VTF 2 mk 3 quit working? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 39 Old 02-12-2010, 09:03 PM - Thread Starter
epsilon72's Avatar
Oh crap!
I started up Serenity today only to notice that I was getting absolutely nothing from the sub. Lo and behold, I check the back of it and it doesn't seem to be powered on at all! The little light that is either red or green doesn't turn on at all.
Could it be that the electronics or the amp has died in this thing? I haven't used it all that often and it's only a little over 2 years old.....which means the electronics might be out of warranty.
What should I do? My system sounds lifeless without it...does HSU let you buy replacement parts if need be?
epsilon72 is offline
post #2 of 39 Old 02-12-2010, 09:09 PM
Spur Darren's Avatar
Originally Posted by epsilon72 View Post
Oh crap!
Did you double check all your cables? Did you check the fuse?
Spur Darren is offline
post #3 of 39 Old 02-12-2010, 09:12 PM - Thread Starter
epsilon72's Avatar
I did double check my cables. I don't know where the fuse is on it though....I'm guessing that's not the volt switch? Where would the fuse be?
edit: I found the fuse, I can turn it and it pops out, but when I put it back in and plug everything in, I still get no power. It looks like it's still good too, the little metal wire in it doesn't look like there's anything wrong with it.
post #4 of 39 Old 02-12-2010, 09:35 PM
Wid
Wid's Avatar
Is it on the same breaker as the rest of the system?
Rick
Wid is offline
post #5 of 39 Old 02-12-2010, 09:37 PM - Thread Starter
epsilon72's Avatar
Yeah...and everything else is getting power just fine.
post #6 of 39 Old 02-12-2010, 10:41 PM
Try unplugging it for 10- 15 minutes then plugging it back in.
post #7 of 39 Old 02-12-2010, 11:25 PM - Thread Starter
epsilon72's Avatar
Well, it's been unplugged for more than an hour and I just tried it...nothing
I've had it for all this time and have not once opened it up...are these things supposed to be cleaned out (dust?) every once in a while, or are they fine without that?
The sub worked fine a week ago, and has been unplugged since then. I had just barely plugged it in today when it died - I wasn't playing anything loud on it or anything. It was completely cool too.
post #8 of 39 Old 02-13-2010, 07:20 AM
Hsu is supposed to have great customer service. I would contact them and post the problem on the forums on the Hsu site. Pete is always on there answering questions.
post #9 of 39 Old 02-13-2010, 09:37 AM - Thread Starter
epsilon72's Avatar
I contacted them and they already emailed me telling me that I could send it in and get it repaired/replaced...it's out of warranty so it'll be $80-$120 plus shipping, but that's better than having a dead sub!
It would be nice if it was something obvious and easily fixable...I have very basic electronics and soldering experience...I doubt though that I'd be able to see what the problem is.
post #10 of 39 Old 02-13-2010, 09:59 AM
Wid
Wid's Avatar
It seems strange the sub was not working when it had been unplugged. I hate to ask but are you certain the power cable is secure on the back of the sub?
Rick
Wid is offline
post #11 of 39 Old 02-13-2010, 10:16 AM
Bunga99's Avatar
Liked: 39
Just for giggles, try plugging the sub on a seperate outlet all together and see if that works. Sounds crazy but I had my laptop stop charging from the bottom connection of the same outlet. I thought something was wrong with the laptop but accidentally pulled it, plugged it into into the top section of the outlet and worked fine. Try moving it to another outlet and see if anything changes.
Bunga99 is offline
post #12 of 39 Old 02-13-2010, 10:17 AM - Thread Starter
epsilon72's Avatar
Should I worry about shock hazards when taking the amplifier section out?
First rule of troubleshooting: Make sure it's plugged in
Yeah, it's secure as I can get it...I've tried more than one power cable, making sure it was firmly pushed in, tried jiggling it a little to see if I get any response...
I don't know. It was working for a few seconds after I plugged it in and turned it on, before it died yesterday. Something must've went wrong in that time, maybe?
@Bunga99: I've tried it plugged into a surge protector (everything else that is plugged into it is working) and I've tried the other connection on the same outlet. I guess I could try a whole other outlet altogether, but I'm not exactly hopeful of it working
post #13 of 39 Old 02-13-2010, 04:02 PM
I would see if Hsu is willing to let you just send the amp in for service and save on shipping.
post #14 of 39 Old 02-13-2010, 04:05 PM - Thread Starter
epsilon72's Avatar
Yeah, they told me to disconnect the amp from the rest of the sub and just send that. Thank God...I'd much rather pay for shipping for the amp than for the whole sub
post #15 of 39 Old 02-16-2010, 01:47 PM - Thread Starter
epsilon72's Avatar
Well, I'm shipping it off to HSU in California today to get it looked at. So far the customer service has been great. One of their techs called me personally and talked to me about it.
I'll cross my fingers - hopefully my sub won't be absent from my setup for too long!
post #16 of 39 Old 02-25-2010, 07:49 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
Let us know what the diagnosis is. I just ordered one earlier today.
Spaceman is offline
post #17 of 39 Old 02-27-2010, 07:35 PM - Thread Starter
epsilon72's Avatar
They told me that it didn't show any signs of abuse or anything, but they replaced a couple components, including a chip. I got it back yesterday and it works just fine again.
Also, I don't think I gave the correct age of the sub earlier in this thread - it turns out it's just over 3 years old.
post #18 of 39 Old 02-28-2010, 01:51 AM
dondino's Avatar
So wait, you took the fuse out and put the same fuse back in? If the fuse is bad then it still won't work by popping it out and putting it back in. I've seen bad fuses where that little metal wire looks perfectly good. I would have tried a new fuse? I don't know, I've never replaced a sub fuse before but I assume it's something you can get from ratshack? Yikes, if so, they may have just replaced a $3 fuse.
Don
ala Yoda...
"Tweeters". Heh! "Treble". Heh! A basshead craves not these things! ...
dondino is offline
post #19 of 39 Old 02-28-2010, 07:04 AM
gotchaforce's Avatar
holy crap i cant believe ive had my vtf2mk3 for over 3 years now! time for a new sub i think
gotchaforce is offline
post #20 of 39 Old 02-28-2010, 08:14 AM
Don
He did say the fuse looked fine. If it was a bad fuse it would be easy to see it was bad.
post #21 of 39 Old 02-28-2010, 08:42 AM
Quoted: 1394 Post(s)
Liked: 589
I've owned 3 different subs over the last 10 years and have had the amps go out on all of them. I'm starting to think that this is just part of the experience of having subwoofers. I do not play them particularly loud but I do put a lot of hours on them.
JimP is offline
post #22 of 39 Old 02-28-2010, 08:56 AM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
JimP,
What subs needed repair (if you don't mind reporting) ?
Charlie
chashint is offline
post #23 of 39 Old 02-28-2010, 08:57 AM
dondino's Avatar
All I'm saying is he said he did nothing but a visual inspection of the fuse and came to the conclusion it was still good. I've seen fuses that "look" fine but are not. Personally, I would have spent the few bucks to rule that out before going through all the rest he went through.
ala Yoda...
dondino is offline
post #24 of 39 Old 02-28-2010, 11:28 AM
cyberbri's Avatar
Liked: 53
You've had a 2.3 for over 3 years? I don't think they've been out that long. I have a 3.2 that I got just about 3 years ago, and the .3s weren't out yet. I got it right when we moved into our new rental house. Unless we've been in this house almost 4 years... Time sure flies!
cyberbri is offline
post #25 of 39 Old 02-28-2010, 11:47 AM
There is a post in the hsu forums that is titled A New era for Hsu research and has the .3's in 06
post #26 of 39 Old 02-28-2010, 11:59 AM
cyberbri's Avatar
Liked: 53
Wow. Haha.
I think I got my 3.2 right before the HO came out. I guess it's been about 3.5 years, because we moved to the house in the spring time, maybe April~May.
cyberbri is offline
post #27 of 39 Old 03-27-2010, 01:14 PM
nweibley's Avatar
Timely thread.
Interesting my HSU VTF2 MK 3 amp just started eating fuses this week too. I purchased it in Oct 2007... just out of the 2 year electronics warranty. In a way it feels all too convenient.
Wish it weren't so but I sent HSU an email asking if it will void my warranty on the driver if I look at it myself. 5th year electrical engineering student here, I have a funny feeling it's going to be an easy fix.
I think next time I'll be getting something different like a SVS. Kinda frustrated.
nweibley is offline
post #28 of 39 Old 03-27-2010, 02:29 PM
cyberbri's Avatar
Liked: 53
Originally Posted by nweibley View Post
Timely thread.
Yes, it's a conspiracy. All HSU subs are programmed to start failing after 2 years...
cyberbri is offline
post #29 of 39 Old 03-27-2010, 03:06 PM
Joe Piz's Avatar
So...I am guessing you got it back. How do you feel HSU handled it? I am thinking about this model, but am a little concerned, sounds like at least a few people here experienced very similar problems.
Joe Piz is offline
post #30 of 39 Old 03-29-2010, 07:21 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Several companies that are highly regarded for subwoofers (with long threads on this forum) have had a few amplifiers fail (either within and outside warranty periods). With another company's subwoofers and a similar statement about the possibility of amplifier failure, I spent time reading a very long thread. The proportion of amplifier failures appeared very small.
It is the nature of this forum that individuals who have had amplifier failures will make comments at a much higher proportion than others.
wwinkler is offline
