NEW MFW-15 amps (May 2010) *pics* - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #1171 of 2738 Old 10-29-2010, 08:50 PM
R_Johnson's Avatar
You might have a loose high level driver lead, pull driver and amp and check red black wires from amp to driver.
If this doesn't work ill sell you a v3.0 for $300.00.
I checked all the connections and they seemed tight. Put in the replacement fuse which blew immediately (without even turning it on; just plugging it in took it out).
R_Johnson is offline
post #1172 of 2738 Old 10-30-2010, 05:54 AM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
PM Murrel, he may be able to help.
Sepen is offline
post #1173 of 2738 Old 10-30-2010, 06:13 AM
Quoted: 1392 Post(s)
Liked: 587
I had a similar problem with my brother's MFW-15.
In his case, the driver and the amp had both gone bad.
Try pushing on the driver to verify that it still moves. It'll take more than a light push but don't overdo it either.
If the driver is bad, you might want to rethink your solution.
JimP is offline
post #1174 of 2738 Old 11-02-2010, 05:00 AM
Sepen's Avatar
Quoted: 27 Post(s)
Liked: 31
Originally Posted by Sepen View Post
My amp went from a slight hum to a massive one, and I got no output either. Talked with Murrel and sent it to him to be fixed. V2 btw. Will let everyone know how it goes. Was thinking of the Turbo but my grandson has grown 2" since it was last in stock.
I got back the part from Murrel yesterday and put it back in my amp, works perfectly, no hum at all. 6 days turnaround from NY to CO via Priority mail. He knows his stuff.
Sepen is offline
post #1175 of 2738 Old 11-02-2010, 06:02 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Is this repair a solution or a band aid?
Murrel,
Is this piece upgraded to be more reliable? If so pm me how much to upgrade them I have a couple I might do.......
NicksHitachi is offline
post #1176 of 2738 Old 11-02-2010, 06:34 AM
murrel's Avatar
Thanks Sam!
I am glad you are back up and running.
Murrel
Murrel J Gray
murrel is offline
post #1177 of 2738 Old 11-02-2010, 06:41 AM
centauro74's Avatar
Sepen, does the amp still gets really hot when in standby and in use after the repair?.
I probably will send mine to Murrel, mine was working great until the crazy ummm noice stared.
centauro74 is offline
post #1178 of 2738 Old 11-02-2010, 06:51 AM
murrel's Avatar
It will still run very warm.....Only way to fix that right now is to purchase a V3.
This only alleviates the hum.
Murrel
Murrel J Gray
murrel is offline
post #1179 of 2738 Old 11-02-2010, 07:44 AM
CaseyGT's Avatar
Murrel
And is this a problem Murrel? I know this has been covered in the pages and pages of discussion, but I don't remember the outcome. Should I unplug the amp after usage, or just let it go into standby?
My caps should be here today, and hopefully my amp fixed tonight. I'll let you know how it goes. thanks so much for your assistance.
Casey
CaseyGT is offline
post #1180 of 2738 Old 11-02-2010, 07:57 AM
centauro74's Avatar
Murrel
Murrel about that, it's this cured definitely or the ummm noise may come back?
If the fix is permanent then is wort the investment in the fix, if not then it's better to get a new amp.
post #1181 of 2738 Old 11-02-2010, 08:30 AM
murrel's Avatar
Casey
I would say it is a problem..leave your amp on it is the onrush that usually causes the boards to fail.
There is no real outcome as it is a design problem. The V3 uses the same transformer but the preamp,power supply and output board is completely redesigned and runs very cool.
And Casey you are welcome!
Murrel
Murrel J Gray
murrel is offline
post #1182 of 2738 Old 11-02-2010, 08:32 AM
murrel's Avatar
Only time will tell and I cant say which is better for you to do. Only 2 months in with this fix and none have come back yet.
Murrel
Murrel J Gray
murrel is offline
post #1183 of 2738 Old 11-02-2010, 09:58 AM
Quoted: 182 Post(s)
Liked: 189
Murrel
You sir get props!!
Maybe restore some rep for the folks in Longont......
post #1184 of 2738 Old 11-02-2010, 10:23 AM
murrel's Avatar
You sir get props!!
Thanks Nick****achi
Murrel
Murrel J Gray
murrel is offline
post #1185 of 2738 Old 11-03-2010, 07:24 AM
CaseyGT's Avatar
Casey
IT'S ALIVE!!!!! and without a hum. My theater walls were shakin' . Thanks again.
CaseyGT is offline
post #1186 of 2738 Old 11-03-2010, 07:37 AM
Quoted: 182 Post(s)
Liked: 189
What did you replace?, Just the Caps? What was the total cost?
post #1187 of 2738 Old 11-03-2010, 08:09 AM
murrel's Avatar
Casey,
Great news! Enjoy
Murrel
Murrel J Gray
murrel is offline
post #1188 of 2738 Old 11-03-2010, 09:26 AM
CaseyGT's Avatar
NH - As I pulled a few of the caps off, they were clearly swollen or ruptured. replacing the 4 as instructed by Murrel, cost about 3 bucks in parts and 8 dollars in shipping from parts-express. I'm not sure how Murrel feels about me handing out specifics about this repair, so I would suggest PMing him for details.
CaseyGT is offline
post #1189 of 2738 Old 11-03-2010, 10:12 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
Any thoughts as to why the new caps will not suffer the same fate as the ones replaced?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #1190 of 2738 Old 11-03-2010, 10:15 AM
murrel's Avatar
Casey,
You can post anything you want.........but I have had many people try to do the fix and destroy the board. And there are no spares to speak of. So if a person is not adept at removing and installing parts then I suggest they don't try to do the repair themselves.
Murrel
Murrel J Gray
murrel is offline
post #1191 of 2738 Old 11-03-2010, 10:16 AM
CaseyGT's Avatar
From the sound of it, we have no guarantee that they won't also fail. But for 12 dollars, It's a fine temporary solution for me. In addition, the failing caps were replaced with higher voltage units. typically this will allow for a bit more head room.
Understood, Murrel. I wouldn't want that hanging over my head either
CaseyGT is offline
post #1192 of 2738 Old 11-03-2010, 10:19 AM
murrel's Avatar
Not saying they wont and never have in fact I have always stated this may be a temporary fix. But I have suggested increasing the voltage and temp ratings on the caps.
Murrel
Murrel J Gray
murrel is offline
post #1193 of 2738 Old 11-03-2010, 10:22 AM
murrel's Avatar
All good Casey. I am glad you are up and running. And yes as this may be a temporary fix it at least gives folks a option or time to decide whether they want a V3 or to wait for Kevin's solution. Only time will tell how long this lasts.
Murrel
Murrel J Gray
murrel is offline
post #1194 of 2738 Old 11-03-2010, 01:00 PM
CaseyGT's Avatar
Here is Murrel's instructions, updated by me slightly, for fixing the hum issues with the v2 Amp.
The parts needed for the fix. If these links aren't legal by forum standards, let me know and I will removed them.
1 x 22uF 160v
2 x 470uF 35V
1 x 1000uF 35v
MFW15v2 HumFix.doc 69k . file
CaseyGT is offline
post #1195 of 2738 Old 11-03-2010, 01:38 PM
Quoted: 182 Post(s)
Liked: 189
Looks good, why not upgrade the main caps while your at it?
post #1196 of 2738 Old 11-03-2010, 01:49 PM
murrel's Avatar
You could if you wanted to but I have only seen them fail when you have a major short in the output section
Murrel J Gray
murrel is offline
post #1197 of 2738 Old 11-03-2010, 03:14 PM
murrel's Avatar
1 x 22uF 160v
2 x 470uF 35V
1 x 1000uF 35v
Nice job Casey!
Murrel
Murrel J Gray
murrel is offline
post #1198 of 2738 Old 11-03-2010, 03:24 PM
todd pellowe's Avatar
For $8.38 shipped USPS priority, I've got to give this a shot... Thanks a ton Murrell.
todd pellowe is offline
post #1199 of 2738 Old 11-03-2010, 05:03 PM
heterology's Avatar
Wow, great info - just wish I still had my v2 amp as it was sent in under warranty right before they shut the doors!
heterology is offline
post #1200 of 2738 Old 11-03-2010, 05:05 PM
murrel's Avatar
Are you completely without a amp?
Murrel J Gray
murrel is offline
Amplifier Speaker
