Official JTR Orbit Shifter Subwoofer Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 212Likes
post #31 of 1653 Old 05-06-2010, 11:08 AM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Originally Posted by bodhisafa View Post
How is this design capable of these enormous numbers if the amp in only puuting out half of the stated power numbers based on the limits of a circuit. Jeff calculated everything of the 4000Watt estimate but if the amp is limited to just half, then those numbers are not realistic, is this correct or am I missing something?
Without getting into what circuits can provide without being tripped, even if the amp can only deliver 2000w that's only 3db less than the stated numbers. So only 142db >25hz. Yeah that just won't do.
cmryan821 is offline
post #32 of 1653 Old 05-06-2010, 11:27 AM
Mark Seaton's Avatar
Quoted: 682 Post(s)
Liked: 1841
Originally Posted by Sphinx360 View Post
4000Wrms? But isn't the limit from my typical 120V 15A AC line about 1800Wrms based on a 100% efficient amp?
Can you produce an honest 4000W sine wave for 2 hrs off a single 20A, 120V home circuit? No. Do we ever do this in audio playback? Nope.
If you have the capability to deliver 4000W for a useful duration ranging from 15s to a few minutes, no audio signal you will want to listen to with peaks of 4000W will have an average power of more than 2000W, and more likely less than 500-700W. Circuit breakers are there largely to protect wires from overheating and to protect from fault (short to ground) conditions. They react on a much longer time average than peak audio signals. MANY audio enthusiasts operate systems with 6000W or more on a 20A circuit without popping breakers.
If you are using these in the interest of good sound quality you are generally more than safe if you figure circuit loading at 1/3rd-1/6th maximum audio power, with 1/4 being a good target. If you are running subwoofers very hard for dance use and regularly hitting limiters, clipping amps and running compressed signals, 1/2 maximum audio power is generally plenty safe.
The 4kW amplifier Jeff is using is the same amplifier I'm using in my Terraform XL and some other future products. I've been testing prototypes of the amp for more than 6 months. I see no problem with normal use of a pair of these 4kW amplifiers on a single 20A home circuit.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #33 of 1653 Old 05-06-2010, 11:58 AM
bodhisafa's Avatar
Gentlemen, thank you for the response(s) to my question regarding amp power and circuit limitation. It was just a question needing some clarification, not and attack on JTR, Iam an owner.
bodhisafa is offline
post #34 of 1653 Old 05-06-2010, 12:14 PM - Thread Starter
RMK!'s Avatar
Quoted: 1697 Post(s)
Liked: 1627
Actually it was a reasonable question that led to a good technical explanation (not mine ). A teaching moment if you will .
smit1001 likes this.
Anxiety is contagious, please keep yours to yourself.
RMK! is online now
post #35 of 1653 Old 05-06-2010, 12:25 PM
Decadent_Spectre's Avatar
Quoted: 379 Post(s)
Liked: 179
RMK! Will you be doing max SPL measurements? Please
Decadent_Spectre is offline
post #36 of 1653 Old 05-06-2010, 12:41 PM - Thread Starter
RMK!'s Avatar
Liked: 1627
With Jeff P. here I don't think I will have any choice in the matter .
Hopefully, he will get his "turn it up" jones satisfied before the Meet. Not everyone attending (myself included) likes 130db .
Reminds me, I need to warn the neighborhood .
RMK! is online now
post #37 of 1653 Old 05-12-2010, 07:01 AM
misterkit's Avatar
So.... whats the news on this lately? Pictures?
misterkit is offline
post #38 of 1653 Old 05-12-2010, 07:09 AM
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1306
I know what you mean, I have played 130 db's at my LP position and your ears pressurize so much that it feels that you are under water. It gets scary and I backed it off. Forget about high frequencies as that will cause damage.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is online now
post #39 of 1653 Old 05-12-2010, 08:37 AM
Jeff Permanian's Avatar
Quoted: 817 Post(s)
Liked: 1745
The first prototype should be finished within the next couple weeks.
Jeff Permanian is offline
post #40 of 1653 Old 05-13-2010, 07:03 AM - Thread Starter
RMK!'s Avatar
Liked: 1627
The problem with having that much audio horsepower is the temptation to use it.
Now that is some good news.
RMK! is online now
post #41 of 1653 Old 05-13-2010, 10:16 AM
misterkit's Avatar
Will there be an option to use an external amp if we wanted to?
post #42 of 1653 Old 05-23-2010, 11:26 AM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
Orbit Shifter LF subwoofer uses a 68 lbs, 18-inch driver news from JTR forum!
ZivkoF is offline
post #43 of 1653 Old 05-23-2010, 04:35 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 1060 Post(s)
Liked: 820
Guys, let's start up a new thread once these hit the street per AVS rules.
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #44 of 1653 Old 06-11-2010, 01:34 AM - Thread Starter
RMK!'s Avatar
Liked: 1627
The first Orbit Shifter pair has landed in California and setup starts tomorrow. I will post initial impressions and some pics then.
I'm hosting a GTG on Saturday and hope that some others will also comment on this unique commercial sub design. Did I mention they are LARGE?
RMK! is online now
post #45 of 1653 Old 06-11-2010, 07:28 AM
bukiwhitey's Avatar
Can't wait to read your feedback.
bukiwhitey is offline
post #46 of 1653 Old 06-11-2010, 07:35 AM
Leffe67's Avatar
Too bad I am on the wrong coast... I would love to witness the official unleashing of the Orbit Shifters. As a precaution, you may want to notify your local seismology office of your plans...
Have fun! Take lots of pictures, and maybe a video.
Leffe67 is offline
post #47 of 1653 Old 06-11-2010, 08:27 AM
InPhase's Avatar
Looking forward to it Rob!
InPhase is offline
post #48 of 1653 Old 06-11-2010, 04:33 PM - Thread Starter
RMK!'s Avatar
Liked: 1627
OK here are some pics. We had a power cord issue (don't ask) and Jeff is just completing a 4hr round trip drive for a replacement. One OS is working and after running a quick Audyssey the results are very impressive . Much dialing in to do but so far so good.
With Grill
Big Mouth ()
Amp
That is all (for now)
RMK! is online now
post #49 of 1653 Old 06-11-2010, 06:18 PM
misterkit's Avatar
very nice.... very nice indeed.
post #50 of 1653 Old 06-11-2010, 07:33 PM
Hudda's Avatar
Liked: 24
Looks great Rob. I'm eager to hear your impressions!
Chris
Hudda is offline
post #51 of 1653 Old 06-11-2010, 08:05 PM
MIkeDuke's Avatar
Quoted: 534 Post(s)
Liked: 211
Stated simply, COOL.
It ain't easy being green.
My System
MIkeDuke is offline
post #52 of 1653 Old 06-11-2010, 09:47 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5029
Scott Simonian is offline
post #53 of 1653 Old 06-12-2010, 01:09 AM
vraxoin's Avatar
Quoted: 13 Post(s)
Liked: 36
Eeesh! We have enough problems with scientists attempting to suck the Earth into a black hole with the Large Hadron Collider. Now you reckless sickos are going to unleash not one, but TWO Orbit Shifters for your evil weekend experiments?! I hope you are proud of yourselves, planet wreckers!
vraxoin is offline
post #54 of 1653 Old 06-12-2010, 06:47 AM - Thread Starter
RMK!'s Avatar
Liked: 1627
Sorry flat earther …
Jeff Meier (Accucal) spent 6 hours calibrating the projector and audio last night with Jeff P and I carefully observing the process. The result was a perfectly calibrated RS35 and a nice flat audio FR in the room. Not being a big fan of Audyssey, Jeff M used the manual EQ of my Integra SSP (DHC-80.1) and his very nice measuring gear to set the levels and EQ points for the system. Mr. Meier is very knowledgeable and a consummate professional who provides his customers with a nice bound copy with all of the settings and video calibration results at the end of the process.
On the audio side, I think he was a little surprised but the size and type of subwoofer that was dealing with last night. He see’s 2-300 systems per year and so is seldom surprised but the OS’s along with a few select others are breaking new ground (and drywall) .
We are planning to run an Audyssey calibration this morning just for comparison purposes.
Science marches on …
RMK! is online now
post #55 of 1653 Old 06-12-2010, 07:07 AM
MIkeDuke's Avatar
Quoted: 534 Post(s)
Liked: 211
Great update. I agree with you on Jeff %100. Also, even though my system and room are small he also indicated that what ever I did, I did it the right way. He said that I should really not change a thing becasue it is my room that is the limiting factor. Even though my surrounds don't "match" he felt that it was not a distraction. He also felt that EQ, which I don't have, is the way to go. Glad that the calibration worked out for you. Now you can watch all your movies again for the first time.
My System
MIkeDuke is offline
post #56 of 1653 Old 06-12-2010, 07:54 AM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Diggin the setup as always a very clean implementation. Are you still crossing the Triple 12s at 60hz or are you letting those Orbit Shifters flex a little more?
gpmbc is online now
post #57 of 1653 Old 06-12-2010, 08:19 AM
drhack's Avatar
RMK - the subs look menacing! Congrats on the upgrade.
Do you have sound proofing for your ht? Is it a distraction for the rest of the house with the monster subs/spkrs?
President Muffley: Gentlemen, you can't fight in here! This is the War Room!!
drhack is offline
post #58 of 1653 Old 06-12-2010, 05:08 PM
vraxoin's Avatar
Quoted: 13 Post(s)
Liked: 36
Sorry flat earther
Hey, I like my Earth like I like my frequency response!
Now, can has more updates, pictures, body count, pls?
vraxoin is offline
post #59 of 1653 Old 06-12-2010, 06:24 PM
misterkit's Avatar
+1..... cmon already.
post #60 of 1653 Old 06-12-2010, 10:19 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Jeff Meier (UMR at AVS) (jeff@accucalhd.com) spent 6 hours calibrating the projector and audio last night with Jeff P and I carefully observing the process.
Thanks for your calibration report. I've included it in the front projection (Post#1) lists that are linked at the bottom of my post.
htwaits is offline
Jtr
