Question about LFE port and 2 RCA ports on Sub. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-08-2010, 09:02 AM - Thread Starter
rob316's Avatar
Guys I have noticed that not all subs come with and LFE port just 2 standard RCA jacks. Is it possible to still use the LFE port on your receiver to a sub that does not have one?
rob316 is offline
post #2 of 6 Old 05-08-2010, 10:13 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
yes
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 6 Old 05-08-2010, 11:11 AM - Thread Starter
rob316's Avatar
Originally Posted by flyng_fool View Post
yes
How would I go about doing that flyng?
rob316 is offline
post #4 of 6 Old 05-08-2010, 11:22 AM
jesyjames's Avatar
Quoted: 16 Post(s)
Just run the cord from the lfe/subwoofer out into which ever input you choose on the sub. Doesn't usually matter.
jesyjames is offline
post #5 of 6 Old 05-08-2010, 12:03 PM
Truls's Avatar
Agree, but the thumb of rule is that you use the LEFT innput, not that it matters on a sub anyway. If you use a Y-ledd/splitter to gain innput on both LEFT and RIGHt you can espect a 3db gain on the signal. But thats totaly useless sincemost subs has a level controll and most recivers has a level controll as well.
Truls is offline
post #6 of 6 Old 05-09-2010, 12:29 PM
Erik Tracy's Avatar
I'm doing this right now because the LFE jack on my sub doesn't work properly.
I'm running a sub cable from the AVR sub out to the left line level RCA jack on my sub.
If you are using bass management from the AVR, then be sure to turn the xover control on the back of your sub all the way up if you are connected to one of the RCA line level jacks so that you don't have two crossover frequencies 'doubling' on top of each other (the sub and the avr).
Erik Tracy is offline
