NEW MFW-15 amps (May 2010) *pics* - Page 71 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #2101 of 2738 Old 11-20-2011, 10:22 PM
streamerlover's Avatar
Originally Posted by Down View Post
Just received my V3 amp recently and went to install it. Is there an easier way to deal with the bullet to spade connection issue than just cutting the bullets off the driver wires and slapping on some spade connectors?
Also, thought I'd share a pic of my old amp. It went out with a bang as you can see.
WOW! Have not seen one like that blow a big cap! That looks nasty..
streamerlover is offline
post #2102 of 2738 Old 12-08-2011, 04:51 PM
HTEnthusiast09's Avatar
Originally Posted by NumLock View Post
Thanks Murrel! I finally installed my V3 amp tonight. Here are some pics.
Hi, thanks for the nice review and pictures. I have a question for you (or a couple) considering I'm a bit of a novice at any improvement project. Were you able to just clip off the wire from your old amp, and after stripping the wire down a little slip on new female connectors? Does it require any soldering or glue, and what kind of connector did you use? My MFW has the plug connectors and I am considering putting in an order for one of these. Thank you for your time!
HTEnthusiast09 is offline
post #2103 of 2738 Old 12-09-2011, 03:14 AM
NumLock's Avatar
No solder or glue. Just the spade connectors, wire strippers, and a crimper or pliers.
I had the parts and tools at work but I'm sure you can buy the spade connects from Radio Shack or Home Depot.
NumLock is offline
post #2104 of 2738 Old 12-11-2011, 04:01 PM
goondog's Avatar
+1 for another successful humfix on a V2 amp!!
thanks Murrell and forum folks. Replace all 4 caps and amp still is warm to touch but no hum until only i increase gain past 12oclock.
thanks again!!
goondog is offline
post #2105 of 2738 Old 12-11-2011, 06:35 PM
laeriq's Avatar
Quoted: 63 Post(s)
Liked: 90
Yesterday I won two of these for $400 on fleabay and will be picking them up in a couple of weeks. I've read through most of this thread so I think I've got a handle on what I'm in for. Both amps are V2 and the seller said he has replaced caps on one of them but that both do have a slight hum. In no order my questions are-
1-I'll probably have my brother do some sodering of new caps. Any preference on the PE Lelon parts vs the Digikey Panasonic parts?
2- If for whatever reason the V2 amps go bad, how hard is it to seal the amp cutout and use a pro amp to power them. Seems like something like an ep1500 would provide plenty of power for both subs.
3- I plan on stacking these. I've used homemade sub risers before but is it worth it having 200+ lbs of sub like this?
4- Looks like a Squaretrade would be around $70... worth it? Does ST make you ship the subs? Seems pretty foolish if they did.
Anyway very excited and scared to go down this road... at worst if they're a disaster by the time the Turbo's are more available I might have some upgrade money. Thanks!
laeriq is offline
post #2106 of 2738 Old 12-11-2011, 10:26 PM
cappra's Avatar
Off the main topic, but does anyone remember which Parts Express amp was a drop
in for the UL-10? Thanks.
cappra is offline
post #2107 of 2738 Old 12-12-2011, 06:26 AM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
You want the 240-B amp....
You might be able to change out the power supply caps similar to what is done with the MFW..... I have had good luck. This is only for the older amps, not the new design
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is offline
post #2108 of 2738 Old 12-12-2011, 06:29 AM
murrel's Avatar
http://www.parts-express.com/pe/show...number=300-804
Murrel J Gray
murrel is offline
post #2109 of 2738 Old 12-12-2011, 08:20 AM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
This is the one you really want, it will get a better response
http://www.parts-express.com/pe/show...number=300-805
Kevin
post #2110 of 2738 Old 12-12-2011, 09:43 AM
cappra's Avatar
You guys are the best. Thanks.
cappra is offline
post #2111 of 2738 Old 12-12-2011, 10:27 AM
etcarroll's Avatar
Location: Living among the children of the corn in Oxford, (S.E.), PA.
Yup - dropped that one right into my UL-10, no problem.
"The Bundys' proud name was built on a philosophy of lying. Well, lying, owing money and perhaps beer. Yes, lying, owing money and beer. The only thing that separates us from the Kennedys is that they have money." - Al Bundy
etcarroll is offline
post #2112 of 2738 Old 12-12-2011, 11:07 AM
Down's Avatar
A little bit belated here but thought I would chime in with another glowing review of the V3 amps. Had it in for a few weeks now and it's been rock solid. Additionally, whether it's a placebo effect or not, it's seemed SO much more dynamic since the amp swap that it's nearly incomparable. Thanks Murrell!
My one annoyance that I'm finally going to get around to addressing is annoying sound coming from the sub. There's a rattle coming from the area where the amp is housed at certain frequencies when the level is high. I no longer have the little plastic controller box and the controller wires are fairly secured so I believe it's coming from some excess wire on the amp vibrating against the plate of the amp. Has anyone else experienced this and came up with a nifty fix?
Down is offline
post #2113 of 2738 Old 12-12-2011, 11:09 AM
Down's Avatar
Yep, I bought mine at Radio Shack, $2 or so for a pack of 10. I went with the crimp on, solderless type and it was very easy. Just cut off bullet connectors, strip a little bit of wire, insert into new spade connector and pinch the entrance and you're done.
Down is offline
post #2114 of 2738 Old 12-12-2011, 11:17 AM
murrel's Avatar
I would first check to make sure the driver and plate covering the driver are secure. You might also make sure that the driver wires are not contacting the driver.
I am glad the amp is working well for you
Have a good day
Murrel
Murrel J Gray
murrel is offline
post #2115 of 2738 Old 12-12-2011, 11:37 AM
Down's Avatar
Have a good day
Murrel
Thanks Murrel. Actually, the first thing I did was tighten the speaker and the plate in front of it. I'd considered popping off the speaker but honestly, I'm a little hesitant to given my history with the assembly quality on this sub, i.e. stripped screw holes. While playing, I did notice that all of the rattling was coming from the amp area and can even feel the vibration of the rattling on the amp, but nowhere else. Fingers crossed that I can perform some decent cable management.
Down is offline
post #2116 of 2738 Old 12-12-2011, 11:39 AM
murrel's Avatar
If you need help dont hesitate to call me.
Murrel
Murrel J Gray
murrel is offline
post #2117 of 2738 Old 12-12-2011, 08:31 PM
Down's Avatar
Murrel
Thanks Murrel. Unfortunately, I believe that after a total of 5 blown amps, including one that burnt out so bad my living room still smells of electric fire 2 months later and dropping the moola on the V3 amp, the MFW-15 has finally beaten me. After wasting the evening playing around with wire management in the back to try and get rid of this rattle coming from the area right around the gain control, I $%#@%$# give up. I'm done.
I see a pair of Outlaw LFM-1 EXs in my near future.
Down is offline
post #2118 of 2738 Old 12-12-2011, 08:38 PM
murrel's Avatar
I still think you should call me tomorrow.
Murrel
Murrel J Gray
murrel is offline
post #2119 of 2738 Old 12-12-2011, 08:39 PM
murrel's Avatar
check the nuts behind the knobs they can vibrate loose
murrel
Murrel J Gray
murrel is offline
post #2120 of 2738 Old 12-12-2011, 08:58 PM
mak99's Avatar
Quoted: 27 Post(s)
I'd recommend you buy a SquareTrade warranty - I did so when I bought my open box MFW back in Feb 2010 for $499. The sub died about a year later (humming), and they refunded me the money when I filed my claim. I did call to explain the situation (AV123 closed, only MCCA had the upgrade kit at that time), and sent them appropriate webpage links and filled out the affidavit. Since the item was over 20# (I think that's their "ship it in" limit), they refunded my original purchase price and told me to just keep the dead sub.
I then used that money towards the Turbo kit right away as Kevin was shipping Kits at that time...so only cost me another ~$300 out of my pocket. Absolutely no regrets about that upgrade - beats the snot out of the stock MFW !!
ST was absolutely great to deal with, and have only filed one other claim in all the warranties I've bought from them over the years - they delivered as promised.
Go ST or go home! BTW, there's usually coupons out there to get a good discount on the warranties. I have a code handy for 35% off, if you want - just PM me...expires 1/6/12.
still one of my favorite bumper stickers of all time...
FREE TIBET! *
* with purchase of equal or lesser Tibet
mak99 is offline
post #2121 of 2738 Old 12-12-2011, 09:09 PM
Down's Avatar
Murrel
murrel
I'll definitely give you a ring tomorrow, thanks for being so helpful. Unfortunately, I'd already tightened the knob backing nuts along with every screw on the thing.
Talk to ya tomorrow and thanks again.
Down is offline
post #2122 of 2738 Old 12-12-2011, 09:25 PM
murrel's Avatar
Anytime after 8am MST
Murrel J Gray
murrel is offline
post #2123 of 2738 Old 12-12-2011, 11:25 PM
NumLock's Avatar
That's the attitude! I'll do you a favor and take in your old MFW.
NumLock is offline
post #2124 of 2738 Old 12-13-2011, 07:49 PM
Thanks and thank you Numlock! I talked to Murrel (cool guy) and I'm looking forward to getting a V3.
post #2125 of 2738 Old 12-14-2011, 12:14 PM
Down's Avatar
It'll be up for sale in a few months.
Down is offline
post #2126 of 2738 Old 12-15-2011, 08:33 AM
volta's Avatar
Just a FYI, I have a black satin with a v.2 amp for sale. PM me if you want details
volta is offline
post #2127 of 2738 Old 12-23-2011, 11:21 AM
SteveSatch's Avatar
Quoted: 32 Post(s)
Anyone with a used V3 amp for sale? My version 1 finally bit the dust. I have three other MFWs all running version 3 amps and they are great amps!
SteveSatch is offline
post #2128 of 2738 Old 12-24-2011, 01:10 PM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
I have a few V2 with the cap fix available
Kevin
post #2129 of 2738 Old 12-31-2011, 02:45 PM
sublime90's Avatar
I have been a member of this board for quite a while now and time and time again you guys come through for me. esp Murrel this time!
I had 2 MFWs down for almost a month and bumped into this thread, two days later + 8 caps and up and running like nothing happened. woot.
When these die, Ill definitely be upgrading to the V3.
Again, thank you all.
Sub
sublime90 is offline
post #2130 of 2738 Old 01-14-2012, 05:21 PM
fschris's Avatar
Quoted: 18 Post(s)
I have a broke MFW-15 amp I will sell... make offer ! I bought it on ebay and the issue was hum. I replaced the caps. Before I replaced them there was no hum but also no sound, after I replaced caps... same thing. No Hum no sound. The amp does turn on. I think the PS is good. It looks good as well. Clean, no scratches etc. Maybe someone could use this for parts....
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
Amplifier Speaker
