NEW MFW-15 amps (May 2010) *pics* - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
Old 08-22-2010, 07:51 PM
Stereodude's Avatar
Quoted: 3090 Post(s)
Liked: 2238
Originally Posted by Pure-Evil View Post
Panties too tight kev?
You'd better be careful of he's going to wrap those panties really tightly around your neck.
Stereodude is offline
Old 08-22-2010, 09:46 PM
jarablue's Avatar
Quoted: 13 Post(s)
No...on my pioneer sc-05 receiver, it uses ICE AMPs. If that is what you mean. But I just have the normal A stock MFW15 in wood grain finish.
Any luck?
Just a quick question......does anyone know what amps are in the MFW15 from the purchase time frame of February of this year? That is when I bought mine.
Edit: Realizing what you said, I do not use an external amp....only the ones built into my receiver. Which are ICE AMPs for the pioneer SC-05.
jarablue is offline
Old 08-22-2010, 10:20 PM
Pure-Evil's Avatar
Liked: 150
Hahaha. Somehow I doubt that. But it was meant in jest
Pure-Evil is offline
Old 08-23-2010, 12:01 AM
HybridHB's Avatar
My MFW 15 has developed a hum, and i went to the AV123 site to see that they are closing shop. Sigh, what now?
HybridHB is offline
Old 08-23-2010, 01:17 AM
Quoted: 1393 Post(s)
Liked: 587
HybridHB,
Had to change this post as I realized I was giving you some bad advice. lol
Since the business has closed, its very unlikely they'll do anything to provide you with a replacement amp.
With that said, you could get on the waiting list for an amp/driver upgrade from Sandbagger for something around $700 or just say the heck with it and find another sub.
The problem with just buying an amp from parts express and hobbling together a way to make it work is that its possible that the driver is damaging the amp and after a short time the new amp will also fail.
JimP is online now
Old 08-23-2010, 01:21 AM
tesseract67's Avatar
Originally Posted by JimP View Post
HybridHB,The problem with just buying an amp from parts express and hobbling together a way to make it work is that its possible that the driver is damaging the amp and after a short time the new amp will also fail.
I am curious, how could the driver be damaging the amps? Impedance too low? Bottoming?
"Women and cats will do as they please, and men and dogs should relax and get used to the idea." -Robert A. Heinlein
tesseract67 is offline
Old 08-23-2010, 01:43 AM
Liked: 587
Earlier this year, I got a replacement amp from AV123 for my brother's MFW-15. As soon as I installed it, it blew.
Several months later, I called AV123 about what happened and they sent out another amp(new design) and a new driver. Put them in and it worked.
Don't know how long it lasted. Donated it to Goodwill for the tax credit.
By the way, the sub couldn't have been abused unless its possible to abuse a sub by not playing it loud enough. My brother and sister in law don't play their system very loud at all.
JimP is online now
Old 08-23-2010, 04:48 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Any luck?
V2 prob.
NicksHitachi is offline
Old 08-23-2010, 06:15 AM
jarablue's Avatar
Quoted: 13 Post(s)
Are the v2 amps bad?
jarablue is offline
Old 08-23-2010, 06:16 AM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
Jim
I highly doubt that he had a bad driver that would cause the amp to blow, instantly. With the track record of the amps, you probably just got another bad amp. Its kind of like russian roulette but with 4 out of 6 cylinders loaded.
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is offline
Old 08-23-2010, 06:21 AM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
HybridHB
I have a solution available now, but its more of a serious upgrade( 2X the output and increased SQ) and its not real cheap either. Look HEREfor the turbo thread for more info.
I am also working on getting a new amp built also that will be reliable along with a slightly better driver if needed.
Kevin
Old 08-23-2010, 06:46 AM
Liked: 587
Originally Posted by sandbagger View Post
Jim
I was also surprised that AV123 sent a driver but when I went to change it out, I found the original driver's voice coil basically fused in place. There was no movement at all.
Would you say that in this case at least, the driver was responsible for the amp to fail or maybe vice versa. The amp caused the driver to fail which in turn caused the amp to fail?
JimP is online now
Old 08-23-2010, 07:17 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
This is my take on this. When the V1 amps started going belly up, the amp module (a board) was identified as the most likely culprit. So, the module itself was redesigned (you can find pictures of both on this site). What happened next is interesting. Longmont had a ton of amps on hand that were suspect. But understand, amp in this case means the amp module and everything else circuit wise. So, they replaced the Chinese made amp module with the one from QSC Longmont. However, people who might've bought two subs or had two amps replaced were finding that some of the amps hummed while others didn't. To me, that suggests that the rest of the amp module was also suspect. You might get a good one. You might not. It's kind of like replacing a heart valve while overlooking that some hearts also had clogged arteries. The heart fails but why blame the valve replacement?
Regardless of what amp you may have, V1, V2, V3, it's important to realize that none of the amps were UL, CE, FCC tested despite any markings to the contrary. The markings were a ruse.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
Old 08-23-2010, 07:34 AM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
Ok
With adding in the fact that the voice coil had either welded itself, or the magnet had distorted the frame to the point of locking up the cone. YES that could and very probably caused the amp to cook itself.
Kevin
Old 08-23-2010, 08:03 AM
secstate's Avatar
It sure seems so. With the recent closing of AV321 it seems folks are coming out of the woodwork with V2 problems (I didn't think they were that widespread until recently). I know folks say they fail on power up but I still power cycle mine with an X10 module. I have probably power cycled mine over 200 times since I got it in January and it still works great. I think the heat kills them and they die on the power cycle but that it is not the power cycle that kills them (just a wild guess though). I have a spare v2 amp in case mine goes. At this point I am going to see what sandbagger comes up with for a replacement amp that is less than the Turbo. I might go for the Turbo too but I am a cheap b--tard which is what got me the MFW-15 in the first place. lol
secstate is offline
Old 08-23-2010, 08:11 AM
jerryhb's Avatar
I had 4 amps go bad , last one I sent to AV666, guess what happened then. I happened to have an old amp(v2) sitting around so I gutted it except for the speaker connectors and filled the holes with a high grade caulk, fresh coat of paint and bought an outboard amp on Ebay for $100 and hope to have a working sub in a few days and then wait for the 'turbo' mod. Will keep board in the loop when up and running.
jerryhb is offline
Old 08-23-2010, 09:12 AM
Stereodude's Avatar
Liked: 2238
Well, I don't know if they're all bad, but a good rule of thumb is that anything that came from AV123 with a power cord had some problem (not always reliability though).
Old 08-23-2010, 10:43 AM
Ruhnie's Avatar
Is this really true? I have been enjoying my x-series speakers from them for over 3 years now w/o any issues whatsoever. Should I be afraid that they may die miserably one day just like my MFW-15 did? It seems to me that their quality started going downhill more recently as the dickhead in charge started having financial issues. I would really like to think that I didn't completely waste all this money on my system. I am not an audiophile and if the rest of my system goes up in smoke I will not have the cash to replace it. The reason I went AV123 in the first place was because of their so-called "value" for such a low price. The more I read about them the more I feel like an idiot. This is all really, really depressing.
Ruhnie is offline
Old 08-23-2010, 11:05 AM
gonk's Avatar
I'm guessing that most of your X-series speakers don't have power cords - only products in that line that ever had built-in amps were the X-Sub and MFW15. Stereodude's point was that their electronics (powered subwoofers, X-Head, X-Amp, etc.) were most frequently sources for problems.
Danny Richie is buying up all the leftover parts for X-series speakers (drivers and Chinese-made crossover networks) from UniAudio and offering them for sale as kits through his company, so replacement parts should be available for a while if you do need them. Also, Skiing Ninja (Sean Parque) offers crossovers for upgrading them, which could serve as replacement crossovers if necessary.
gonk
Beta tester: BDP-83 / BDP-80
gonk is offline
Old 08-23-2010, 12:17 PM
Stereodude's Avatar
Liked: 2238
Yeah, basically. Every subwoofer they made had some sort of issue. Some models fried amps (UFW-10, MFW-15). Some had incorrectly configured amplifiers that made the performance underwhelming / embarrassing (UFW-12) [There's two fixes for the UFW-12 available here]. The X-amp had a hiss problem, the X-head had a hiss / hum problem. RDES sub EQ was a pile. The Perpetual Technologies P-1A had a really long wait (>5yrs) for those people who bought it hoping to get SOCS. The P-3A advertised 192kHz capability and never delivered it. There were the Emotiva related debacles / birthing pains. I'm sure I'm missing some other things from the list too.
No, because they're not powered from the wall.
Old 08-23-2010, 12:32 PM
UofAZ1's Avatar
Quoted: 50 Post(s)
Liked: 75
Haven't had any issues with my subs in my Strata Minis (3 years daily use now - knock on wood) so those 350 watt amps and 8" drivers are good.....so far.
UofAZ1 is offline
Old 08-23-2010, 12:46 PM
RedshiftAVS's Avatar
I love my MFW-15 when it's working, but I'm currently on my first V2 amp (after 3 failed V1 amps) and it recently started buzzing. Got a reply from tech support with RMA, so I sent it back and have been patiently waiting. Little did I know they'd be going out of business and leaving me with a useless MFW-15. Their web page says they'll have information on replacement amps soon. I sure hope so, but based on previous response, I have little faith
Short of spending 3 days reading 24 pages of this thread, what other alternatives are out there to replace my MFW-15 with?
RedshiftAVS is offline
Old 08-23-2010, 01:03 PM
ProblemHouston's Avatar
Quoted: 13 Post(s)
Liked: 27
Look here:
http://www.seaton-sound-forum.com/post?id=4853297
I never argue with fools cause from a distance you canÂt tell who is who....
ProblemHouston is offline
Old 08-23-2010, 01:24 PM
Ruhnie's Avatar
Doh my bad guys, totally misread your point. No my x-series stuff isn't powered, so hopefully my anxiety over this will die down and they will last a long time. Now if I can get my MFW-15 amp issue resolved I can go back to not having to worry about my audio gear, aka "ignorance is bliss" stage
Ruhnie is offline
Old 08-23-2010, 05:40 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
If you need a spare driver for your MFW, here is your chance:
http://www.audiocircle.com/index.php?topic=84989.0
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
Old 08-23-2010, 10:16 PM
lugged's Avatar
I looked around but didn't see anything else about this, so I figured I'd chime in... anyone else get a letter about creditor claims against AV123 and a liquidation sale next week? Presumably it's because I sent in two V2 amps a week or two before they shut down.
Per the letter, proceeds from the sale will go first towards rent/tax/etc, then to "holders of consumer deposit claims" (sounds like pre-pays?), then, if possible, to "holders of general unsecured claims."
There's a form to fill out and mail in if you have a claim, due by Sept 15th. I'm wondering if it's even worth the bother. I somehow doubt they'll be making enough from the sale to cover all of their more legally prominent debts and still get to me.
The online-only liquidation sale is Monday next week, and is listed on the auctioneer's site (Dickensheet & Associates.)
lugged is offline
Old 08-23-2010, 10:31 PM
heterology's Avatar
Yep, got the same letter today. I also had an amp in for repair - v2 that developed the bad hum.
heterology is offline
Old 08-23-2010, 10:34 PM
Stereodude's Avatar
Liked: 2238
Well cheer up because you two will be able to buy your defective amps back for just pennies on the dollar!
Old 08-24-2010, 11:43 AM
Curtis, I only saw references to X-series items there.
Old 08-24-2010, 11:44 AM
LOL...mine was actually refused by someone there, so at least I get it back. It works, but it hums...too bad I don't have enough equipment and knowledge to figure out which component is causing the problem. I do know how to solder and replace it if I did
Amplifier Speaker
