Official Rythmik Audio Subwoofer thread - Page 954 - AVS Forum | Home Theater Discussions And Reviews
 3555Likes
post #28591 of 28620 Old 04-20-2017, 08:59 AM
gwsat's Avatar
Quoted: 2712 Post(s)
Liked: 2998
Originally Posted by basshead81 View Post
The cabinet is much larger then the V1801, the amp is also much heavier. Driver might be a little heavier too.
The driver and amp is heavier then the JTR, plus JTR uses Baltic birch which is lighter then mdf.
As big as big as FV18s cabinets are (21"(W) x 33" (H )x 22"(D) - (23" D with grille and heatsink)), each one is still about the same size as my Hsu VTF-3 MK3 Turbo (33”(h) w/ Turbo X 17”(w) X 25”(d)), which they will be replacing. They are heavy, though. The shipping weight of each is 180 pounds, which is double the net weight of my old Hsu, less its Turbo unit.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
post #28592 of 28620 Old 04-20-2017, 09:03 AM
gwsat's Avatar
Liked: 2998
Originally Posted by enricoclaudio View Post
The DS1802 driver alone is 40 lb.
Enrico -- The FV18 spec page describes its driver as a DS1820 18" high excursion with custom sensing coil. How much does it weigh?
gwsat is offline
post #28593 of 28620 Old 04-20-2017, 09:15 AM
enricoclaudio's Avatar
Quoted: 1185 Post(s)
Liked: 1246
Sorry, that was a typo. The driver on FV18 is the DS1820 and it weights 40 lb.
gwsat likes this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #28594 of 28620 Old 04-21-2017, 06:36 PM
bear123's Avatar
Quoted: 1722 Post(s)
Liked: 2532
Originally Posted by imureh View Post
What makes this sub over 70lbs more than the V1801 and 50lbs more than the JTR 118HT?
Although it was mentioned the actual weight is more like 155 vs 180, remember that the V1801 is a VERY small 18" ported sub, so much less weight due to smaller cab. And the JTR is probably not any smaller but does use baltic birch rather than MDF, which is much lighter(but very strong).
bear123 is offline
post #28595 of 28620 Old 04-21-2017, 07:45 PM
Marc Alexander's Avatar
Quoted: 1464 Post(s)
Liked: 1169
Baltic birch doesn't require the bracing that MDF does. Vs properly braced MDF, there is no performance advantage to BB. Although it should be more durable over a lifetime. I would want baltic birch if I was travelling (PA) or worried about flooding.
*JTR: 17mm baltic birch 13-ply
*Rythmik: ¾" = 18mm MDF
*PSA: 1" = 25.4" MDF (both sides texture painted or veneered)
*Seaton: 1" = 25.4mm MDF (both sides veneered) (1.5" MDF for F18 faceplates), SS used BB in the past
Marc Alexander is offline
post #28596 of 28620 Old 04-21-2017, 08:54 PM
Liked: 1246
In fact, the front panel is 1-1/2" and the back panel is 1" MDF, even on E15HP, F15HP and FV15HP. 18mm MDF for sides, top, bottom and braces.
Marc Alexander and gwsat like this.
post #28597 of 28620 Old 04-21-2017, 09:24 PM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
ply wood i dont care what kind isnt as good as mdf for subs...I have made alot of plywood subs back in the day and they just dont sound as good imo.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is offline
post #28598 of 28620 Old 04-21-2017, 09:45 PM
tvuong's Avatar
Quoted: 1620 Post(s)
Liked: 953
Rythmik sub is heavier than other ID sub manufacturers mainly comes from its analog amp. I am guessing Rythmik amp would be ~15-25lbs versus ~4-6lbs from Speakerpower?
Marc Alexander likes this.
tvuong is offline
post #28599 of 28620 Old 04-21-2017, 10:02 PM
Liked: 1169
Nice, you should advertise this. Your website needs a serious overhaul. HTML5 instead of flash.
serith and Gary Bechtold like this.
post #28600 of 28620 Old 04-22-2017, 10:04 PM
serith's Avatar
Quoted: 61 Post(s)
Liked: 51
html5 & node.js
healthnut likes this.
jbl l100t3 (x2), rythmik fv15hp (x2), phase linear 700b, samsung ln52b750, sony str-db930
serith is offline
post #28601 of 28620 Old 04-22-2017, 10:45 PM
gopala33's Avatar
Quoted: 168 Post(s)
Originally Posted by torii View Post
who needs subs when towers get you this? not a bragging statement, just a statement...
i need radio shack where to buy
amazon.com unable to get
gopala33 is offline
post #28602 of 28620 Old 04-22-2017, 11:21 PM
Liked: 1169
Was this playing a test tone or a movie scene? SPL is the total sound under the curve so 108dB may not be representative of the bass capabilities of your towers, just the complete sound level. Grab a UMIK-1 and REW and we can get real measurements.
post #28603 of 28620 Old 04-23-2017, 08:04 AM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
yea, i was just listening to some music w/out subs...with subs on and during a movie star wars fight scene I get 118db. with rew get 110 at -5mv
since I usually listen in the mid 90's db my point is only really need the subs for movies or electric music. but of course the more subs the better
torii is offline
post #28604 of 28620 Old 04-23-2017, 08:15 AM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
dont think they sell this model anymore, its 20 years old. could probably use a phone app.
torii is offline
post #28605 of 28620 Old 04-23-2017, 08:21 AM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
I was just messing around around, nothing serious
this was my last rew with subs at -15 or so mv. I will break out rew again when I buy another rythmik sub, prob the 18.
torii is offline
post #28606 of 28620 Old 04-23-2017, 09:01 AM
gwsat's Avatar
Liked: 2998
I'll report here once I receive my FV18s and get them setup. Rythmik tells me that they will ship tomorrow via UPS and should get here in a couple of days.
torii likes this.
gwsat is offline
post #28607 of 28620 Old 04-23-2017, 10:10 AM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
anyone know how amps are measured in regards to gain setting? does max output on amp occur with gain at lowest/middle/highest?
just curious.
torii is offline
post #28608 of 28620 Old 04-23-2017, 02:00 PM
bear123's Avatar
Liked: 2532
ply wood i dont care what kind isnt as good as mdf for subs....
This just isn't true, unless you are talking about ease of finishing. MDF holds an advantage in this area. If you are referring to low quality or low grade plywood, I would have to agree with you. But the discussion was about high quality void free Baltic Birch, which is certainly not inferior in any acoustic way to MDF. It does have the advantage of being stronger and more durable, which may or may not matter to some or most.
chucky7 and Matt2026 like this.
bear123 is offline
post #28609 of 28620 Old 04-23-2017, 06:09 PM
stash64's Avatar
Quoted: 240 Post(s)
Liked: 87
Hi All,
I'm seriously considering purchasing a pair of F8's. I would like to be able to tuck a floor stand (for the front monitors) partly underneath the subwoofer but can't seem to find any information on what, if anything, Rythmik provides for floor mounts. I'm hoping to be able use my SVS Soundpath floor mounts.
Are there any F8 owners that can help fill in the blanks ? A picture or two would be great. Thanks.
Sean
stash64 is offline
post #28610 of 28620 Old Yesterday, 01:53 AM
Liked: 1169
just curious.
The max output of a sub is finite and can potentially occur at any gain setting.
Gain is not exactly a volume setting, which is why there is a gain adjustment to begin with. Different processors have different subwoofet out voltage characteristics. The gain adjustment matches the amplifiers gain structure to the source. Google amplifier gain matching for more eloquent explanations. There is probably one on the Rythmik website somewhere.
post #28611 of 28620 Old Yesterday, 12:52 PM
torii's Avatar
Quoted: 923 Post(s)
Liked: 484
it is due to the weight/mass differences. just my opinion based off my experiences. if you like plywood better so be it...I dont.
torii is offline
post #28612 of 28620 Old Yesterday, 01:13 PM
Liked: 1246
Originally Posted by stash64 View Post
Hi All,
Sean, the insert is M6. Also know that the F8 comes with rubber feet. But if you want to use your SVS Soundpatch feet then you can because they come with 4 x M6 screws.
post #28613 of 28620 Old Yesterday, 02:10 PM
Matt2026's Avatar
Quoted: 382 Post(s)
Liked: 14626
I used 1/2" 9 layer Finnish Baltic Plywood on a display shelf project. I routed in 1/8" wide lines for walnut inlay strips for the pattern which was inspired by a leaded glass window design. I was amazed that all of the points look great, no chipping to the naked eye. It was easy to finish with a clear rub on poly, not sure MDF would be any easier, maybe for some finishes.
My inclination is to think MDF "could" be better for sub encosure as it seems like it is a naturally more "dead" material but could entirely just be a figment of my imagination Never got the urge to do my own speaker cabinets, maybe in part because I don't have much of a working space
Really like my Rythmik F12 in 1100 cuft room
Name:	Deco Display Shelf(144).jpg
Regards, Ken (Retired)
9.1) Denon 4520CI; Samsung 55H8000 & BD-F7500; R&LRS/L/R SVS Ultra BS,
Ultra Center; FH & SS Polk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nakamichi RE-2, CDC-4A, CR7A, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #28614 of 28620 Old Yesterday, 03:32 PM
Davecraze's Avatar
Quoted: 163 Post(s)
Liked: 56
Hi guys,
As far as sealed subs go, it seems the L22 gets fairly little love around here, as compared to its 15 inch brothers.
My room is dedicated, sealed and 2900 cubic feet. 100% movies only.
I had a JTR Orbit Shifter LF, which was great (even though I ran it at like 15% of its capability - I had very bad nulls and could not reposition) and now I have two PSA v1500s. The PSA's are good subs also but I like to mix things up and wonder if sealed subs are for me.
I usually listen at modest levels - like -20 to -25 below reference.
I am intrigued by the servo subwoofers, I want to put them nearfield, I want the drivers to fire into my seating, and I have only 16"-17" of depth to work with.
Would three L22s nearfield be a good option? Am I wasting my time even exploring this?
DIY is not an option - no tools, no inclination and no talent.
Thanks guys.
Davecraze is offline
post #28615 of 28620 Old Yesterday, 04:35 PM
tvuong's Avatar
Liked: 953
^^ Are you planning to replace the Psa subs in that room or adding the L22's to the Psa? Mixing ported and sealed subs are challenging. 3 L22's directly behind you will be awesome for sure.
tvuong is offline
post #28616 of 28620 Old Yesterday, 04:56 PM
Liked: 1169
Originally Posted by Davecraze View Post
Hi guys,
Thanks guys.
That would be sweet but the ported subs right behind the MLP will be even better. Try it out.
post #28617 of 28620 Old Yesterday, 05:15 PM
Davecraze's Avatar
Quoted: 163 Post(s)
Liked: 56
The PSA subs would be replaced with three L22s.
I could also maybe one L22 and one F25 (I have more space in the nearfield location behind one seating area). I feel that three L22s may be better than one L22 and one F25, but I have no personal knowledge to back that up.
post #28618 of 28620 Old Yesterday, 07:10 PM
tvuong's Avatar
Liked: 953
^^ I am sure either options would be excellent. Another option is to keep your psa subs upfront and add 2-3 of the Behringer 1200D MBMs (~ 14" cube) directly behind your seatings. This option is fairly cheap and could be the ticket to bass nirvana. For more information about MBM, read post #1 of this link at the minimum.
Nearfield Ported MBM for Increased Mid-Bass Tactile Response
tvuong is offline
post #28619 of 28620 Old Yesterday, 07:40 PM
Davecraze's Avatar
Quoted: 163 Post(s)
Liked: 56
Will check it out. The PSA V1500s are both near field (almost very near field - I almost sit on top of them), so I get pretty good tactile response right now. I am sure that can be improved with some dedicated MBMs.
post #28620 of 28620 Old Today, 12:54 AM
sherr127's Avatar
Quoted: 56 Post(s)
Any picture of fv15hp and fv25 driver side by side?
sherr127 is online now
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
