Official Rythmik Audio Subwoofer thread - Page 952 - AVS Forum | Home Theater Discussions And Reviews
 4675Likes
post #28531 of 30660 Old 04-14-2017, 08:37 AM
Marc Alexander's Avatar
Quoted: 2618 Post(s)
Liked: 2484
Originally Posted by budeliao View Post
My 4 F15HPs do a great job shaking the house, but can't say that's keeping me from considering 4 F18HPs when available. Biggest issue is my actual "out of pocket", which I figure to be (("Price of 4 F18HPs" - "what I could get for the F15HPs") x 2) due to "spousal compensation factor".
Do you know the price of the F18s?
Edit: 3 to 4 month wait on the F18 which may mean 6-8.
Originally Posted by enricoclaudio View Post
The F18HP should be ready in three months, maybe four. We have a F28 already here in Austin for testing. But that model will take a bit more, maybe by fall 2017.
Marc Alexander is online now
post #28532 of 30660 Old 04-14-2017, 08:55 AM
Liked: 2484
@jt78681
Originally Posted by rythmik View Post
fv18 uses 900wrms amp and fv25 uses 1800rms amp.
Fv18 will be 3db (updated) higher output than fv15hp. More improvement is from below 18hz where port output is significant. The improvement is via port compression reduction in the following way. In data-bass test data, our compression is the lowest because the servo feedback adjust the amp output so the output of woofer cone always maintain the consistent frequency response. The only exception is below 18hz where port output becomes significant. Since there is no sensor on ports, compression data show the loss of output even after we maintain correct woofer cone movement. Our observation from the data is 1db additional compression loss for every 5db spl increase until eventually the port wind noise takes over. So i expect to gain 1db more output just from lower port compression. So overall, it is 3db (updated value) more output.
For fv25, we expect 6db more output above 30hz. The enclosure size is reduced by 30% per driver, but we have 50% more power from amp. So in the end each driver in fv25 has approximately same output as fv15hp in the baseline comparison. But the number of ports (and port area) increases from 1 to 1.5 (per driver), therefore it cuts down the compression loss slightly.
One interesting information of fv15hp by data-bass is the 12.5hz max output from fv15hp in 1 port mode is not limited by the 2nd order or 3rd order harmonic distortion like in other tests. This means the amp output is not the limiting factor. Instead it is the upper band noise which is caused by port noise. So how can be reduce that upper band noise and allow for a higher output number with 2nd or 3rd order distortion becoming the limiting factor? First, 50% more port area per driver does help and second, we will use a bit more internal sound absorbing material. So that can give us up to 3db output improvement (or up to 9db total output as i referred early in this thread) at 12.5hz point.
post #28533 of 30660 Old 04-14-2017, 09:06 AM
JT78681's Avatar
Quoted: 1478 Post(s)
Liked: 1005
Originally Posted by Marc Alexander View Post
Sorry I should have been more specific in my post earlier. I am looking for pictures of the two subs side by side to get an idea of how much larger they will be.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #28534 of 30660 Old 04-14-2017, 09:53 AM
Schrodinger23's Avatar
Quoted: 58 Post(s)
Liked: 26
Here is a Photoshop picture that Rythmik has on their Facebook page:
https://www.facebook.com/rythmikaudi...type=3&theater
Marc Alexander likes this.
Schrodinger23 is offline
post #28535 of 30660 Old 04-14-2017, 12:52 PM
gopala33's Avatar
Quoted: 169 Post(s)
i know you told me you was using Acoustic Research PR153
can't get so you was give link for brand Mediabridge have you tested for quality sound BASS compare Acoustic Research PR153
Originally Posted by tvuong View Post
5m ~ 16.5 feet. Currently on Amazon, the longest Mediabridge Y subcable is 15ft. KableDirekt has a 20ft. Buy whatever one that is long enough for you. They are both excellent.
15ft = 4.5meter i think enough
gopala33 is offline
post #28536 of 30660 Old 04-14-2017, 05:51 PM
Liked: 2484
I use Acoustic Research, SVS soundpath, and Audioquest subwoofer cables throughout the house. The PR153 is the 25' Pro sub cable. The PR152 is 15'. The PR253 is still available Acoustic Research and is the most well made cable I have used. It is 25', has special locking RCA connectors, and is silver plated heavy guage copper. The MS252 is 15' but costs the same.
MS253 Audio RCA Mono Subwoofer Cable w/Y-Adaptor (25 feet) (Discontinued by Manufacturer) https://www.amazon.com/dp/B00008VSM8/
I think I have a spare PR152 w/Y if you want to buy one used, like new.
post #28537 of 30660 Old 04-14-2017, 05:54 PM
torii's Avatar
Quoted: 1484 Post(s)
Liked: 796
I picked up this audioquest sub cable on closeout/sale for 50 bucks
https://www.amazon.com/AudioQuest-Ir...audioquest+sub
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #28538 of 30660 Old 04-14-2017, 06:42 PM
Bruce Watson's Avatar
Quoted: 58 Post(s)
Liked: 56
i really need 5meter cable with y cable
you said Mediabridge didn't make a long Y sub cable
then what cable i must choose for y cable for FV15HP
Redco Audio will make any kind of cable you need. Last time I needed some other parts, I included a new set of subwoofer cables for my two LVX12s. Redco is easy to work with -- I recommend calling them and telling them about your application (the choices on the website can be overwhelming unless you know a whole lot about all the various cable options, because Redco carries hundreds of cables and terminations).
I wanted a very flexible cable -- most of the readymade cables are really stiff and won't lay flat. Since some of mine have to be visible, laying flat was a requirement for WAF. Redco's recommendation were a big improvement for me over the Mediabridge cables they replaced.
Bruce Watson is offline
post #28539 of 30660 Old 04-14-2017, 06:50 PM
torii's Avatar
Liked: 796
you could use a short y cable on the output of your avr and then just run regular sub cables...couldnt you?
torii is online now
post #28540 of 30660 Old 04-14-2017, 07:57 PM
DonH50's Avatar
Quoted: 2170 Post(s)
Liked: 1750
Yes. Use something like this: https://www.monoprice.com/product?p_id=6261 and whatever mono RCA cable you need.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #28541 of 30660 Old 04-14-2017, 08:51 PM
Timothy1180's Avatar
Quoted: 870 Post(s)
Liked: 266
Audioquest y adapter are $15-20. Great quality and just works. Look on Amazon. Get 1 female to 2 males. Than run 1 sub cable to sub. If you run more than two subs use 1 male to 2 females off avr. That'll run 4 subs. Which is the most I'd run off avr before you'll have limited voltage.
Look on Amazon. Better cables serpent is great y and so is audioquest.
Timothy1180 is offline
post #28542 of 30660 Old 04-14-2017, 09:05 PM
Liked: 2484
You want the Y at the sub not the AVR (unless you need to split for multiple subs).
post #28543 of 30660 Old 04-14-2017, 09:55 PM
Liked: 8
I just got the Rhythmic FV15HP and it is unbelievable. Here is my review link:
Rythmik FV15HP is Unbelievable
serith and citsur86 like this.
US AudioList is offline
post #28544 of 30660 Old 04-14-2017, 10:58 PM
serith's Avatar
Quoted: 68 Post(s)
Liked: 65
one of us, one of us...
jbl l100t3 (x2), rythmik fv15hp (x2), phase linear 700b, samsung ln52b750, sony str-db930
serith is offline
post #28545 of 30660 Old 04-15-2017, 10:21 AM
kyzer soze's Avatar
Quoted: 228 Post(s)
Liked: 152
Welcome to the club
Ascend Sierra 2's (LCR & side surrounds) + Klipsch atmos modules. 5.1.4 setup
Marantz AV7703
NAD M25
Rythmik FV15HP
kyzer soze is online now
post #28546 of 30660 Old 04-15-2017, 08:51 PM
mdameron's Avatar
Quoted: 77 Post(s)
Liked: 81
When will the LVX12 be back in stock?
mdameron is offline
post #28547 of 30660 Old 04-15-2017, 11:25 PM
Liked: 2484
I recently inquired and was told 3 months.
post #28548 of 30660 Old 04-16-2017, 11:03 PM
Liked: 0
I'm planning on building a DS1501 or DS1510 and have some questions.
First am I correct in assuming the DS1510 in a box built to the suggested specs on the website will be basically the same performance as the F15HP?
Second how much difference would there be between the DS1510 and DS1501 as far as spl and low end extension?
I understand that generally speaking higher power will give more dynamics, but I don't listen at high volumes (the highest I turn my volume to is -15 and usually its closer to -25 on my Denon AVR) but I am looking for low extension, I want to feel it! Would the 370 watt version have what I'm looking for, or is it worth the extra money for 230 more watts?
Sent from my E2306 using Tapatalk
mplett is offline
post #28549 of 30660 Old 04-17-2017, 12:20 PM
enricoclaudio's Avatar
Quoted: 1479 Post(s)
Liked: 1608
Sorry for the delay. Between Easter week and moving to a new apartment, I wasn't able to be on top of this matter. So right now the FV18 is up. Brian is finishing the FV25. We will add the quick guide for the amplifiers and subwoofer pictures later.
http://www.rythmikaudio.com/FV18.html
serith, dominguez1 and MrGrey like this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #28550 of 30660 Old 04-17-2017, 01:02 PM
serith's Avatar
Quoted: 68 Post(s)
Liked: 65
this may be a stupid question, but why isn't it called an fv18hp? what does the hp denote?
also, how well will this new 18 play with the existing ported 15's?
serith is offline
post #28551 of 30660 Old 04-17-2017, 01:28 PM
Liked: 1608
HP means High Power. Two years ago, we used to offer the FV15 (with A370PEQ3 amp) and the FV15HP (with H600PEQ3 amp) so we put the HP on the 600 watts version to differentiate the two models. The FV18 only comes with one amp option (HX1000XLR3) so it does not make sense to put the HP on the model, same for the new F18, FV25 and F28 models.
post #28552 of 30660 Old 04-17-2017, 03:30 PM
torii's Avatar
Liked: 796
is it possible to order a sub with the amp on a specific side/not the back? or will that affect the design/performance?
torii is online now
post #28553 of 30660 Old 04-17-2017, 08:51 PM
rcohen's Avatar
Quoted: 1386 Post(s)
Liked: 628
F18XHP, followed 5 years later by the F18XXHP, to later be eclipsed by the F18XXX, and finally the inevitable F18WTF?
You sure you don't want to let me name your models?
rcohen is offline
post #28554 of 30660 Old 04-17-2017, 09:02 PM
Liked: 2484
I suspect the answer from @Rythmik will be no as their cabinets are not built locally.
However, Jim Salk can build custom Rythmik subs: http://salksound.com/type.php?format=Subwoofer
post #28555 of 30660 Old 04-17-2017, 11:28 PM
gopala33's Avatar
Quoted: 169 Post(s)
i found ebay Acoustic Research PR-152
here photo
i already ordered
you is PR-153 i know PR-153 = 25 feet so PR-152 = 15 feet enough
can you check that box is Original ??
gopala33 is offline
post #28556 of 30660 Old 04-18-2017, 06:09 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
I chose not to add FV18 as there is no lower power version of 18" driver. We do have lower power version 15" model (for F25/FVX15) and therefore we need to use "HP" on 15" models.
In terms of mixing FV18 with FV15HP, it is doable with one port FV15HP as the phase shift on those two models (one port FV15HP and two ports FV18) below 40hz is almost identical. You can use 14hz with a particular damping on FV15HP one port, and then use 12hz or 14hz on FV18 2 ports with same damping and no rumble filter. The other port combination is not recommended due to phase difference.
Marc Alexander and torii like this.
Rythmik is offline
post #28557 of 30660 Old 04-18-2017, 06:12 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Hows fv18 performance compare to jtr cap 1400 and psa v1801?
sherr127 is offline
post #28558 of 30660 Old 04-18-2017, 06:22 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
FV18 with two ports open is tuned to 12.5hz (which we call it 12hz) and I don't believe the other two models do that (that can be explained by the 12.5hz CEA-2010 number). It is important to get the port tuning frequency low because in ported sub, the outputs of port and woofer are out-of-phase below port tuning frequency and in-phase above port tuning frequency. One may wonder why a sudden change in phase? In fact in follows the T/S models. So below the tuning frequency, you may see a lot of cone movement, but less output. It is because it is output is nagated by the port output. The result is that it has a 24db/oct roll-off vs a 12db/oct roll-off of a sealed sub.
Based on databass data on JTR 1400, it will have about 1-2db more output than FV18 at 20hz. But since the tuning frequency of FV18 is set to 12hz, FV18 will be 4-5db higher than JTR 1400 at 12.5hz.
dominguez1 and sherr127 like this.
Rythmik is offline
post #28559 of 30660 Old 04-18-2017, 06:57 AM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
^^ Hi Brian, is it safe to assume the FV18 FR will be +-3db between 12-200hz with LFE input? Thanks.
tvuong is online now
post #28560 of 30660 Old 04-18-2017, 07:02 AM
gwsat's Avatar
Quoted: 3375 Post(s)
Liked: 3919
Brian -- Thanks for the info you and Enrico have given us about the FV18. Could you or Enrico please post the FV18’s dimensions and an approximate date when production models will be available for shipping? Also, what would the price be for a pair of FV18s?
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Sonamp 2-1 2channel 100W power amp; Crestron Control System; 2 Rythmik FV18 subwoofers, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR; Roku Premiere+
gwsat is online now
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
