Need help with my Martin Logan Dynamo setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-06-2010, 11:43 AM - Thread Starter
pvanosta's Avatar
Quoted: 40 Post(s)
My system:
LG 60PK550 plasma
Sony BDP 370 player
Swan Home theater speaker set(front, center, surround)
Martin Logan Dynamo Sub
Pioneer vsx 1020K receiver
The whole HT is set up and calibrated for sound using the Pioneer setup microphone.
The sub is connected via single RCA between Pio Sub Out and ML '0.1 LFE in' input.
The Dynamo manual describes this as the correct way to set up a multi-channel system.
When watching video with DD 5.1 or higher digital sound, the sub works great.
When listening to music (CD, Ipod), the sub does not get any signal. I want the sub to get signal at all times, regardless of the source.
In other words: when the receiver's display shows any other signal than 'digital', the sub gets no signal.
What am I missing? To my nowledge, the pioneer does not have an extra set of pre out plugs that I might be able to plug into the ML sub's 'right in' and 'left in' inputs.
Should I try using some of the other RCA outputs, like CDR/Tape out or DVR out?
Any advice / suggestion would be most welcome.
pvanosta is offline
post #2 of 4 Old 11-06-2010, 01:44 PM
haskin1234's Avatar
Set your speakers to small and see if that works.
haskin1234 is offline
post #3 of 4 Old 11-07-2010, 04:23 PM - Thread Starter
pvanosta's Avatar
Quoted: 40 Post(s)
Setting the speakers to small did not make a difference.
Also: any disc media (blu ray / cd / sacd) through hdmi activates the subwoofer correctly.
The Ipod through the USB port does not...
pvanosta is offline
post #4 of 4 Old 11-07-2010, 04:40 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
Use one of the surround modes, PLIIx, Neo:6, etc. That should extract a subwoofer signal from a non-HDMI source.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
