best sub under 400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 04-19-2010, 10:18 AM - Thread Starter
alejopelaez's Avatar
I need to buy the best sub that I can get for 400 or less. Mostly for blu rays.
I have a 1019 Pio Receiver
Pro monitor 800 (definitive Technology) for fronts.
Pro center 1000 (definitive Technology) for Center
HDT HD r65 for Surrounds.
alejopelaez is offline
post #2 of 23 Old 04-19-2010, 07:09 PM
JSchulte's Avatar
Elemental Designs has several nice subwoofers in the $400 and under range and I believe the shipping is free. HSU also has the STF series which can be had for sub-$400.
JSchulte is offline
post #3 of 23 Old 04-20-2010, 08:14 AM
Quoted: 73 Post(s)
Liked: 112
eD and HSU are your best bet.
rnatalli is offline
post #4 of 23 Old 04-20-2010, 08:49 AM
nith's Avatar
Cambridge Soundworks P300HD. Tri-oppose designed woofers (6-6.5 woofers).
It rated at 25-200Hz. CNET says it sounds as good as the Bowers & Wilkins PV1.
$399 + Free shipping; additional $50 off with coupon SPTAKE50.
http://store.cambridgesoundworks.com...B00345HIHQ.htm
nith is offline
post #5 of 23 Old 04-20-2010, 03:03 PM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
The Hsu STF-2 is ~$391 (includes shipping).
wwinkler is offline
post #6 of 23 Old 04-20-2010, 03:06 PM
Johnnycloud's Avatar
I use the HSU STF-1 in an 1800 cu.ft. room and it is great, plenty of power for the room size. I use the 1019 also.
Johnnycloud is offline
post #7 of 23 Old 04-21-2010, 10:55 AM
Artman22's Avatar
Quoted: 374 Post(s)
Liked: 183
Would anyone put the Acoustech pl-200 in this category
PSN: Artman22
Xbox live: Artman22
Artman22 is offline
post #8 of 23 Old 04-21-2010, 03:18 PM
N1GHTRA1N's Avatar
It might be the best under $300.
N1GHTRA1N is offline
post #9 of 23 Old 04-21-2010, 09:10 PM
Artman22's Avatar
Quoted: 374 Post(s)
Liked: 183
How much better would the stf-2 be compared to the pl-200? I know musicaly it's better, but overall?
PSN: Artman22
Xbox live: Artman22
Artman22 is offline
post #10 of 23 Old 04-22-2010, 07:49 AM
N1GHTRA1N's Avatar
Other than Music I don't know that it is better and I can't really say the music would be better either. The PL-200 has a lower bass response level and more power overall plus a 12" speaker which has its advantages. Just looking at specs I'd say the PL-200 is the winner, looking at every thing I've read I'd say they are pretty even but the PL-200 should be cheaper.
post #11 of 23 Old 04-22-2010, 08:12 AM - Thread Starter
After going back and forward I have come to the conclusion that eD might be the best bang for the buck. So the A2-300 would be the choice. Now my question is if I can increase my budget from 400 to 600 would the A3-300 would be that much better over the A2-300? Or is there any other sub in the 600 that is that much better than the A2-300?
post #12 of 23 Old 04-22-2010, 09:58 AM
Nino1919's Avatar
I would say Ed-A3-300 or SVS PB NSD 12... Both have similar specs and great reputations.
Nino1919 is offline
post #13 of 23 Old 04-22-2010, 10:09 AM
signmastr's Avatar
Quoted: 12 Post(s)
SVS is well over his budget with shipping. eD if you can stand the wait. Shop used?
signmastr is offline
post #14 of 23 Old 04-23-2010, 08:31 AM - Thread Starter
Is the VTF-2 MK 3 in the same league with these two.
Is the HSU VTF-2 MK 3 better than the A3-300??
post #15 of 23 Old 04-23-2010, 08:46 AM
nith's Avatar
If you:
1. have tools (jigsaw, router) or borrow from neighbor(s).
2. have $600 budget
3. have free time to kick air
4. D.I.Y.
a. Build a Rythmik CI for accurate bass.
b. Build a Elegance Acoustics 15" + 2-18" PR for monster SPL.
nith is offline
post #16 of 23 Old 04-23-2010, 09:11 AM
Snowmanick's Avatar
Quoted: 247 Post(s)
Liked: 349
$400-$600, I'd look at the SVS PB12-NSD. They have one B-Stock right now. Solid sub, solid company, should be able to satisfy most people for years. Just so long as you don't mind it being black.
The other option I'd look at would be the Hsu VTF 2 MKIII in black. Hsu's are solid, good sounding products and could keep you happy for years as well.
Toss a coin.
I'd lean towards the SVS, but mainly due to familiarity with the company and product.
~Nick
"Every loaf of bread is a tragic tale of grains that could've become beer.......but didn't...."
"If it works the first time, it's not high end." ~ Harry Pearson
Snowmanick is offline
post #17 of 23 Old 04-23-2010, 09:14 AM
Stryprod's Avatar
Absolutely in the same league as those two and arguably better depending on listening habits and preferences. The coolest aspect of the VTF-2 is the ability to go between tuning the sub towards music, or lower extension.
Not sure what the warranty is on the e.d. but the HSU comes with a 7 year warranty on the driver. The VTF-2 MK 3 is also $40 off right now, approx $510 (w/o shipping). The biggest reason I am getting one though, is the fact that their shop is 5 minutes from my house. The weights a lot!
There are just so many factors to weight when getting one... oh and if you go with the A2-300 which is a VERY well respected sub, you will have to weight approx. a month or so to get it since it's made to order.
craigsubs ranking:
Hsu VTF-2 Mark III w/o Turbo ($510 ID): 86 points (40-46)
Elemental Designs A2-300 ($415 ID/SI): 83 points (44-39)
So "technically" most would rank it a little higher but the cost per performance if going by craigsubs metric is $5 a point for the A2-300 versus $5.90 for the VTF-2
A lot would argue that the A2-300 is a better bang for the buck, a lot would argue the VTF-2 is better all around... confusing indeed!
Stryprod is offline
post #18 of 23 Old 04-23-2010, 09:18 AM
Stryprod's Avatar
SVS is a GREAT sub too, but if you factor in shipping you are going to go over that $600 mark easily. Great sub though too!
Stryprod is offline
post #19 of 23 Old 04-23-2010, 09:21 AM
Snowmanick's Avatar
Quoted: 247 Post(s)
Liked: 349
Depends on location. As mentioned, one available as b-stock right now, running their shipping estimator to my address it came out right at the $600 mark. Outside of the b-stock, then yes, the sub itself is $599 MSRP + shipping.
~Nick
post #20 of 23 Old 04-23-2010, 09:33 AM - Thread Starter
craigsubs ranking:
Maybe I asked the question wrong? I was trying to compare the HSU VTF-2 to the A3-300 not the A2-300. Which one is better or more bang for the buck. I'm 85% movies 15% music
post #21 of 23 Old 04-23-2010, 10:49 AM
Quoted: 73 Post(s)
Liked: 112
Both are excellent. In general, I find HSU subs a hair more articulate and eD subs will have a hair more authority down low.
rnatalli is offline
post #22 of 23 Old 04-23-2010, 10:53 AM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
How low can the VTF-2 MK 3 go?
I believe the eD A2-300 is 18Hz.
JChin is offline
post #23 of 23 Old 04-23-2010, 12:09 PM
HammerDE's Avatar
Click on the Hsu advertised link at top of page and then select the VTF-2 April Special. The Specs are listed.
HammerDE is offline
