Official Rythmik Audio Subwoofer thread - Page 811 - AVS Forum | Home Theater Discussions And Reviews
 3407Likes
post #24301 of 28258 Old 07-11-2016, 07:42 PM
tegage's Avatar
Quoted: 44 Post(s)
Liked: 24
Originally Posted by Matt2026 View Post
This is what I use here in California https://smile.amazon.com/Quakehold-8...rds=Quake+Hold
Yes sir, I use that stuff in my Palm Springs home
Sent from my SM-P600 using Tapatalk
LG 65EF9500
Oppo BDP-103
Polk LSiM703, LSiM704C, LSiM 702, LSi 7
Rythmik D15SE sub
Outlaw 975
Outlaw 7125
tegage is offline
post #24302 of 28258 Old 07-11-2016, 10:28 PM
Quoted: 471 Post(s)
Liked: 181
Well, decided on the F12s. If I have to upgrade down the road and take a hit on these subs than so be it. I will enjoy the hell out of them until than. Money well spent, is money spent on a smile.
I ordered one today along with Sierra center and will order another one in 45 days to maintain the discount.
Thank you all for the advice and help.
Theriddler07sms is offline
post #24303 of 28258 Old 07-11-2016, 10:58 PM
Snowmanick's Avatar
Quoted: 267 Post(s)
Liked: 383
Originally Posted by citsur86 View Post
As an aside, today I added a couple additions which may or may not bring my HT to new heights. too bad I can't figure out how to get the speaker wire to them through that external wall with insulation in it. For the moment they're just hanging there until I can figure it out.
What I have done in the past when running cable in an external insulated wall is: A) use a stud sensor to determine if there are any fire breaks between the studs, B) Once reasonably sure the answer to A was no, cut a small hole in the drywall where the speakers are and another where you want the cables to go in the wall, C) Used a fiberglass cable fish rod fed from the top dry wall opening down to the lower opening, D) taped the speaker cable to the fish rod, which keeps it more secure and is less likely to pull the insulation, E) slowly pull the rod back out. Voila.
I have had to do this a couple times for surrounds, just be sure to use inwall rated speaker cable. I normally use a wall plate to make it look a little cleaner as well.
It is pretty cheap and easy.
~Nick
"Every loaf of bread is a tragic tale of grains that could've become beer.......but didn't...."
"If it works the first time, it's not high end." ~ Harry Pearson
Snowmanick is offline
post #24304 of 28258 Old 07-12-2016, 01:28 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by JimWilson View Post
Age hasn't changed me; I want it all, both quality and quantity! And yes, I'm over 50...
You youngins'. I'm over sixty (over sixty-five even), and I still need to crank AC/DC.
woster402 and bmcn like this.
BDP24 is offline
post #24305 of 28258 Old 07-12-2016, 03:40 AM
Bond 007's Avatar
Quoted: 2398 Post(s)
Liked: 1923
Congrats. Those Sierra are fine speakers too.
Bond 007 is offline
post #24306 of 28258 Old 07-12-2016, 03:48 AM
citsur86's Avatar
Quoted: 984 Post(s)
Liked: 308
Originally Posted by Blacklightning View Post
This means if you play a 60hz test tone at 80db, your sub will be able to play a 10hz tone at 77db. (in a perfect flat world) But you will find if you are just running one sub or you are not eq'ing your sub the peaks and nulls in your room may cause frequency swings as high/low as 30db.
Yes and no. REW will give you a nice graph to look at. You can also just use an SPL meter, play test tones and just write down the numbers.
let's say you have a sealed 12" sub. Play the sub outside in an open field and you will have less bass. Now place it in a room and you will find that the smaller the room the louder the low frequencies below 25hz will sound. In a perfect world you would measure your sub outside and then in a room and you will see your room gain.
Ok thanks! I'll have to measure my sub to see what I get.
So since I have my sub in a large open first floor layout, I'm likely to have much less room gain than if it were in a smaller sealed room. Also I have a ported sub not sealed. Does that make a difference in terms of room gain? I would assume ported subs typically have more room gain.
My Current "Living Room" Home Theater!
Plasma 50" TV: Samsung PN50C8000 — DLP Projector: Optoma GT1080
Projector Screen: Elite VMAX2 Electric — Receiver:Pioneer Elite VSX-44 — Fronts: B&W 684 S1
Center: B&W CM Center S2 — Surrounds: B&W 685 S1 — Subwoofer: Rythmik FV15HP
Rear Surrounds: Polk Audio T15 — Front Heights: Polk Audio T15
citsur86 is offline
post #24307 of 28258 Old 07-12-2016, 05:11 AM
PlasmaPZ80U's Avatar
Quoted: 1980 Post(s)
Liked: 568
Enjoy your new sub and CC.
PlasmaPZ80U is offline
post #24308 of 28258 Old 07-12-2016, 06:11 AM
JimWilson's Avatar
Quoted: 1323 Post(s)
Liked: 1689
I love the old stuff featuring the second lineup (the guys from the late 70's on). Now there's no Malcolm, Phil Rudd, Cliff Williams or Brian Johnson - it's just Angus. Maybe they should call themselves A?/?? instead...
enricoclaudio and BDP24 like this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #24309 of 28258 Old 07-12-2016, 06:21 AM
enricoclaudio's Avatar
Quoted: 1133 Post(s)
Liked: 1180
Great speakers, Congratulations!! That's my next upgrade in speakers: Sierra Towers with RAAL + Horizon Center with RAAL and Sierra 2s for surround
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #24310 of 28258 Old 07-12-2016, 08:08 AM
Blacklightning's Avatar
Quoted: 415 Post(s)
Liked: 284
The general rule is that Ported subs have lessroom gain then sealed subs but both subs will get the same room gain at 32hz.but the story changes below the port tuned frequency so at 15hz and lower, roomgain is not really a factor for most ported subs.
If you are chasing 10hz performance sealed is theway to go.
But all this means nothing until you get REW and amic. People are used to seeing graphs of speakers and they think they arehearing a nice straight line. You can have a sub rated at 16-200hz but in aroom it could change to 10-200hz or 45-200hz with a huge whole at 80hzand 120z.
Here is a graph of the bass of my full rangespeakers bass response. some would say I'm at 25-200hz +-5db in-room, myspeakers are rated at 42Hz-20KHz. but you can see that my response dips below-5db at 50hz, 80hz, and 170hz.
citsur86 likes this.
Blacklightning is offline
post #24311 of 28258 Old 07-12-2016, 08:13 AM
citsur86's Avatar
Quoted: 984 Post(s)
Liked: 308
I've done a lot of reading about how to use REW and I plan to get some equipment and take measurements sometimes before the summer is over because I really want to know what my sub looks like in my room - but I know it sounds great to my ears, so its more for curiosity sake. I still have this question, and this is where I think I still don't understand a piece of this. After you take your measurements, what do you do? Taking yours as an example - how do you pull the 50hz and 80hz drop up to remain flatter? What would you do? How would you know what to do? Would you want to or does a drop at those frequencies make sense in your environment? How would you know?
citsur86 is offline
post #24312 of 28258 Old 07-12-2016, 08:25 AM
Liked: 568
So, for the LV12R with a 19Hz port tune, room gain can occur from 32Hz to 19Hz, but not under 19Hz?
post #24313 of 28258 Old 07-12-2016, 08:31 AM
Quoted: 415 Post(s)
Liked: 284
You have a lot of questions. lol
There are so many things you can do. I do not have access to most of my REW files right now. A couple of things is positions.
You can set your mic up and measure your response over and over again with different positions. And I don't mean the 3 different positions in your room I'm talking about 6 inchs from the wall vs 8 inchs from the wall. Even sub facing the east wall versions west wall. Also phase controls on subs are so much easier to do with REW. I do not have any EQ system so I need to move my sit and or speakers to they and get a flat response. Here are two things that I did with REW. First was a bass trap test with 1,3,and 5 bass traps. Second was my speaker 4,5, and 6 feet from the front wall.
I hope others will answer this question also.
Name:	bass traps.jpg
ID:	1541905   Click image for larger version
post #24314 of 28258 Old 07-12-2016, 08:31 AM
Liked: 568
I have a big wide dip between 2 huge peaks at 50Hz and 90Hz. I just cut everything down to the lowest point in the dip and end up with a perfectly flat response from 19Hz to 100Hz. Of course, this may not be the right approach for everyone, but I get absolutely perfect bass this way in terms of SQ and balance.
I tried boosting the dip a bit and cutting the rest down and basically got the same end result by measurements, but it sounded kinda off by ear. That was with a max boost around 60Hz of 6dB. Anything beyond that sounded downright bad, especially with music.
post #24315 of 28258 Old 07-12-2016, 08:34 AM
Liked: 568
Might want to look into sub EQ, without it there is no position in my square room that has acceptable FR or waterfall.
post #24316 of 28258 Old 07-12-2016, 08:40 AM
citsur86's Avatar
Quoted: 984 Post(s)
Liked: 308
eorr23 likes this.
citsur86 is offline
post #24317 of 28258 Old 07-12-2016, 09:18 AM
Quoted: 415 Post(s)
Liked: 284
Originally Posted by PlasmaPZ80U View Post
Might want to look into sub EQ, .
I'm just a simple 2 channel setup, no sub, and no EQ. These are old graphs that I'm just using for examples.
post #24318 of 28258 Old 07-12-2016, 09:20 AM
torii's Avatar
Quoted: 831 Post(s)
Liked: 428
you can also manually adjust the distances set in avr for the subs. every x amount of feet equals a wavelength at certain hz or something like that. this method can help tweak/raise room nulls.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is offline
post #24319 of 28258 Old 07-12-2016, 09:25 AM
bkeeler10's Avatar
Quoted: 308 Post(s)
Liked: 183
Re Room Gain, I don't think that the room "cares" whether the bass is coming from a ported sub or a sealed sub, or a bass drum or stringed bass, or whatever. The room "supports" the low frequencies it will, no matter the source. The reason room gain is less pronounced for ported subs is simply because the output of the ported sub drops very quickly below port tune (about twice as quick as a sealed sub would be below that same frequency), so there's less output for the room to support.
Suppose you have a ported sub tuned at 20 Hz, and a sealed sub capable of the same output as the ported sub at 20 Hz. Suppose that your room gives you 6 dB of gain at 22 Hz and 8 dB of gain at 17 Hz. Then play a 22 Hz tone at 90 dB anechoic. The output of both subs will be increased by 6 dB, to 96 dB.
Now play a tone at 17 Hz, with the same signal strength. The ported sub will probably be down 8 dB (playing at 82 dB anechoic) while the sealed sub will probably be down 3 dB (playing at 87 dB anechoic). Both subs still get an 8 dB boost from the room at 17 Hz. The in-room response for the ported sub will be 90 dB (82 anechoic + 8 room gain), while the in-room response for the sealed sub will be 95 dB (87 anechoic + 8 room gain).
Just wanted to clarify that, since there seems to be some confusion. And, as always, this is as I understand it.
bkeeler10 is online now
post #24320 of 28258 Old 07-12-2016, 09:32 AM
Quoted: 415 Post(s)
Liked: 284
Originally Posted by bkeeler10 View Post
Re Room Gain, I don't think that the room "cares" whether the bass is coming from a ported sub or a sealed sub.
Correct, I was just keeping it simple and short.
but we should get back on topic... how about the Rythmik F8 and F12g? Best music subs from Rythmik. I wish I could do a blind test with those and the L12 and a few ported Rythmik subs.
post #24321 of 28258 Old 07-12-2016, 10:17 AM
Liked: 568
Yeah, that sounds absolutely correct and consistent with what I've read before.
healthnut likes this.
post #24322 of 28258 Old 07-12-2016, 10:19 AM
Liked: 568
I see.
Yes, the sw dist tweak. Though nowadays I find my AVR's auto cal gives an ideal result and tweaking things further doesn't help SQ-wise.
post #24323 of 28258 Old 07-12-2016, 10:28 AM
torii's Avatar
Quoted: 831 Post(s)
Liked: 428
my very old velodyne hgs 12 sub came with a remote control. it is very handy when listening to boost or turn down the sub based on mv or sq if the sources change alot. wonder why very few new subs come with this feature? Is it due to avr's having sub trim options available? does rythmik plan on releasing a remote control for their subs anytime in the future?
torii is offline
post #24324 of 28258 Old 07-12-2016, 10:29 AM
Liked: 568
When it comes to musical subs, I would say all Rythmiks fall into that category. You just need to select high or mid damping.
The sealed models might be slightly better for music only setups and the ported models might be slightly better for HT only setups. The biggest difference being a single ported sub of a given driver size will have about twice the max output at 20Hz of a single sealed sub of the same driver size.
As for the F8, I think its best used for high crossovers and/or as a midbass module. However, it could be suitable for general music or even mixed music and ht use if output is not a priority nor is getting serious impact from LFE. The main caveat being that a pair of 8 inch drivers in sealed configuration is going to have its limits vs. the larger subs.
(Jim's review of the F8 gives a good idea of the kind of buyer that would be best suited for the F8.)
post #24325 of 28258 Old 07-12-2016, 11:49 AM
Liked: 568
Watching Allegiant right now and it sure does impress as far as bass goes.
London Has Fallen had great overall sound, but mostly lacking in bass.
post #24326 of 28258 Old 07-12-2016, 12:08 PM
Liked: 1180
Just wanted to make you guys aware about a company named Orisun Audio who is trying to sell subwoofers that are, in appearance very similar looking to Rythmik Audio subwoofers and Velodyne subwoofers. If you see the picture below you will know what am I talking about. These are NOT Rythmik Audio subwoofers, they don't use Rythmik Audio parts and they are NOT direct servo subwoofers. Unfortunately, we have an overseas customer who got scamed by this company and after opening the subwoofer he found out that the driver has only one pair of cables because it has no servo coil. Also, damping controls, rumble filter and freq controls do nothing. They are just there as ornaments. They also claim that are located in Charlotte, NC but they are not. This is an overseas company, most probably Chinese, who has no presence in the USA. Our overseas dealers are already aware of this but now I wanted to inform our US customers because they have listed an US address in their contact info but there is no phone or even an email to contact them.
Name:	Screen Shot 2016-07-12 at 1.17.06 PM.png
post #24327 of 28258 Old 07-12-2016, 12:12 PM
DonH50's Avatar
Quoted: 1878 Post(s)
Liked: 1407
Guess you've made the big time now... I'll never understand the (lack of) ethics and morality of some people, and some companies.
Thanks for the head's up. - Don
MrGrey, torii and eorr23 like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #24328 of 28258 Old 07-12-2016, 12:48 PM
JimWilson's Avatar
Liked: 1689
If so it's a typical pattern of infringement. The area is renown for stealing IP by directly copying the real thing; since the original is made there anyway access to the manufacturing is probably only a handful of cash away (and a small handful at that). They've even ripped off the design of entire cars! I've seen pictures of Audi clones that look indistinguishable from the real thing.
post #24329 of 28258 Old 07-12-2016, 12:53 PM
MrGrey's Avatar
Quoted: 562 Post(s)
Liked: 678
Companies like that needs to get their knees broken, I just can't freaking stand people like that, totally disgusting.
Sent from my LG-H901 using Tapatalk
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Sub - Rythmik FV15HP
The Ultimate List of BASS in Movies w/ Frequency Charts
My PayPal.Me
MrGrey is offline
post #24330 of 28258 Old 07-12-2016, 12:54 PM
torii's Avatar
Quoted: 831 Post(s)
Liked: 428
remember the days when we had restrictions with china business/trade?
torii is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
