SSW-10 Infinity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-01-2010, 03:31 AM - Thread Starter
chickendog's Avatar
Hello,
I have an old SSW-10 subwoofer without the woofer. Could someone help me find a replacement woofer for it. I am clueless what to get.
chickendog is offline
post #2 of 4 Old 11-01-2010, 05:48 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Do you know whether the amplifier SSW-10 still works? If so, then you might consider another 10" driver.
You could contact Infinity about whether they sell a new driver or recommend a third-party driver. If Infinity (or someone else) could give you the Thiele/Small (T/S) parameters, then you might go to Parts Express (or some other reputable company) to find a 10" driver with very similar T/S parameters as a replacement.
The service manuals for JBL/Infinity subwoofers typically do not give the T/S parameters. They only give the recommended driver.
If this seems like too much of a hassle, then you might consider one of the 12" recommended subs in the ~$200 range such as BIC F12 or Premier Acoustic PA-120.
wwinkler is offline
post #3 of 4 Old 11-01-2010, 10:20 PM - Thread Starter
chickendog's Avatar
How to check if the amplifier still working? I used a volt-meter but it didn't detect anything.
post #4 of 4 Old 11-02-2010, 07:02 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
You could connect a speaker to the amp. You would also need a signal source (say from an Ipod or cd player connected into the rca input).
With just the signal source, your volt/ohm meter should give you some indication of output. If it does not, then it seems likely that the amp is dead.
wwinkler is offline
