How to hook up a BIC F-12, complete newb question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-12-2010, 03:36 PM - Thread Starter
dukefett's Avatar
Hi I just bought this BIC F-12 along with a new receiver (Onkyo TX-SR608) and Polk Monitor 70/40 Speakers for my new apartment, I haven't moved in yet so I'm trying to order everything now so when I get there I can just get going.
From what I've read you use an RCA cable for the sub, on the picture in the back of the there's several connections visible. So now I'm not sure how I should be connecting this thing up.
Thanks a lot, pic attached.
dukefett is offline
post #2 of 7 Old 05-12-2010, 04:25 PM
batpig's Avatar
Quoted: 3707 Post(s)
Liked: 3581
there are several connections but only one of them is RCA
make sure the RCA cable you buy is a "digital coax / subwoofer" cable with a 75ohm spec like this one, not just your standard red/white RCA: http://www.monoprice.com/products/pr...seq=1&format=2
then hook it up from the SUB OUT of the 608 to the input on the sub. Disable the crossover on the sub (set the switch to the "Dolby Digital 5.1/6.1/7.1" position), turn the volume to 1/2 way, and run Audyssey... then you are good to go.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #3 of 7 Old 05-12-2010, 07:51 PM - Thread Starter
dukefett's Avatar
Ok awesome thanks a lot, that's exactly what I was looking for. I had a cart full of stuff ready to go at Monoprice so thanks a lot for the link.
dukefett is offline
post #4 of 7 Old 05-12-2010, 07:55 PM - Thread Starter
dukefett's Avatar
Another quick question, is there any danger for quality vs. length of cable for this type like with speaker wire? I'm not sure where I want to place the sub yet, I'll do some testing for that, so I'm thinking of getting the 25' just in case.
dukefett is offline
post #5 of 7 Old 05-12-2010, 07:59 PM
slopokdave's Avatar
Quoted: 28 Post(s)
You are fine with 25feet. Subwoofer cables often are offered at lengths like 25 feet because of room placement.
slopokdave is offline
post #6 of 7 Old 06-06-2010, 04:43 PM
wilmer007's Avatar
Just wanted to thank you guys as i'm buying the same as OP and had the same question so i didn't have to make another thread and found this through google. Thanks Guys
wilmer007 is offline
post #7 of 7 Old 06-07-2010, 06:47 AM
XARiUS's Avatar
Good luck with your new setup! I have exactly the same gear, but my Onkyo is the 606. I'm holding out on the hopefully soon to-be-announced 708. =)
X
XARiUS is offline
