Polk Audio PSW PSW10 subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-29-2010, 10:57 AM - Thread Starter
broertje's Avatar
I need help. Will the Polk Audio PSW PSW10 subwoofer work with Monitor 60 and Polk Audio CS1? I need a Subwoofer but do not know what to get? My family room is 21 x 13, with vaulted ceiling if that helps out. Any advice would be appreciated.
broertje is offline
post #2 of 10 Old 06-29-2010, 11:18 AM
pjones0404's Avatar
Yes it will work.
Now the bigger question is what are you expecting from your subwoofer? The room you have is pretty large. The polk will not be able to fill that room with bass. What is your budget?
pjones0404 is offline
post #3 of 10 Old 06-29-2010, 11:56 AM
sully78's Avatar
Are you asking because they are $90 right now? I would go with two at least.
sully78 is offline
post #4 of 10 Old 06-29-2010, 01:35 PM
4theLuvofHD's Avatar
Probably need 4 or more. 90$ should be their list price. They are on par with Sonys 10". I would save and spend more on a decent sub. Oh, and I am a Polk fan, minus their subs.
4theLuvofHD is offline
post #5 of 10 Old 06-29-2010, 01:37 PM - Thread Starter
broertje's Avatar
I was asking about the PSW10 because of the $90 price. I am trying to safe money if possible.
broertje is offline
post #6 of 10 Old 06-30-2010, 02:28 PM
dacdd's Avatar
the psw10 is not a good sub at all. Really weak, heavy distortion when it tries to dig remotely low, I wouldnt buy one at all.
If you can mustard up 200 dollars and shoot for a bic f-12 or h100, it would be a huge improvement and only slightly over 100 bucks more to do it. I would not purchase a psw10.
dacdd is offline
post #7 of 10 Old 07-19-2010, 09:55 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I am looking to grab one on craigslist for $50. This will only be for a computer setup, and just want something to fill in around 40-60Hz where my Monitor 30s will drop off. I am in an apartment with neighbors, and felt like this would be a good deal. Any thoughts?
I have a BIC F-12 in my living room and love it, but do not want to spend that much for a computer setup, and my neighbors wouldn't be too pleased with that either
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #8 of 10 Old 07-19-2010, 05:06 PM
Andronicus81's Avatar
I had this sub for about 2 months until I upgraded to a BIC H100. Test tones under 40hz really showed the weakness in the sub, although it is pretty good as a general music sub. Save your money for something a bit better, trust me.
Waiting for MST3k BD 3D 7.1
Andronicus81 is offline
post #9 of 10 Old 03-14-2011, 08:21 PM
HuckMan's Avatar
A month after deciding the PSW10 was good enough for my 10x13 room, I wanted to take it back. After you listen to more and more music, the bass doesn't sound as "cool" as it used to. Definitely go the extra step and spend more on the sub.
HuckMan is offline
post #10 of 10 Old 03-14-2011, 09:21 PM
Florida_Gator's Avatar
Bic F-12 would work well with what you have. Set your speakers to "small", with a crossover of 80hz. I've got the F-12 with similar Polks setup that way, and it's a great HT setup!
Florida_Gator
Florida_Gator is online now
