Official Rythmik Audio Subwoofer thread - Page 821 - AVS Forum | Home Theater Discussions And Reviews
 2027Likes
post #24601 of 24623 Old Today, 07:20 AM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
Originally Posted by PlasmaPZ80U View Post
The low pass filter (crossover knob and lpf slope switch)
By the way, when you get REW you can do compression sweeps (carefully) and determine at what volume setting on the AVR the sub starts compressing at 20Hz.
Also, keep in mind that MCACC could be setting the sub a bit hot all on its own (YPAO sets mine 6-7 dB hot all on its own) AND that bass management adds to the LFE too. And the more speaker channels you have the more bass management is sent to the sub. All these things can make the sub play louder than it would otherwise.
So, how loud the sub plays is based on whether the sw trim is running hot and by how much, the number of bass managed speaker channels, and obviously the AVR master volume (MV).
And regarding bass management, if you don't use upmixing, 2.0 has 2 channels of bass management, 5.1 has 5, 7.1 has 7, etc.
So, a 5.1.signal will have the sub playing more softly than a 7.1 signal by a few dB.
Got it - I'm playing in 5.1 with PLIIz on to power the front heights - so 7 channels. Just got to the scene where they crash and he is floating under water. The sub made some not so nice sounds. Sounded low, so not clipping or anything, but possibly was just a frequency too low to hear. Besides that part and the one at the beginning, the sub has handled the movie wonderfully. The whole system sounded great. I'm at 55 now and im assuming this is close to reference as it is very loud - just below unpleasantly so haha.
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is online now
post #24602 of 24623 Old Today, 07:41 AM
Bond 007's Avatar
Quoted: 1701 Post(s)
Liked: 1562
First Ive heard that. You confirm that with REW?
Bond 007 is online now
post #24603 of 24623 Old Today, 08:02 AM
Bond 007's Avatar
Liked: 1562
Originally Posted by citsur86 View Post
So I have a big problem (I think). I popped in Edge of Tomorrow this morning since I heard it was a good movie to watch for the LFE. At the beginning, before the movie really started, there was a crazy sound that came out of the LV12R that did not sound right at all. When I got up to switch it over to High (it was on Low) i noticed it wasnt on, and it wont turn on - even when plugged in. If I put the switch to On or Auto, no lights. Any idea what happened here?
Woops. Might not wanna do that again.
Its a Rhythmik but its the entry level Rhythmik. Adjust your standards accordingly.
post #24604 of 24623 Old Today, 08:04 AM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
Well I wasn't searching out that scene - just read that it was a good movie for LFE so decided to pop it in this morning. It's a bit scary that at the normal volume I listen to movies with my EQ as it is, there's a chance that some random scene in a movie could do that to the sub. Guess from now on before I watch a movie I will look it up online to see if there are any watch-out moments like that one. So far I've seen just Edge of Tomorrow and Django have Subwoofer killing parts. Any others off the top of anyones head they could think of?
post #24605 of 24623 Old Today, 08:07 AM
Bond 007's Avatar
Liked: 1562
Theres no way thats the case.
Youre either listening way too loud or have the sub way too hot.
Ive had the LV12r for 6 years and have never had any problem.
AlexanderDelarg likes this.
post #24606 of 24623 Old Today, 08:10 AM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
So I have the sub at +6db from what MCACC set it to, and I was listening probably a bit under reference. Is that not reasonable? Also the more I've read about this this morning, the more I see its rare and only present in a handful of movies. Have you watched Edge of Tomorrow with your normal settings? No issues?
post #24607 of 24623 Old Today, 08:23 AM
healthnut's Avatar
Quoted: 247 Post(s)
Liked: 131
The rescue scene in Lone Survivor, The pod scene in War of the Worlds, the dragon fight (10hz) in How to Train your Dragon, check out the master thread of low bass scenes for much more.
healthnut is online now
post #24608 of 24623 Old Today, 08:48 AM
PlasmaPZ80U's Avatar
Quoted: 1543 Post(s)
Liked: 463
Well, REW hdmi channel 4 is just LFE. It doesn't include the usual 5 or 7 bass managed speaker channels.
I've read this in many places AVS and other, including the Audyssey thread, I believe.
Also, he should make sure that MCACC is not setting the sub hot like YPAO is in my case... I use to think I liked running the sub 3-4dB hot but in reality it was 3-4dB plus 6-7dB hot: up to 11dB hot! And that is with a flat sub frequency response, not a house curve.
I now just leave it where YPAO sets it (6-7dB hot). It integrates alot better at these more reasonable levels.
I also discovered that by lowering all my speaker and the sub trim (via offsets) so the lowest channel is -10.0dB, I can set my sub gain much lower than if relying on YPAO alone (keeping sub trim just under 0). And this interestingly enough gets the speakers playing 75dB with the AVR manual test tones at 0MV. Basically, like if I had an AVR with Audyssey.
PlasmaPZ80U is online now
post #24609 of 24623 Old Today, 08:56 AM
Liked: 463
Odds are the size of your room plus your listening levels with sub 6dB hot made the sub exceed it's output limits down low.
REW will let you see what's going on and how loud you can get in your room without issues but you might need more subwoofer(s) if you want to continue listening at your present levels.
You also can check in REW that MCACC isn't already running things hot on its own or that it's boosting the sub too much, especially the low end.
post #24610 of 24623 Old Today, 09:53 AM
Liked: 463
I just did some compression sweeps to point of minor compression at 20Hz:
Name:	compression sweeps.jpg
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Rythmik LV12R; PS4, Xbox One, Motorola RNG150N
post #24611 of 24623 Old Today, 10:06 AM
JimWilson's Avatar
Quoted: 1049 Post(s)
Liked: 1252
Figured it out. The fuse under where the power cord is plugged in (found the pull out compartment) was blown. Luckily you good folks not only protected the sub from destroying itself, but you also provided an extra fuse within the pull out chamber. Fixed it. Recalibrating using MCACC now and I'll leave the sub at -6 for the duration of the movie. Crossover is 80hz for all speakers. Cheers!
You might want to keep an eye on that. Even if you did overdrive/overheat the sub I would think the thermal circuit should have shut it down before the fuse popped. That's uncommon, at least in my experience anyway.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #24612 of 24623 Old Today, 10:28 AM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
Strange. I didn't do anything strange just plugged into LFE like normal.
post #24613 of 24623 Old Today, 10:39 AM
Alan P's Avatar
Quoted: 3706 Post(s)
Liked: 2461
Very well known sub killer scene. The rest of the movie doesn't even have much bass, just the out-of-place tones during the intro.
Edge of Tomorrow... careful guys!
Edge of Tomorrow - Is My SW Broken?
Edge of Tomorrow intro
Alan P is offline
post #24614 of 24623 Old Today, 10:40 AM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
Wow i don't understand why they would put that into the movies sound mix! Lucky for me the fuse blew and sub is fine after having replaced it.
MrGrey likes this.
post #24615 of 24623 Old Today, 03:29 PM
JimWilson's Avatar
Liked: 1252
You didn't do anything wrong. A properly engineered subwoofer - which the Rythmik line are - will be designed to prevent the user from doing anything foolish. Mechanisms such as shelf filters and thermal protection are incorporated to avert self destruction. You may hear the occasion port chuffing, or some other sound of distress, but those are more an indication of reaching a limit then signs you've damaged anything. Think along the lines of tire squeal; you push a car too hard around a corner and you're likely to get an audible warning that you're approaching the limits of adhesion (squeal). Back it down a touch and all is good. Similar concept.
A blown fuse is a bit different though, because that implies the current draw exceeded rated capacity. That's never good. However, fuses are really cheap mass produced parts with zero QC that are made by the gazillions. It's not inconceivable that you were squealing the tires, as it were, and the fuse blew before its rated capacity would have suggested. In other words, it might have been a bum fuse from the get go. That's why I suggested just keeping your eye on it; while a blown fuse is not common, it may have been due to something not related to the amp or what you were doing.
post #24616 of 24623 Old Today, 03:47 PM
ndabunka's Avatar
Quoted: 65 Post(s)
if your amp goes from zero to 100 then 50 is probably reference so you may want to turn it down to 50 moving forward. No need for anything to be "near unpleasant".
From time to time, the Gene Pool could use a little chlorine ...
ndabunka is online now
post #24617 of 24623 Old Today, 04:01 PM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
It goes from 0 to 80 actually. But I think it sounds closest to the volume you would hear in a movie theater around 50-55. Anything over 55 is harsh and unpleasant. I usually watch movies somewhere between 50-55
Can anyone tell me what size fuse it is that's used in the LV12R? I would like to pick some up to have on hand in case this one goes.
post #24618 of 24623 Old Today, 04:09 PM
torii's Avatar
Quoted: 556 Post(s)
Liked: 246
if you blow more than 1 fuse, I would be looking at other issues. if you cant turn up your system to 70-80% maybe your gains and/or trims are set too high.
I was just listening to some bass hvy music and my velodyne hgs 12 started making obnoxious sounds. I quickly muted and checked its controls and forget to turn back on its subsonic filter. it was really trying to keep up with my rythmik :P
I had it turned off for some movies, but music will really test a sub imo more than 99% movies due to movies usually just an explosion or short duration boom, where music can literally be non stop.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc800v, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is online now
post #24619 of 24623 Old Today, 04:11 PM
citsur86's Avatar
Quoted: 262 Post(s)
Liked: 65
Only the one has blown so far. Just want to have another on hand in case it happens so I can get back up and running immediately, at which point I would do some further investigation. My UMIK-1 comes tomorrow and I have the house to myself, so I'll be running REW tomorrow.
post #24620 of 24623 Old Today, 04:14 PM
torii's Avatar
Quoted: 556 Post(s)
Liked: 246
sounds like a good plan
torii is online now
post #24621 of 24623 Old Today, 04:15 PM
JimWilson's Avatar
Liked: 1252
Assuming it's the ubiquitous glass tube style it will etched into the metal ends.
ndabunka likes this.
post #24622 of 24623 Old Today, 05:41 PM
laserjock II's Avatar
Quoted: 527 Post(s)
Liked: 241
Make sure they didn't put the lower rating for 220VAC fuse in there.
Here's an example
http://www.rythmikaudio.com/download/XLR3_sealed_quickguide.pdf
laserjock II is online now
post #24623 of 24623 Old Today, 05:55 PM
buckshot's Avatar
Quoted: 28 Post(s)
My FV15HP has a new friend. The UPS guy dropped this off today.
The AVS forum is good for the ears but terrible for the wallet.
buckshot is online now
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
