RS400, DIY 125" 2:35 Elite Screen cinegray 3d .
dlynch34 is online now
post #23672 of 28972 Old 05-25-2016, 04:23 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by dlynch34 View Post
My diy subs..
Are you considering getting the Mye stands for your 3.7i's? They're not cheap, but it's a great design, and everyone who has gotten them has found them to improve the sound of their Maggies, especially the bass. I looked into getting them for my Tympani's, but that model is actually two separate stands, one for the two bass panels and a second for the midrange/tweeter one, at twice the price of the models for single-panel Maggies such as the 3.7i. I'm thinking of making some myself out of wood. The stock Maggie feet hold up the panels, but don't provide them much stability.
BDP24 is offline
post #23673 of 28972 Old 05-25-2016, 04:24 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Is your amp the H600 (with DS1510 driver), or the A370 (with the DS1501)?
BDP24 is offline
post #23674 of 28972 Old 05-25-2016, 04:42 AM
dlynch34's Avatar
Quoted: 297 Post(s)
Liked: 122
It is actually the hx800xlr with dual ds1501 drivers.
Don
post #23675 of 28972 Old 05-25-2016, 04:50 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Ah, so you run the two subs mono, each woofer off one half the HX800? That amp is actually intended to power two drivers in a single enclosure, with connecting cables of no longer than a "certain" length. I'm not sure what that length is, but if they are too long that could be what's causing your problem. Check with Brian when he gets back, or maybe Enrico has the answer.
BDP24 is offline
post #23676 of 28972 Old 05-25-2016, 05:02 AM
dlynch34's Avatar
Quoted: 297 Post(s)
Liked: 122
Yea it has a 20 foot limit. I have the subs at most 10 feet apart ..
Don
post #23677 of 28972 Old 05-25-2016, 06:03 AM
ahmedreda's Avatar
Quoted: 316 Post(s)
Liked: 252
If anyone is interested, I just listed my four FV15HPs for sale. Decided to go with a low profile DIY to completely hide behind the screen.
FS: 4x Rythmik FV15HP Black Oak w/600WRMS (latest model)
Madmax67 likes this.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #23678 of 28972 Old 05-26-2016, 11:25 AM
dlynch34's Avatar
Quoted: 297 Post(s)
Liked: 122
yea not sure why they went to this base... on carpet it is very unstable.... I dont want to change out bases as the other solutions seem way expensive. Not to mention I have put enough money into my system including these subs.... I am having to figure out this amp as I keep having them clip... never had this happen before with any subs I have owned prior.... going to take a look at the gain and see if that is the culprit...
Don
post #23679 of 28972 Old 05-26-2016, 11:46 AM
DonH50's Avatar
Quoted: 1926 Post(s)
Liked: 1457
You get get small spikes to attach to the bases at Wal-Mart, Home Depot, etc. Or the audiophile versions from various places.
Also check the AVR's levels, it may be overdriving the input of the sub. And make sure it is not overboosting the deep bass due to a room issue or something like that. And double check all the wires; a bad servo connection could do it. You could also just as a test put one amp on top of the other and shorten the servo (feedback) wire to make sure the wire is not too long or picking up noise causing instability in the sub amp. It could be a bad amp, but I suspect something else is going on.
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #23680 of 28972 Old 05-26-2016, 01:28 PM
Matt2026's Avatar
Quoted: 385 Post(s)
Liked: 14702
May be possible that the gain on the sub is too low and the AVR output is clipping, not the sub... just a thought.
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; R&LRS/L/R SVS Ultra BS,
Ultra Center; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-2, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #23681 of 28972 Old 05-26-2016, 07:48 PM
enricoclaudio's Avatar
Quoted: 1206 Post(s)
Liked: 1276
The L22 Unboxing pictures are posted on Facebook. I'm really impressed with the performance of this baby. It integrates wonderfully with my Dynaudio's BM5 mkIII Monitors. This is for sure one of our best choices for near field monitoring. The sound is crystal clear and accurate as the F12 but with the power of the F15HP. Even though it's 28" tall it fits perfectly under any standard desk as you can see on the pictures posted on FB. To control the volume of the subwoofer I got a JBL Nano Patch+ Volume Control which is right after the Apogee Duet Audio Interface output. This is definitely the right choice for those looking for a great sealed subwoofer, powerful as the F15HP, with very small footprint and only cost $849 with shipping included.
https://www.facebook.com/media/set/?...6239148&type=3
Matt2026 likes this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #23682 of 28972 Old 05-26-2016, 11:14 PM
Maccur's Avatar
Quoted: 22 Post(s)
Liked: 31
Came home from work to find this in my garage! Day off today to set up.
Maccur is offline
post #23683 of 28972 Old 05-27-2016, 02:03 PM
Darkjuju's Avatar
Liked: 0
I just got a similar package yesterday and a whole holiday weekend off to tune. All I could manage was getting it unboxed and in place of my old HSU with the default tweaks the guide its sent with. Sounds good but i need to break out the whole mic setup and measure for the gain.
Darkjuju is offline
post #23684 of 28972 Old 05-27-2016, 02:53 PM
Liked: 1276
I just finished to unbox the LVX12 as well. It's ready and running on the bedroom setup. This thing is just crazy good. Accurate as any of our sealed subwoofers but a monster in terms of output. Now I have a pair of F12SEs in my media room, an L22 on my desktop near field setup and a LVX12 in my bedroom setup. All of them available for demo to any local customer (Houstonians). BTW, my apt is 710 sq. ft.
torii and Madmax67 like this.
post #23685 of 28972 Old 05-27-2016, 03:21 PM
JimWilson's Avatar
Quoted: 1400 Post(s)
Liked: 1835
I'm sure the neighbors are just gonna love you; "hey everybody, I have tons of subwoofers and I want you all to demo them!"
JT78681, primetime74 and Madmax67 like this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #23686 of 28972 Old 05-27-2016, 03:35 PM
Liked: 1276
I'm a very good neighbor and that's why I got a pair of these, one for the L22 and one for the LVX12
After 9 pm I press the mute button down and no subwoofers in my house
BTW, I haven't got a complaint in the last 5 years so either I'm a good neighbor or my neighbors are deaf
post #23687 of 28972 Old 05-27-2016, 06:09 PM
DonH50's Avatar
Liked: 1457
What?
AlexanderDelarg and Madmax67 like this.
post #23688 of 28972 Old 05-27-2016, 07:59 PM
Maccur's Avatar
Quoted: 22 Post(s)
Liked: 31
A bit of a difference in size between the Rythmik E15HP and the Velodyne HGS 10 Series II it replaces. The Velo has been a great performer for 13 years. Quite a kick for such a small cube.
I needed a friend to help me load the Rythmik into its new home.
ID:	1464321   Click image for larger version
JT78681 and Matt2026 like this.
Maccur is offline
post #23689 of 28972 Old 05-27-2016, 08:27 PM
Liked: 1276
Here some pictures of the LVX12 Black Matte. On Monday I will post on Facebook all unboxing pictures!!! This thing is a beauty!!
ID:	1464369   Click image for larger version
ID:	1464377   Click image for larger version
ID:	1464385   Click image for larger version
post #23690 of 28972 Old 05-27-2016, 08:46 PM
Bond 007's Avatar
Quoted: 2526 Post(s)
Liked: 1995
You sure youre not just alone in the bldg?
Thanks for the updates.
Bond 007 is offline
post #23691 of 28972 Old 05-28-2016, 04:19 AM
sevenz's Avatar
Quoted: 71 Post(s)
Liked: 51
nice pics enrico, the matt version is gorgeous. Is Rythmik planning to have it for the other models too?
By the way, could u share what's the difference in strengths between the ported LVX12 VS the sealed E15HP? And also in terms of midbass and the distortion. Thanks. =)
sevenz is offline
post #23692 of 28972 Old 05-28-2016, 07:12 AM
PlasmaPZ80U's Avatar
Quoted: 2018 Post(s)
Liked: 582
If I'm not mistaken, matte black and black oak are standard options on all Rythmik subs.
PlasmaPZ80U is offline
post #23693 of 28972 Old 05-28-2016, 09:46 AM
Liked: 1276
Black Matte and Black Oak are standard finishes in all our models, except for the F25 that only comes in Black Oak.
The good thing about Direct Servo is that ported subwoofers have basically same accuracy as sealed subwoofers so it's very hard to tell a difference between ported vs sealed. In this case, for a normal listener would be very hard to find a difference between the LVX12 and the E15HP, mostly if you run the LVX12 in one port mode. I put the L22 and the LVX12 side by side and it was really a challenge even for me to find a difference with some material. The LVX12 has a little bit more punch on the mid bass region but like I said, really hard to hear that difference. Both subwoofers having Direct Servo technology, distortion is something to not be worry about. A more apples to apples comparison would be between the E15HP vs L22. Things that favor the E15HP over the L22: Connectivity (XLR2 and XLR3 options available), speaker level inputs, PEQ and Piano Black finish. For most people with AVRs with room correction systems like Audyssey, YPAO, ARC, etc, the L22 would be a more natural choice and also you can save some money
Blacklightning and Madmax67 like this.
post #23694 of 28972 Old 05-28-2016, 12:38 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
With all the Rythmik models and price points, no one has to settle for an Hsu or SVS anymore!
BDP24 is offline
post #23695 of 28972 Old 05-28-2016, 12:44 PM
HVAC Guru's Avatar
Quoted: 142 Post(s)
Liked: 110
Finally had a chance to go and pick mine up today, it's been a long few weeks knowing it was sitting waiting for me. I'm glad it's double boxed and packed with lots of foam, she took a beating during transport.
Good thing I have an appliance moving dolly, I don't know how I would have been able to get it in the house by myself. Someone asked if I bought a new washing machine, when I said it was a subwoofer they had this puzzled look on their face and asked "why?" Lol. I guess it's just a little bit larger then what most people associate a subwoofer with.
Now time to rattle some stuff
enricoclaudio and Matt2026 like this.
HVAC Guru is offline
post #23696 of 28972 Old 05-28-2016, 03:43 PM
12B4A's Avatar
Quoted: 328 Post(s)
Liked: 199
Because:
RTROSE, natetg57, MrGrey and 2 others like this.
Life is Lambertian
12B4A is online now
post #23697 of 28972 Old 05-28-2016, 04:00 PM
HVAC Guru's Avatar
Quoted: 142 Post(s)
Liked: 110
Ah, the Tacoma Narrows Bridge. Well played.
My sheet rock in the basement was doing an impression of it. I had to walk around and take some stuff off the walls, sorry decor, sub wins.
post #23698 of 28972 Old 05-28-2016, 04:31 PM
MrGrey's Avatar
Quoted: 599 Post(s)
Liked: 755
Originally Posted by 12B4A View Post
Because:
haha my landlord pretty gave me the same look and said something along the lines of ''how much rattle do you want?'' dude is so clueless man and he has a little bose sub.
HVAC Guru likes this.
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Sub - Rythmik FV15HP
The Ultimate List of BASS in Movies w/ Frequency Charts
MrGrey is offline
post #23699 of 28972 Old 05-28-2016, 04:32 PM
Liked: 1276
Talking about Black Matte finish. This picture tells you everything about this nice looking finish!!!
MrGrey and Madmax67 like this.
post #23700 of 28972 Old 05-28-2016, 04:35 PM
MrGrey's Avatar
Quoted: 599 Post(s)
Liked: 755
Mine is peeling on my FV15HP, what and eye sore and to make it worse i accidentally scuffed the back while moving it from the wall showing the bare wood... kill me please.
Center
MrGrey is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
