Official Rythmik Audio Subwoofer thread - Page 874 - AVS Forum | Home Theater Discussions And Reviews
 4244Likes
Old 09-17-2016, 02:55 PM
enricoclaudio's Avatar
Quoted: 1319 Post(s)
Liked: 1373
You can also try with a cheater plug (three to two prong adapter) to see if the hum goes away.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 09-17-2016, 11:27 PM
kyzer soze's Avatar
Quoted: 146 Post(s)
Liked: 64
Originally Posted by enricoclaudio View Post
Maybe the new cable is fine but the power outlet in the new location is not in the the same circuit as the receiver. Try plugging the subwoofer in the same outlet that it was before and try both subwoofer cables.
Your advice worked thank you!!! Why does that happen I never knew my sub and receiver should be plugged in to the same circuit.
Ascend Sierra 2's (LCR & side surrounds) + Pioneer upfiring modules. 5.1.2 setup
Marantz AV7703
NAD M25
Rythmik FV15HP
kyzer soze is offline
Old 09-18-2016, 04:53 AM
Liked: 1373
Ground Loop
Old 09-20-2016, 09:05 AM
Quoted: 27 Post(s)
Originally Posted by Bruce Watson View Post
I'm 10 days late to the party, but... I've got nearly the same room, running a Denon x4000, with the subs at 4 dB hot, and I'm running a pair of LVX12s. Couldn't be happier. Even my wife couldn't be happier. I was pleasantly surprised that the 12s don't leave me wanting at all. I tend to play movies at about -20 when the wife is with me, and -5 when she's out. Either way the Rythmiks sound perfectly flat, completely relaxed, like they are just lopping along without a care in the world (while shaking the walls). I don't think the 15s would be any different at all; they could deliver the exact same SPLs (with a few more dB at max output if you ever manage to get there), just at a higher cost.
Now, if you can't get the 12s through Ascend Acoustics, by all means go for the FVX15s. Same tech. same sound, a few more dB max SPL. It might be overkill but that won't hurt anything.
Thanks for the input! It's $175 more for me to get the pair of FVX15's from Ascend Acoustics vs the LVX12's direct from Rythmik due to sales tax. I think the 15's are overkill for my purpose but for the small difference in price it's kind of like 'why not,' I'll have a little more headroom and a couple hz lower extension. Will be ordering today... hoping to get black matte in spite of what Rythmik's website says.
filter_sweep is offline
Old 09-20-2016, 09:14 AM
Quoted: 68 Post(s)
Liked: 86
Last time I tried to purchase a Rythmik from Ascend, no sales tax was added shipped within CA. Sales tax is added for other Ascend speakers though. So I'm not sure what's happening there, but you may want to check it out.
choombak is offline
Old 09-20-2016, 09:15 AM
Quoted: 68 Post(s)
Liked: 86
Finally after a week long analysis paralysis phase (and selling my SVS SB12-NSD), I put in an order for a B-stock Rythmik E15HP black matte now! Hopefully I'll be on this thread more and more going forward. And yes, I am super excited! :-D
choombak is offline
Old 09-20-2016, 09:16 AM
Liked: 1373
The FVX15 black matte is back in stock. Ascend does not carries any stock with them. All Rythmik Audio subwoofers are shipped from our warehouse in Austin, TX. We process orders placed directly with us the same day. Ascend usually takes 4 - 5 days to process orders then they send the order to us.
Old 09-20-2016, 09:23 AM
Liked: 1373
BTW, if you live in TX and order from Ascend Acoustics in CA, you will pay TX sale taxes either way. It won't show up in Ascend's shopping cart but they will add the sale taxes portion manually to your method of payment.
Old 09-20-2016, 09:48 AM
Quoted: 27 Post(s)
Thanks for the heads up on that... a little disappointing but it opens up my options a bit... makes me wonder if the LVX12's really would be better for me then.
Old 09-20-2016, 09:53 AM
Liked: 1373
Sent you a PM.
Old 09-20-2016, 10:39 AM
citsur86's Avatar
Quoted: 1348 Post(s)
Liked: 535
How did your testing of the logos go? Any methods found to be better than any others?
citsur86 is offline
Old 09-20-2016, 11:07 AM
Liked: 1373
No testing yet, sorry. Brian sent me the logos yesterday so I should be getting them today or tomorrow.
Old 09-21-2016, 06:34 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 265 Post(s)
Liked: 365
Here is what my method is.
I use superglue gel. Unlike the regular fluid version, it is very well controlled. It bonds in 5 seconds and complete cure may take just a couple of hours.
As always, practice whatever many times you can, and then glue only once.
First dry fit and check if the logo plate is flat (not damaged or warped during shipping)
The trick of applying glue is only put on small beads of glue. Give about same distane to all edges. 3/16" will do.
Tapes can help alignment.
Good lighting is going to be very helpful. But missing the spot a bit is not a big deal.
Side view of the logo.
enricoclaudio and MrGrey like this.
Rythmik is offline
Old 09-21-2016, 07:15 AM
JT78681's Avatar
Quoted: 1441 Post(s)
Liked: 960
@Rythmik
Brian could I stop by the shop sometime and get two of these logos for my grills?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 09-21-2016, 07:38 AM
KanosWRX's Avatar
Quoted: 178 Post(s)
Liked: 58
New cable and now my sub is making a humming noise. My old cable is blue jeans I've tried switching back and forth it only hums with this new one. Argh!!!!!
I had a humming issue in one of my cables that I bought on Amazon (Mediabridge I believe), it was actually a pretty good cable, used many of them before, but it was 50 feet long and you really need a good quality cable at that length. I ended up ordering the Blue Jeans Cable LC-1 Analog Audio Cable. Solved the hum issue just fine for me. It sounds like you had a blue jeans cable before, then bought a monster one. I would say switch back to the blue jeans cable or buy another. I think it comes down to the actual coper wire in the middle of the cable, most are just copper platted, which doesn't work well for long sub-woofer cable runs, causing hum. Basically it looses the ground over that long distance, which is why sometimes using a cheater plug can help. Rythmik actually helped me figure this out, so thanks to them
KanosWRX is offline
Old 09-21-2016, 07:41 AM
KanosWRX's Avatar
Quoted: 178 Post(s)
Liked: 58
I noticed the same thing as well, if I plugged them into the same circuit my hum went away, but that required me to run a 40 ft power cable though my walls which doesn't meet code Like I said in the post above, really all you should need is a high quality sub cable, not a mediabridge one from amazon or one from best buy either. But if your sub and receiver are near each other, and plugging them into the same outlet is ok, then whatever works for you best, stick with that
KanosWRX is offline
Old 09-21-2016, 11:28 AM
DonH50's Avatar
Quoted: 1997 Post(s)
Liked: 1561
There are numerous things you can buy to break a ground loop without running a 40' power cord across the room. You can buy line-level isolators or a power line isolator from Amazon pretty cheaply. A "high quality cable" will not break a ground loop. It might change the impedance of the loop and help, but it is very rare when a cable has done anything for me or clients.
Foundation42 likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 09-21-2016, 08:30 PM
Liked: 1373
Got the logos today and after some tests I agree with Brian that the best method is Superglue Gel.
As you can see we have two sizes. The big one for 15" subwoofers and the small one for 12". The price for the logos is $0, we are giving them away for free for current customers. We will charge only $2 for each logo for handling and shipping within the 48 states. We will sell up to 2 logos per customer unless you have more than 2 subwoofers. Brian is gonna make an order link that I will share with customers over email. I will post an update as soon I get the order link from Brian.
rcohen, citsur86, JT78681 and 1 others like this.
Old 09-22-2016, 12:40 AM
laulau's Avatar
Quoted: 78 Post(s)
Liked: 118
Any idea how much the shipping and handling will be to the 50th state? Thx.
Salk STRT / SongCtr-RT / SongSurr ; Rythmik F12 (x2) (latest ver setup guide) ; HT -- Denon 4520; DSonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; CCast; FireTV ; Furman Elite15PFi; Omnimic/REW; CalMAN i1D3/i1Pro2
HPs
RPi3Digi+ >AGD DAC19 >Cavalli LC >HFM HE400i :: Rpi3Digi+Pro >Schiit Bifrost 4490 >Schiit Valhalla >Senn HD600 & HD6XX ::
RPi3Digi+Pro >Schiit Mimby >Schiit Vali 2 >Meze 99 Classics :: FB2K >Schiit Modi2U >Schiit Magni2U >Oppo PM3
laulau is offline
Old 09-22-2016, 01:36 AM
Quoted: 473 Post(s)
Liked: 185
$2
Cant wait for my logo. May have to buy another FV15HP so I have something to put the second logo on. Buy a $1200 logo and get a free FV15HP sounds like a killer deal to me.
Theriddler07sms is offline
Old 09-22-2016, 03:01 AM
Bond 007's Avatar
Quoted: 2571 Post(s)
Liked: 2036
Good deal.
Bond 007 is offline
Old 09-22-2016, 04:00 AM
citsur86's Avatar
Liked: 535
Awesome! Can we get 2 even if we have 1 subwoofer? Id like the second to maybe put on the back of my
citsur86 is offline
Old 09-22-2016, 05:52 AM
Norixone's Avatar
Quoted: 62 Post(s)
Liked: 32
Logos
@ Enrico
It seems like I will have to invite you over for a plate of gnocchi to get my two logos
Norixone is offline
Old 09-22-2016, 05:55 AM
Liked: 1373
Originally Posted by Norixone View Post
@ Enrico
That sounds good to me but lets wait until October 12th. I'm in day 11th of Whole 30
Liked: 1373
Yes you can!!
Old 09-22-2016, 06:10 AM
Norixone's Avatar
Quoted: 62 Post(s)
Liked: 32
Wheren't you planing to come over for Easter?
Norixone is offline
Old 09-22-2016, 06:35 AM
Liked: 1373
Yes, that's my plan but most probably not for Easter weekend. Either one week after or come back two or three days before Easter. My older sister will be in Milan visiting my niece mid April so my plan is meet with them over there. Like a family reunion
Old 09-22-2016, 07:03 AM
Liked: 1373
It should cost the same. First class mail rate is flat within the 50 states.
Old 09-22-2016, 07:43 AM
Quoted: 27 Post(s)
Alright guys, after way too much research, reading of internet forums and hand-wringing, I placed an order for 2 x LV12Rs. Although I had my eye on a couple LVX15s, with TX sales tax factored in the price was really pushing it without having heard any of the subs I've been researching.
Here's the thing... I need a baseline. I'll be finishing my HT room this weekend, and I just have no idea what is enough vs overkill for my sealed 2500 cu ft of space. Based on my wife & kids' somewhat low tolerance for high volume, I'm convinced the LV12R's will be adequate 98% of the time... it's that other 2% I just don't know about... maybe they will and maybe the won't. If I'm left unsatisfied, I have options:
- Split them up and move them to other rooms (I have 2 more rooms that will soon have multi-channel audio and will also need a sub)
- Talk to Enrico / Brian about how to integrate more subs into my room and have them play nice with the LV12R's. I'm thinking these could be stacked on top of some of Rythmik's bigger subs in the back rear corners (only place my room will accommodate the subs) if needed, and cable them such that the AVR sees each stack as one sub.
- Rent a truck, drive the 3 hours to Austin and exchange with a couple FV15HPs (would save on shipping both ways).
Let the journey begin!
Old 09-22-2016, 09:44 AM
Bruce Watson's Avatar
Quoted: 44 Post(s)
Liked: 45
Alright guys, after way too much research, reading of internet forums and hand-wringing, I placed an order for 2 x LVR12's.
LV12R? Or LVX12? There is no LVR12.
Bruce Watson is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
