Need a Subwoofer recomendation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-21-2010, 11:53 AM - Thread Starter
vizar99's Avatar
I'm currently in the process of building a new HT setup.
I have already selected the receiver and front speakers - they are currently being shipped.
AVR: Onkyo TX-NR708
Speakers: Klipsch WB-14 front / bookshelf and Klipsch WC-24 Center (Icon w)
TV: Samsung UN46C6400
The room is 12x17 with a vaulted ceiling (12') and wood floors it will be a dual use room for HT and as a family room. The system will be used for both HT and Stereo listenng - split evenly.
I would like a sub that will fit the room and not be too large, but have good sound quality.
I was thinking of going with the Klipsch 8" sub xw-300D, but would like to have alternatives.
My price range is $300-$500 shipped
Thanks in advance for any advice.
vizar99 is offline
post #2 of 6 Old 09-21-2010, 12:06 PM
sholling's Avatar
The little Klipsch is going to be in over it's head in a room that size. Check with Elemental Designs and Hsu Research.
sholling is offline
post #3 of 6 Old 09-21-2010, 01:26 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
The ED A5s-300 Subwoofer seems to be a good fit. I think as long as your keep the levels in reason you will get good playback with that sub. Not sure of the shipping cost though...they're heavy
kgveteran is offline
post #4 of 6 Old 09-21-2010, 04:47 PM
brian6751's Avatar
Quoted: 1142 Post(s)
Liked: 1120
Svs pb10-nsd.
That's not science! - Cyborg
FOR SALE: 120" 16:9 Silver Ticket AT Screen
Rivers Edge Theater
brian6751 is online now
post #5 of 6 Old 09-22-2010, 11:26 AM - Thread Starter
vizar99's Avatar
Thanks for the recomendations.
Looking at those sites, and am focusing on sealed subs for accuracy, I am considering the folloging:
eD: A5S-300 - compact, but i have concern with its non linear behavior at med to high levels - but i do not know how to quantify this and whether it is a problem for my application, cabinet finish is so-so.
SVS: SB12-NSD - compact, pricy w/ shipping and no independent info available
Hsu: VTF-1 - good price,Bash amp,though size is a somewhat big disadvantage and it is ported (though not really a con) - seems complicated to use
Klipsch: xw-500D: compact; nice UI for comfiguration and recall of settings, BASH amp
should i be concerned with the eD non linear behavior or lack of info on SVS and is the up level Klipsch xw-500D a unit i should consider?
Thanks again
vizar99 is offline
post #6 of 6 Old 09-22-2010, 12:15 PM
spyboy's Avatar
Liked: 48
Thanks again
What non linear behavior are you looking at? Some sealed subs have some roll-off at lower frequencies which is compensated for by room gain. None of these subs are complicated to set-up or use. If you need help, you just call and they give you technical assistance over the phone.
The A5S-300 should do well in your space.
spyboy is offline
