Subwoofer recommendations for Definitive Technology ProCinema Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-02-2010, 06:27 PM - Thread Starter
steveerat's Avatar
I'm a newbie looking to build my first decent HT system, and I found 2 pairs of lightly used Definitive Tech ProCinema 1000 and 800 monitors as well as a 2000 center channel at a good price.
What subs would work well for this setup in a 12x14 home theater area in a larger 12x28 space?
The set would be used for 50% Bluray/DVD/Dish HD content, 30% PS3 gaming, and 20% music. I want something with some musicality that is strong but won't over-power the rest of the system. That said, I do own my house and neighbors aren't an issue.
Size and appearance are not overly of concern, but I don't want to spend much more than $500, and would be happy to spend less.
Thoughts and recommendations are much appreciated!
steveerat is offline
post #2 of 2 Old 08-03-2010, 09:12 PM
lunarlizard88's Avatar
SVS, Hsu, Elemental Design, Epik, etc. Take your pick. You need not to worry about matching a sub to your speakers, just worry about a sub that can fill that space. You also need the height of the room because you need to know the volume of air that you will need to pressurize.
lunarlizard88 is offline
