Official Rythmik Audio Subwoofer thread - Page 824 - AVS Forum | Home Theater Discussions And Reviews
 2054Likes
post #24691 of 24709 Unread Yesterday, 05:51 PM
newc33's Avatar
Quoted: 476 Post(s)
Liked: 499
Originally Posted by PlasmaPZ80U View Post
Nice to see the limiter is now separate from the power switch.
By the way, that's a lot of knobs and switches. The compact amp is much simpler.
Nice, I didn't even notice that. I like seeing the limiter separate as well
7.4 w/ denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
dual reaction audio gamma 21s!
Dual PSA s3600i's
newc33 is offline
post #24692 of 24709 Unread Yesterday, 06:57 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
These are the screws I took out that won't retighten.
FS: Proficient GL6 Center Channel Speaker
My Current "Living Room" Home Theater!
citsur86 is online now
post #24693 of 24709 Unread Yesterday, 06:58 PM
Liked: 8
me like
Karnis2 is online now
post #24694 of 24709 Unread Yesterday, 06:59 PM
MrGrey's Avatar
Quoted: 259 Post(s)
Liked: 141
Was something broken? Why was it even opened 😬 you are living on the edge manπŸ˜‚.
Sent from my LG-H901 using Tapatalk
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Surrounds - Don't ask lol
Sub - Rythmik FV15HP
MrGrey is offline
post #24695 of 24709 Unread Yesterday, 07:10 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Originally Posted by MrGrey View Post
Was something broken? Why was it even opened you are living on the edge man.
In an attempt to "fix it" yesterday since it wouldn't even turn on I started unscrewing ALL the screws on the back not realizing only the ones around the perimeter were needed to remove to get the amp plate out. I loosened 4 perimeter screws and the two screws you see in the above photo before noticing the compartment under the power input which holds the fuse (shown below for anyone interested).
Once I realized it was just a blown fuse in secured the 4 or so perimeter screws I had removed and tried to secure the 2 in this photo but they just spin in place once all the way in. I was told today they might be screws with nuts on the other side so I took the amp plate completely off to see if I could find the nuts (which I thought might be causing my rattle). Turns out they don't look like but screws but are holding on the pictured component (transformer?) They won't tighten though still. That's what I need help with.
post #24696 of 24709 Unread Yesterday, 07:15 PM
enricoclaudio's Avatar
Quoted: 694 Post(s)
Liked: 694
Use two philips screwdrivers. One inside and one outside. It is like tightening a nut and bolt with two wrenches.
Enrico Castagnetti @ Rythmik Audio
Media Room: Polk LSiM705s, LSiM706C, LSiM703s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Duet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #24697 of 24709 Unread Yesterday, 07:19 PM
Quoted: 694 Post(s)
Liked: 694
Or you can use a small wrench (I think it's 8 mm) between the circuit board and the amp plate to stop the gold nut spinning so you can tighten the inside and outside screws.
post #24698 of 24709 Unread Yesterday, 07:36 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Got one of them on there that way. The other won't go even when I tighten from both sides at the same time. I think the small bolt might be stripped. Any idea what size they are so I can pick another one up?
post #24699 of 24709 Unread Yesterday, 07:40 PM
buckshot's Avatar
Quoted: 29 Post(s)
Liked: 37
Those look like risers and screws you would get with a computer case. I could be wrong though.
buckshot is offline
post #24700 of 24709 Unread Yesterday, 07:46 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Genius! This gave me the idea to pull one off of my old sub that is no longer used (trash) and viola! same size and all - sub is all back to normal now, all screws and bolts secured. Will rerun MCACC and REW tomorrow and see if anything is changed.
post #24701 of 24709 Unread Yesterday, 08:03 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Decided to run tonight instead. Sub sounds back to normal! No more rattling during MCACC! Running REW now.
post #24702 of 24709 Unread Yesterday, 08:11 PM
Quoted: 151 Post(s)
Liked: 59
I was about to tell you to do it tonight. Stop leaving us in suspense lol
Theriddler07sms is online now
post #24703 of 24709 Unread Yesterday, 08:18 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Actually looking a bit better getting ready to post graphs and files in REW thread!
post #24704 of 24709 Unread Yesterday, 08:35 PM
ndabunka's Avatar
Quoted: 78 Post(s)
Completely OFF topic but my wife just saw this thread and said she thought she knew you. She says your picture looks a lot like Duff Goldman, the Ace of Cakes guy
From time to time, the Gene Pool could use a little chlorine ...
ndabunka is offline
post #24705 of 24709 Unread Yesterday, 08:52 PM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
Haha nice - I can honestly say that is a first - that dude is awesome though!
ndabunka likes this.
post #24706 of 24709 Unread Yesterday, 10:20 PM
BDP24's Avatar
Quoted: 246 Post(s)
Liked: 170
Now keep yer hands off the damn amp! Why were you removing the screws that hold on the metal stand-offs that support the circuit board? And if you got them loose, why couldn't you then retighten them? You should be listening more, not tinkering with the amps innerds. Relax and enjoy the damn subwoofer!
BDP24 is offline
post #24707 of 24709 Unread Today, 03:13 AM
Bond 007's Avatar
Quoted: 1716 Post(s)
Liked: 1563
lol
Bond 007 is online now
post #24708 of 24709 Unread Today, 04:06 AM
citsur86's Avatar
Quoted: 297 Post(s)
Liked: 73
A movie I was watching blew the amp fuse. I didn't know that's what happened but it wouldn't turn on at all so I tried to remove the amp to see why it wouldn't turn on. Didn't realize the center screws weren't holding the amp on. Couldn't tighten them once they I loosened them because they have to be tightened from both sides. I finally did and fixed the fuse and now all is good. Hope that answers your questions lol. I will now continue to enjoy it.
post #24709 of 24709 Unread Today, 05:33 AM
Quoted: 14 Post(s)
Liked: 3
I have my sub sounding great now. After initially rerunning Audyssey and making sure the sub was detected, I increased the db to 0 from -3.5 and turned the volume knob from 12 to about 1:30. I watched a few scenes including The Incredible Hulk campus scene and the Super 8 train crash scene. Both of these scenes produced excellent defined bass. Thanks for everyone's help. I truly appreciate it.
thinksmartpc is online now
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
