NEW MFW-15 amps (May 2010) *pics* - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
Old 10-19-2011, 01:31 PM
razafina's Avatar
My mfw15 has a sealed chamber where the amp plate goes, it only has a small hole about 3/4" were wire goes to driver and Q adjustment board.
razafina is offline
Old 10-19-2011, 02:52 PM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
Those holes are not well sealed if at all.....
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is offline
Old 10-19-2011, 03:13 PM
razafina's Avatar
I guess I will be using spray foam to seal the cavity. So I can do what I think I can do.
razafina is offline
Old 10-20-2011, 04:45 PM
mak99's Avatar
Quoted: 27 Post(s)
I'd think twice before cutting all those holes into your cabinet! How about a small fan outside the sub, blowing across the plate amp? My old v2 amp also got quite warm during use, and lasted about a year before humming off into the sunset.
Cutting those holes would surely ruin any potential resale value, or make it difficult to upgrade to a Turbo or other future MCCA plate amp...
still one of my favorite bumper stickers of all time...
FREE TIBET! *
* with purchase of equal or lesser Tibet
mak99 is offline
Old 10-20-2011, 05:03 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
My V2 amp vented a cap near a choke or coil, it was 22uf or 470uf at 100V(I have to check again and verify), I think is the pre audio board not the power supply and output board driver. I replace it and the other caps mention and its back and running. I will problably be putting a fan on the bottom by raising the bottom, making a hole for a fan(3" to 4" like computer fan) that will be install in the bottom. And making a couple of holes on the side to vent the hot air and help keep the amps components cool.
A passive option would be best. I have often thought of ordering some heat sink and mounting it to the back where the hottest components are. This would be the easiest and should provide enough cooling for that amp.
I have since converted a pair of original MFWs to sealed to work with 4 other sealed MFWs for a total of 6. I'll say 2 or 4 sealed do a good job in my room down to 10, and 6-8 are perfect.
Converting these cabinets to sealed is pretty easy, I pulled amp and top circuit board sealed up holes and port slot inside. Net volume is a bit large I prefer the 2.5ft3 per driver I designed but the ~3ft3 per driver of the original MFW does fine. Excursion is less controlled than I like, I can't beat on them quite as hard as I can the ones I built.
Anyways its an option for those with multiples if you run out of amps. About 250W per driver is plenty. I don't think many people would be happy with just one sealed in any room.....
NicksHitachi is offline
Old 10-20-2011, 05:07 PM
razafina's Avatar
Ok, the fan would be blowing the internal hot air, The purpose is to cool off by using external cooler air. I am also thinking about turning the boards and the transformers from internal to external and fabricating a pexiglass or metal cage. I would be using the same threaded hole that are use for the boards and the transformer. I think that will be a better alternative, than cutting holes and I can mount a circuit that will come on when ever it gets more that say 90 degrees inside the fabricated cage. What do you guys think.
razafina is offline
Old 10-23-2011, 08:52 PM
richlgilbert's Avatar
All - I just wanted to post how helpful Murrel is to resolve issues with the MFW15's. Thanks for all you do!
richlgilbert is offline
Old 10-30-2011, 04:08 AM
NumLock's Avatar
I ordered one of Murrel's V3 amps a few days ago. I hope it comes in soon!
NumLock is offline
Old 10-31-2011, 06:39 PM
trekker's Avatar
I had placed my order for (3) V3 amps the first week of Oct and I just received the FedEx shipping notice. Not too long of a wait. :-)
trekker is offline
Old 11-04-2011, 10:42 PM
cbtbackflow's Avatar
How did they turn out? I just ordered one...
cbtbackflow is offline
Old 11-04-2011, 11:43 PM
GobbityGotz's Avatar
Got my V3 today. Easy install and runs much cooler than my past v2's( i went through 2 of them). haven't had a chance to crank it because the kid was sleeping already but should get to drive it hard this weekend. Thanks Murrel! Celebrated with a can of Ten Fidy.
My life is set at reference level.
GobbityGotz is offline
Old 11-05-2011, 05:31 AM
NumLock's Avatar
I got my shipping notice! I can't wait until it gets here. Time to buy some new movies.
NumLock is offline
Old 11-05-2011, 07:52 AM
murrel's Avatar
You are welcome!
And I am glad that you enjoy our beer!
Have a great weekend!
Murrel
Murrel J Gray
murrel is offline
Old 11-11-2011, 05:23 PM
centauro74's Avatar
Anyone interested in selling a sub, my friend keep asking me to buy one of mine. He lives in NJ.
centauro74 is offline
Old 11-11-2011, 05:40 PM
tjwashow's Avatar
murrel is very helpful when it comes to these things! My amp just crapped on me and murrel is about a month and a half wait he said, so i am going external amp behringer inuke 1000dsp. We chatted and he suggested it so heck yea im going to try. Ill let you know how it turns out.
tjwashow is offline
Old 11-11-2011, 06:55 PM
Quoted: 182 Post(s)
Liked: 189
probably not a bad plan, someone could probably get a good working set of filters with a little effort and a measurement rig.... Prob want to high pass at like 15-19hz though to keep out of trouble with excursion......
Old 11-13-2011, 03:24 AM
NumLock's Avatar
Thanks Murrel! I finally installed my V3 amp tonight. Here are some pics.
NumLock is offline
Old 11-13-2011, 03:31 AM
NumLock's Avatar
I had to make a adapter cause my V1 amp uses bullet connectors while the V3 uses spade connectors.
V1 amp on top, V3 amp on the bottom:
Ready!
NumLock is offline
Old 11-13-2011, 06:38 AM
yadfgp's Avatar
Quoted: 66 Post(s)
Liked: 68
Anyone interested in a couple of MFW's with the v3 amps in em?
http://emotivalounge.proboards.com/i...d=20824&page=1
yadfgp is offline
Old 11-13-2011, 07:27 AM
murrel's Avatar
Very nice pictures! I am glad all is working well! Also good to see that that Fed Ex is getting the amps to you with little or no damage to the box!
Enjoy!
Murrel
Murrel J Gray
murrel is offline
Old 11-13-2011, 08:02 AM
HuskerHarley's Avatar
Quoted: 33 Post(s)
Liked: 26
Great pics.
Murrel
Any chance you can include the adapters, with the 4 V3's I ordered from you, in case mine use bullet connectors as well?
HH
HuskerHarley is offline
Old 11-13-2011, 10:34 AM
murrel's Avatar
Originally Posted by HuskerHarley View Post
Great pics.
Murrel
HH
Sure can. I will do my best to remember. Your amps hopefully will be in my shop for my testing sometime next week.
have a great day
murrel
Murrel J Gray
murrel is offline
Old 11-19-2011, 06:17 PM
streamerlover's Avatar
Wouldn't have been easier to just clip the bullet ones from the woofer and add female spades there? Or was length the issue?
streamerlover is offline
Old 11-19-2011, 06:31 PM
MTAtech's Avatar
Quoted: 14 Post(s)
Women tell me "length doesn't" matter.
MTAtech is offline
Old 11-19-2011, 07:05 PM
Down's Avatar
Just received my V3 amp recently and went to install it. Is there an easier way to deal with the bullet to spade connection issue than just cutting the bullets off the driver wires and slapping on some spade connectors?
Also, thought I'd share a pic of my old amp. It went out with a bang as you can see.
Down is offline
Old 11-20-2011, 07:15 AM
murrel's Avatar
Please make sure that your driver is not damaged, would hate to see you damage the new amp.
Murrel
Murrel J Gray
murrel is offline
Old 11-20-2011, 09:28 AM
Down's Avatar
Murrel
How exactly would I know whether the driver was damaged?
Down is offline
Old 11-20-2011, 01:40 PM
murrel's Avatar
Gently with both hands push the driver in and out. Make sure it moves freely with no resistance.
Murrel
Murrel J Gray
murrel is offline
Old 11-20-2011, 03:06 PM
NumLock's Avatar
I wanted to fix my old amps just for fun so I left the bullet connector on there.
NumLock is offline
Old 11-20-2011, 03:35 PM
Quoted: 182 Post(s)
Liked: 189
Murrel
Or you could just hook up your nice new amp and if you see smoke, its probably bad......
Amplifier Speaker
