Subwoofer pre-out vs speaker out? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-28-2010, 02:48 PM - Thread Starter
safe bobo's Avatar
How come when I set it up, so the receiver sends the signal to the subwoofer, than out to the speaker via the speaker cables. I get much (louder) bass? Than when I use the pre-out subwoofer cable? It's almost as though it's on a super low volume. Also if I use stereo (RCA) input, can I get bass via the pre-out?
safe bobo is offline
post #2 of 3 Old 05-28-2010, 04:36 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Have you set Subwoofer to Yes on the receiver? How did you connect the pre out to the sub?
If you are only using a stereo source, then you have to make sure the sub is set to on in the AVR and the speakers set to small to get bass redirection to the pre out.
Randy
ransac is offline
post #3 of 3 Old 05-28-2010, 05:25 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Did you set your speaker to SMALL when you utilized the pre-out or not?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
