Buzzing Noise from Warfedale Powercube 12A - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-07-2010, 07:52 PM - Thread Starter
melchionda's Avatar
I've had a Warfedale Powercube 12A for about 8 or 9 years. Its worked fine until a few months ago I woke up to the sound of a loud buzzing noise comming from the Sub. Its not feedback like you would hear from a bad ground, its sounds different and is much louder. I've been using a Pioneer VSXD-912 Reciever with this sub and have connected it with the Sub out jack on the Reciever. However I dont think that the noise has anything to do with the Reciever as the noise happens regardless of whether or not the Sub is connected to the Reciever. All I have to do is plug the Sub in and turn it on and it immediately makes the noise.
Any ideas?
melchionda is offline
post #2 of 2 Old 02-07-2010, 08:11 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
A friend of mine had a similar buzz problem from their little 8" Definitive Technology sub--no connection needed. Replaced the amp driver module ($60 board) and all is well. Was not able to trace which component went south--I couldn't get the schematic.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
