SVS PB12-NSD vs Paradigm DSP-3400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-22-2010, 09:11 AM - Thread Starter
echoesian's Avatar
Guys..pls give your comment on these because the price difference is not really that huge. The DSP-3400 has a 14" woofer but the SVS only 12".. not sure about their amp performance though...
echoesian is offline
post #2 of 6 Old 09-22-2010, 10:37 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
This seems like deja vu .... did you do a search on it as I think someone just asked this same question?
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #3 of 6 Old 09-22-2010, 10:39 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Here it is ...
http://www.avsforum.com/avs-vb/showt...light=paradigm
The last half touches on the 3400. The reality is, without objective data it's tough to call. Slightly bigger driver in the Paradigm, much larger box with the SVS, but more ports on the Paradigm. Amp specs were about the same IIRC, though the new PB12NSD has a 400 watt amp.
Low end may still go to the SVS due to the box size advantage I would guess.
Personally, if space wasn't a concern, I'd probably go with the SVS with their new DSP amp.
pbc is offline
post #4 of 6 Old 09-22-2010, 10:39 PM - Thread Starter
echoesian's Avatar
Originally Posted by pbc View Post
Here it is ...
Is there an improvement on the new DSP amp even on their entry sub like PB12-NSD?
post #5 of 6 Old 09-23-2010, 05:38 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Well, their old amp wasn't a DSP design, the new one is, and has more power. So yes, there is an improvement.
I assume you can get each sub for around the same price? For some reason I thought the DSP-3400 was a couple hundred more?
pbc is offline
post #6 of 6 Old 11-13-2010, 04:07 AM - Thread Starter
echoesian's Avatar
What could be the improvement on the new DSP amp? Aside from more power, would it be better for music and how about the low end?
