Funky Waves Audio - Official Thread (Prebuilt and Custom Subs) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
Closed Thread
post #31 of 766 Old 10-27-2010, 02:25 PM
edgebsl's Avatar
Quoted: 666 Post(s)
Liked: 1211
Not a bad price for what it does!
That sounds exciting!
Jeremy
Reaction Audio Subwoofers
edgebsl is offline
post #32 of 766 Old 10-31-2010, 08:17 AM
dlfromcanada's Avatar
I'm assuming these amps are a good match for the LMS Ultra 18, is that correct?
dlfromcanada is offline
post #33 of 766 Old 10-31-2010, 08:49 AM
penngray's Avatar
Liked: 47
I will be finding that out soon.
My amp should get here next week, I just wish I had the Marathon 5050 that is stuck in back order to compare against it.
I will compare against the EP2500.
penngray is offline
post #34 of 766 Old 10-31-2010, 12:21 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Yes they are designed to run the LMS5400 and Pro18 5100, in the FW18.0 and FW18.3. We will likely use it in the upcoming FW15.0 and FW15.3 as well. It can also be used in custom subwoofers with other drivers, when suitable.
Nathan Funk
Funk Audio
Funk Audio is offline
post #35 of 766 Old 10-31-2010, 04:19 PM
crabra's Avatar
Originally Posted by Funky Waves View Post
and only 120V.
That a pity.
Look HERE what we have to pay in Australia for a high powered plate amp.
crabra is offline
post #36 of 766 Old 10-31-2010, 06:39 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
We can look into a 220/240V version if there is enough interest.
Nathan Funk
Funk Audio
post #37 of 766 Old 10-31-2010, 06:46 PM - Thread Starter
Warpdrv's Avatar
Originally Posted by crabra View Post
That a pity.
Oh my good lord - $6K for a 3000w plate amp....
Sweet !!!! I'll take 6.....
Warpdrv is offline
post #38 of 766 Old 10-31-2010, 06:59 PM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
I see an FW 10.1 as a ported 10"; do you also make a sealed 10"?
If so, what dimensions and FR would one expect?
Thanks - Rick
PS. Same questions on the 8" (actually, what are the dimensions and FR of the ported 8 too)
PPS. I am looking for 2 small subs for 2.1 systems. One is computer setup the other is livingroom but size are critical.
rick240 is offline
post #39 of 766 Old 10-31-2010, 08:01 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
We don't have a standard design for those but we can do custom. A sealed 10" with the same driver as the 10.1 could be ~15" cube, and would be the same price as the 10.1. F3 of 35 Hz, f10 of 20 Hz.
The 8" is under redesign as we are going to another driver. We are thinking of a sealed dual opposed 8" with a 300 watt Bash amplifier, it will be ~13" cube, F3 40hz F10 24hz. It will be a little more than the old 8.1, but close.
Nathan Funk
Funk Audio
post #40 of 766 Old 11-01-2010, 01:23 AM
crabra's Avatar
If someone was brave enough there is probably is market down here for a completed built sub with 2000w amp.
From what I understand it's the electronics getting passed or c-ticked as we call it to be able to sell commercially in Australia.
How hard is it to make or convert to 220v/240v?
The closest thing is SGR doing a Mal-X with either powered by a hypex 800w or pro amp.
crabra is offline
post #41 of 766 Old 11-05-2010, 04:13 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Here is a peak at a new product, and yes we can do custom designs like this as well. It is CNC machined 1" Aluminum plate. The enclosure this will mount to will be stacked birch ply.
Nathan Funk
Funk Audio
post #42 of 766 Old 11-05-2010, 04:21 PM
alphaiii's Avatar
Quoted: 44 Post(s)
Liked: 58
We don’t have a standard design for those but we can do custom. A sealed 10" with the same driver as the 10.1 could be ~15" cube, and would be the same price as the 10.1. F3 of 35 Hz, f10 of 20 Hz.
The 35Hz f3 is the modeled response correct?
So with room gain, what kind of in-room extension could one expect?
alphaiii is offline
post #43 of 766 Old 11-05-2010, 04:32 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Yes 35hz is half space model. Room gain can vary a lot but I would expect Mid 20's.
Nathan Funk
Funk Audio
post #44 of 766 Old 11-05-2010, 04:52 PM
alphaiii's Avatar
Quoted: 44 Post(s)
Liked: 58
And would the sealed SDX10 design also use the 300W BASH amp used in the 10.1?
That amp doesn't have any boost in the stock version, but can be modded to add boost, correct?
alphaiii is offline
post #45 of 766 Old 11-05-2010, 05:13 PM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Yes same amp, it has ~1db boost around 30hz IIR, and can it be changed.
Nathan Funk
Funk Audio
post #46 of 766 Old 11-06-2010, 07:07 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Very nice work Nathan,
Two things; The CNC machined 1" Aluminum plate baffle is simply gorgeous...make my head swirl with possibilities. Also, wrt the big 4kw amp, are those fans mounted at the bottom of the heat sinks?
Thank you and good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #47 of 766 Old 11-07-2010, 06:12 AM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Yes the amp has cooling fans, fully variable speed, low noise.
Nathan Funk
Funk Audio
post #48 of 766 Old 11-07-2010, 06:22 AM
penngray's Avatar
Liked: 47
So that amp has a 4000Watt Peak? It will be interesting to see it against the Marathon 5050.
penngray is offline
post #49 of 766 Old 11-07-2010, 08:10 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I'm still trying to figure out if it's worth attempting to rejig my boxes to fit this sort of an amp into them vs having that monster QSC RMX 5050. I think it makes sense, though I'm wondering about having two amps with two fans, albeit in an enclosure vs. the single amp in the QSC. Plus, I have a center cross brace that I'd have to figure out what to do with even if these amps would fit into the enclosures and I could cut the box. Hmmm...
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #50 of 766 Old 11-07-2010, 08:37 AM
edgebsl's Avatar
Quoted: 666 Post(s)
Liked: 1211
Is the 5050 just taking up too much room?
That is a great amplifier!
Jeremy
edgebsl is offline
post #51 of 766 Old 11-07-2010, 08:45 AM - Thread Starter
Warpdrv's Avatar
Prob that and the noisy fans
Warpdrv is offline
post #52 of 766 Old 11-07-2010, 08:57 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
What Warp just said. Even with the modded fan I can still here it during low passages and find it annoying. Plus, having a 75lb beast on an otherwise elegant Salamander rack in my family room is a bit annoying.
Besides, removing the 5050 from the rack would free up space for more exciting new gadgets that I don't really need but will spend money on anyhow.
pbc is offline
post #53 of 766 Old 11-07-2010, 09:06 AM
edgebsl's Avatar
Quoted: 666 Post(s)
Liked: 1211
Hmm, do you have a closet on the same floor?
Can you run cables through your basement or walls?
What I am getting at is maybe you could store the amp somewhere else and put a ded outlet on a switch?
Jeremy
edgebsl is offline
post #54 of 766 Old 11-07-2010, 05:50 PM
Tack's Avatar
Quoted: 3035 Post(s)
Liked: 4203
That amp is very cool. You could even config some "out" terminals to parallel or series another separate sub.
Tack is offline
post #55 of 766 Old 11-09-2010, 07:52 AM
Funk Audio's Avatar
Quoted: 106 Post(s)
Liked: 186
Yes 4000 watts peak, 2000 watts RMS, The 5050 has around twice the RMS output but even twice the power is only 3db difference, so it should be within that range.
Nathan Funk
Funk Audio
post #56 of 766 Old 02-01-2011, 10:41 AM
Mike_WI's Avatar
Quoted: 224 Post(s)
Liked: 150
Great thread.
I hadn't heard of Funky Waves Audio until I met Warpdrv and saw his sub results.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is online now
post #57 of 766 Old 02-01-2011, 11:47 AM - Thread Starter
Warpdrv's Avatar
Originally Posted by Mike_WI View Post
Great thread.
Mike
Just a note - I didn't get my large DIY boxes from Funky Waves, those were from John @ AE Speakers, but I have ordered a custom 18.0 box for an LMS I have.... Which is what Mike and I discussed when he was here...
I will post pics when the time comes...
Warpdrv is offline
post #58 of 766 Old 02-01-2011, 04:58 PM
Unobtainium's Avatar
Some of the nicest veneer work I've seen. The machining is cool.
The quality of drivers speaks volumes about the desired end product.
Nathan isn't too far from me. Might have to take a drive up his way to decide if I really want to mess with DIY when I'm so busy.
Canadian made is always a plus for us guys up north, as mentioned, so we don't get hosed on duty, brokerage,delays, etc.
"The bitterness of poor quality lingers long after the sweetness of low price subsides"
Unobtainium is offline
post #59 of 766 Old 02-01-2011, 05:33 PM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Workmanship is stunning.............no doubt!
Anyhow, I'm not interested in a beauty queen ........ rather I'm looking for two inert enclosures supporting the best drivers available........both subs will be placed behind a facade AT wall/screen.
Good looks will take a back seat as sound quality and box real estate trumps all! I want the Velodyne Digital Drive sound/distortion levels with much greater SPL capabilities...................
Am I asking too much?
Nathan's builds seem to be my only path to meet my objectives toward sonic "nirvana"........
doublewing11 is offline
post #60 of 766 Old 02-01-2011, 09:15 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 76
Hey Nathan,
So do the 2000 watt plate amps have any form of adjustable boost for a sealed 4cuft LMS or is it just something the user adds with a Bassis, DCX or MiniDSP on his own?
What's a good boost range for the LMS in a 4cuft sealed with that much power anyway?
mjaudio is offline
Closed Thread Subwoofers, Bass, and Transducers
