Official Rythmik Audio Subwoofer thread - Page 858 - AVS Forum | Home Theater Discussions And Reviews
 2417Likes
post #25711 of 25724 Unread Today, 09:01 AM
bear123's Avatar
Quoted: 1533 Post(s)
Liked: 2218
Usually only one amp is needed for buttkickers unless you have a lot of them. I.E. multiples can usually be driven off a single channel depending on power handling and how powerful the amp is. I suppose you could just use the second sub output from the AVR, but splitting a connection would work as well as it won't alter the voltage.
bear123 is offline
post #25712 of 25724 Unread Today, 09:45 AM
ndabunka's Avatar
Quoted: 129 Post(s)
Liked: 32
Originally Posted by citsur86 View Post
I think you're right. A projector screen would be much bigger of an upgrade than a new receiver. Would really prefer an electric screen that rolls up into the ceiling and out of sight. Decided to grab a tape measure today and measure between the speakers. I couldn't measure the diagonal directly but I measured the length along the ground and the height based on where I could see it coming down. 120"x55" which, using a little Pythagorean, gives me a 132" screen max. I'd likely wanna go a bit smaller if/when I do it.
In-ceiling powered models can get pricey (thousands for a good one) and then when you pair it with a good projector you will likely spend $3 to $4K on the video alone so just realize that it's not an economical approach.
I am modifying my old draper using a flush ceiling mount kit which will likely cost me about $500 to $1000 for the changes. There is a 120" model similar to it on eBay for $500 but the seller has not stated if the material is acoustically transparent or not so I have not bid on it myself... yet.
From time to time, the Gene Pool could use a little chlorine. Just say'N
Yamaha RX-A3060 7.1.4, B&W Signature 7's (Left/Right), FMP4 Center, CWM7.5 surrounds & rears, CCM65 (Four in-ceiling), Rythmik 15" Custom, Sony VPL-HW50ES
ndabunka is offline
post #25713 of 25724 Unread Today, 10:34 AM
Bond 007's Avatar
Quoted: 1819 Post(s)
Liked: 1627
What's the latest word on the logos?
Bond 007 is online now
post #25714 of 25724 Unread Today, 11:46 AM
Blacklightning's Avatar
Quoted: 283 Post(s)
Liked: 187
Anybody else love the Salk Version of the F15?
$1695
We have built many custom subwoofers over the years for all kinds of applications. But since Rythmik introduced their Direct Servo Technology, we've pretty much limited subwoofer production to Rythmik-based designs. They are simply too good.
It takes a lot of air movement to generate deep bass. And there is just as much energy coming off the rear of the subwoofer cone as there is initiated by the front of the cone. The result is a tremendous amount of energy being directed back into the subwoofer cabinet. This energy can easily create cabinet resonances and can cloud the clarity of the bass response.
We address cabinet resonance in two ways. First, with our Rythmik 15" builds, we use 1 1/2" walls rather than the standard 3/4" walls. This added mass lowers cabinet resonances to extremely low levels. We also add very substantial bracing to further reduce the chances of cabinet wall resonances. The result is extremely clean, precise and musical deep bass.
When set up properly, the sub should never call attention to itself. But your system will play significantly deeper than before and the sound will be very clean, accurate and musical...which is how it should be.
Also F12 $1295
Blacklightning is online now
post #25715 of 25724 Unread Today, 11:49 AM
Marc Alexander's Avatar
Quoted: 258 Post(s)
Liked: 188
Also F12
Uh… yeah! Estimated cost?
Marc Alexander is online now
post #25716 of 25724 Unread Today, 11:53 AM
citsur86's Avatar
Quoted: 672 Post(s)
Liked: 159
+1 for an upade from @enricoclaudio on these.
Also F12
I'm personally not a fan of this. I don't think it looks bad just not my personal style. However, how does one get Rythmik Sub with a custom box made?!
My Current "Living Room" Home Theater!
Pioneer Elite VSX-44 AVR, MiniDSP 2x4 HD DAP,
Rythmik FV15HP SW x1, B&W 684 S1 Mains x2,
B&W 685 S1 Surrounds x2, B&W CM Center S2 x1,
Polk T15s Front Heights & Rear Surrounds x4
citsur86 is online now
post #25717 of 25724 Unread Today, 11:54 AM
Quoted: 258 Post(s)
Liked: 188
Salk has many different wood finishes to choose from.
post #25718 of 25724 Unread Today, 11:55 AM
citsur86's Avatar
Quoted: 672 Post(s)
Liked: 159
Oh cool thanks!
post #25719 of 25724 Unread Today, 11:56 AM
DonH50's Avatar
Quoted: 1593 Post(s)
Liked: 1108
The 12" model is $1295 with standard finish(**); custom finishes go up from there. The 15" model starts at $1695. Jim uses heavier cabinets with more bracing than standard Rythmik so he does more than just fancy finishes but the guts are the same.
From Salk website: ** Standard finishes include curly maple, curly cherry, curly walnut, oak, straight mahogany and satin black. Wood veneers can also be dyed. So, for example, you can have deep rose-red curly cherry or electric blue curly maple. See gallery for examples.
I was going to pull weights to compare but at the moment Rythmik's website is not accessible to me (appears to be down).
If you want a Salk version, order from Jim Salk: http://www.salksound.com/ He makes some great speakers, too!
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #25720 of 25724 Unread Today, 12:04 PM
Quoted: 283 Post(s)
Liked: 187
Step one: http://www.rythmikaudio.com/products2.html
Step two: Find Cabinet maker
Step three: say goodbye
post #25721 of 25724 Unread Today, 12:22 PM
laulau's Avatar
Location: "The loveliest fleet of islands that lies anchored
Quoted: 70 Post(s)
Liked: 95
Different strokes...
I'm a fan of just about everything Salk does, his end products are only limited by your imagination and wallet. Having said that, my Rythmiks are black oak as I got my first one long before Salk started making custom Rythmiks.
Salk SongTowers-RAAL/Salk SongCtr-RAAL/Salk SongSurr ; Rythmik F12 (x2) (my humble setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Xbox 360; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3 w/Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics ::: CCA > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 ::: FooB2K > Schiit Modi2U > Schiit Magni2U > Oppo PM3
laulau is offline
post #25722 of 25724 Unread Today, 12:32 PM
citsur86's Avatar
Quoted: 672 Post(s)
Liked: 159
Yeah don't get me wrong, I think it looks beautifully done, and very professional. Just that specific finish not in line with my personal tastes.
post #25723 of 25724 Unread Today, 12:35 PM
Quoted: 258 Post(s)
Liked: 188
Money no object I get Salk to build me 4 F25s!!
post #25724 of 25724 Unread Today, 12:54 PM
rcohen's Avatar
Quoted: 1042 Post(s)
Liked: 408
I've done some reading on buttkickers and the likes. Still trying to figure out how the signal gets to them. Do I split my second subwoofer pre/out on my AVR to 2 external amps that drive the buttkickers?
One of these days, I think it would be fun to play with some cheap, generic ones:
https://www.parts-express.com/dayton...watts--295-244
I've read that the ideal signal to send to tactile transducers is bass without room EQ, ideally with a custom tuned HPF & LPF. I've only experienced stuff like this that was pretty gimmicky and distracting, but many enthusiasts around here have said that it's possible to tune them to feel natural and not distracting - just enhanced impact and immersion - similar to ULF.
Many have said that Crowsons are superior to the Buttkicker style transducers, but they are more expensive.
rcohen is online now
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
