The Official HSU VTF-15H Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
Old 01-10-2011, 09:39 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
Originally Posted by ralfale View Post
In terms of low bass output 20hz n below where does vtf15 stand against pb13?
I don't think they have been compared. The pb12-plus is in the audioholics shootout with the 15H and it costs around $400 more. $ comparison between the two is closer to compare two VTF-15H to a pb13-ultra.
Originally Posted by VTF-15H View Post
I just read online that foam performs better, but rubber is more durable. Maybe the treatment on the foam helps with durability? Can someone plz confirm?
The treated foam surround on this sub seems to be very durable and I highly doubt will ever be an issue.
Luke Kamp is offline
Old 01-11-2011, 05:13 AM
sputter1's Avatar
Liked: 42
I wouldn't lose any sleep over it. Each has its use. eg downfiring you would likely want rubber.
Both rubber and foam break down.
The driver was designed for a foam surround. I trust HSU to know what they are doing.
sputter1 is offline
Old 01-11-2011, 07:18 AM
VTF-15H's Avatar
I agree. Although it is slightly alarming that this new product would be constructed of what is generally understood to be an inferior material, it may be due to engineering purposes. For example, there are parts of the space shuttle that are made out of what appears to be pieces of tin foil and styrofoam. It's quite possible that the foam is of a lighter weight and enables the woofer to move at a higher speed which is the reason for the upper mid-bass slam for such a large woofer -- who knows. And the fact that it is treated foam should alleviate any associated durability concerns.
I say we focus on performance for now and if the surrounds start tearing or falling apart then we rely on HSU to replace the surrounds under the woofer's 7 year warranty.
VTF-15H is offline
Old 01-11-2011, 07:22 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
...woofer's 7 year warranty.
This is a nice point.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
Old 01-11-2011, 08:22 AM
floridapoolboy's Avatar
I'm not trying to slam the Hsu sub because of the foam surround, the new Captivator sub apparently uses it also. I'm old school, I've seen many pictures of vintage speakers with foam rot, that's all. Of course Hsu will cover the driver for 7 years, what happens when the sub is older than that? I know, who keeps their subs that long around here, by then upgradeitus will have set in, so the question is probably moot!
floridapoolboy is offline
Old 01-11-2011, 08:26 AM
sputter1's Avatar
Liked: 42
You could re-foam it. I've never done it but folks have done it for older speakers.
I've had older speakers with foam rot out into almost dust lol, they were 18 years old at the time though.
sputter1 is offline
Old 01-11-2011, 08:42 AM
sputter1's Avatar
Liked: 42
It's only inferior from the "rot" aspect though rubber dries out as well just not as quick. Using a silicon treatment would prevent this or atleast prolong it's lifespan. I expect that's what the current foam surrounds use these days.
I haven't read anything that would suggest that foam is "significantly lower quality" I really doubt that HSU would skimp on such a small item as a surround if it was a poor performer, after all it's all tied into the driver.
my 2cents
sputter1 is offline
Old 01-11-2011, 09:56 AM
Legairre's Avatar
Quoted: 472 Post(s)
Liked: 270
With a 7 yr warranty I 'm covered. There's no way I'll have any sub for 7 yrs. My upgraditus will kick in when the next Hsu sub comes along and this one will go on the market. In four years I've I've gone from dual VTF-3 MKII, to VTF-3 HO w/turbo, to VTF-15H. As long as the Dr. keeps making them better and better I'll just keep buying.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
Old 01-11-2011, 10:29 AM
I'm currently running dual LFM-1EX subs, which should be very similar to the twin VTF3s you used to own. What is your opinion of the VTF-15 compared to your old dual setup?
Old 01-11-2011, 10:44 AM
cacihome's Avatar
Quoted: 37 Post(s)
Yep. It appears to be the same as the one on the ULS driver.
Cacimar Hernandez
cacihome is offline
Old 01-11-2011, 11:01 AM
Quoted: 76 Post(s)
Liked: 58
From the ULS-15 Product page:
"It also has a butyl rubber foam surround. Butyl rubber foam has the longevity of solid butyl rubber without the weight penalty."
If indeed they are the same material.
Old 01-11-2011, 11:54 AM
gajenn's Avatar
I'm sorry if I don't get the focus on foam over rubber if the warranty is 7 years and the company has such a good rep..why bother thinking and rethinking over this..get a different sub if it irritates u..quality of sound and db's of output for your room seem more relevant. Now for me if the spikes aren't pure titanium then I'm not interested !!!
gajenn is offline
Old 01-11-2011, 12:08 PM
Dude, this is AV Science, many of us are interested when products change in design or materials. Of the 3 popular surrounds butyl rubber half roll was long considered the best for high xmax use and longevity. Foam fell out of favor due to rot, but now seems to be making a comeback. Some of us are curious why that is, because of a performance aspect or because of cost. That's all, no irritation, just curiosity.
Old 01-11-2011, 12:12 PM
mojomike's Avatar
Liked: 30
A guy you might want to ask is Mark Seaton since he does frequent these forums. I believe the Submersive also uses some sort of foam surround. I doubt he used it in order to cut corners.
mojomike is offline
Old 01-11-2011, 12:26 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
The treated foam material used today is much better than before and very durable. Many companies are moving in that direction now and you would have to contact them to ask why. I even believe the JL subs such as the Gotham are using the foam surround now and they cost a pretty penny. The treatment keeps the foam from drying out and therefore stops deterioration.
Old 01-11-2011, 12:39 PM
jhan1000's Avatar
I think the JL Audio F112/113 uses a similar foam material as well.
http://www.avsforum.com/avs-vb/showp...postcount=1376
Here was their rationale for using foam:
http://www.avsforum.com/avs-vb/showt...6#post13425966
Life is good.
jhan1000 is offline
Old 01-11-2011, 01:47 PM
irythros's Avatar
Just got myself the 15h. With any luck, it'll ship today and even more luck, be here by the end of the week...
First 'real' sub I will have heard too. Previous setup was horrible (logitech Z5500 computer speakers and sub). Parents setup is Bose but actually has a sub and surrounds. Not the 'surround from a single box' setup.
The hard part is waiting
Really been looking forward to blowing my room apart.
irythros is offline
Old 01-11-2011, 02:27 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
You are in for a real treat if never heard a true sub before! Contact HSU as they will give advice on setup and placement as will the forum. Let us know impressions after proper setup!
Old 01-11-2011, 11:15 PM
Legairre's Avatar
Quoted: 472 Post(s)
Liked: 270
Well the dual VTF3 MK2 setup was outperformed by my VTF-3 HO w/turbo and the VTF-15 easily outperform the VTF-3 HO w/turbo. There's just no comparision between the dual VTF3 MK2 setup and the VTF-15H. The VTF-15H moves a lot more air than the HO even with the turbo and would just put the dual VTF3 MK2 setup to shame. There's just simply no comparison, the 15H is incredibly power. I used to think the HO w/turbo was powerful until I got the 15H. The 15H just loafs along like it's not even breaking a sweat.
Old 01-12-2011, 07:35 AM
VTF-15H's Avatar
Mine should be getting here tomorrow, depending on the weather. The FedEx tracker has a snow storm warning that delivery may be delayed. What are the most popular settings?
So far it looks like this is the most popular for movies:
- Open
- EQ2
- Q.03
And this is the most popular for music:
- Sealed
- EQ1
- Q.07
I plan on keeping it set at the movie mode, then switching to music mode for parties, etc., where music will be played for extended periods of time (I just figured out how to stream my music from my iTunes library on my laptop to my PS3 )...
VTF-15H is offline
Old 01-12-2011, 07:56 AM
Robert760's Avatar
Try ports open and eq2 q.07 that setting is nice i have my vtf15 duals that way
Robert760 is offline
Old 01-12-2011, 09:12 AM
sputter1's Avatar
Liked: 42
Oddly enough or not, I prefer one open port, EQ-1 Q=.3.
That's beauty of this sub, you have 5 modes to play with.
My SMS-1 allows me to check visually of all the options.
sputter1 is offline
Old 01-12-2011, 12:03 PM
carlm9's Avatar
I am close to ordering (1) or (2) of these up to replace some SVS PC-13 Ultra's but want to make sure it is going to be an improvement.
Are there any people out there that can give a comparision between the SVS Ultra and the VTF-15H? Thanks for your help.
Jason
carlm9 is offline
Old 01-12-2011, 12:08 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
What sort of improvement are you looking for? The PC-13Ultra is a great sub.
Any changes, positive or negative, IMO, wouldn't be with the effort....unless you are looking at aesthetics.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
Old 01-12-2011, 12:18 PM
irythros's Avatar
Unfortunately placement cannot be helped on, and proper setup cant be done
My room is so small, it can only be put in 1 of 2 spots. I also dont have an SPL meter or decent mic for REW. Not ideal, but cant do much...
I will let you know how much damage is done in the first day, assuming the foundation holds out
irythros is offline
Old 01-12-2011, 12:47 PM
mrcoop's Avatar
Quoted: 35 Post(s)
Liked: 52
Jason
if you have 2 pc-13 and looking to replace with 2 vtf15's...IMO, that would probably be a lateral move if not a step down in output...IMO, you would see no improvement.
mrcoop is offline
Old 01-12-2011, 02:36 PM
carlm9's Avatar
I didn't know if the VTF-15H would have more output than my SVS. If it did, I would consider moving forward. Asthetics do play a little part of it, everyone always asks "What are those two big cat toys doing back there"?
carlm9 is offline
Old 01-12-2011, 02:38 PM
carlm9's Avatar
Thanks Mrcoop,
It just suprises me that nobody has done a comparison on these two. Thanks
jason
carlm9 is offline
Old 01-12-2011, 02:41 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
I have to agree with the above, the PC13 Ultra is a hell of a sub. I don't think you will see a big improvement by trading two PC13s for two VTF-15s. On the other hand, you could make some money by selling the PC13's and going with the VTF-15s without losing much in the way of performance.
shadyJ is offline
Old 01-12-2011, 02:59 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
The new Hsu has only been available for 2 months. I don't think many people owning an Ultra are in the market for a new sub.
-curtis
cschang is offline
Subwoofers , Hsu Research , Hsu Vtf 15h Subwoofer
