The Official HSU VTF-15H Thread - Page 89 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
Old 04-12-2012, 04:19 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Originally Posted by saltysteven View Post
I'm not doubt this monster for one second when it comes to movies but music is different. Let's say something with alot of bass like dance music. Its a constant bass beat. At the 9 position its way to much!!! Its just over powers the speakers and way to much exaggerated bass. Another question is should I have the enhanced button on or off?
Setting to 9 o'clock will certainly be too much! In our demo room, our 15H is set at 1/3 way up between minimum and 9 o'clock.
Also, if you want more mid bass, use the sub as an end table to your left as you look at your TV. Set the sub to two ports open, EQ2, Q=0.3.
dr_hsu is offline
sputter1's Avatar
Liked: 42
Originally Posted by oztech View Post
It makes me wonder just how accurate those little toy mics are that come with receivers especially in the lower regions.
I think it would depend on the AVR, Pioneer not so much but with Audy equiped AVRs I would expect better.
sputter1 is offline
Old 04-12-2012, 04:39 PM
shumi_9's Avatar
Quoted: 12 Post(s)
Ok,
this is it guys, I can not squeeze any more out of it, given the middle of the room LP constraint. +/- 2.5 db across the entire FR, I will take it!! Lenghts of subs increased from 10.8 feet (both) to 11.2 feet (both). Any additional increases in lenght started causing a significant drop in frequencies higher that 80 Hz.Blue curve is pre Audyssey, green is post. Darn shame that the Eqing causes a lot of bass extension to go bye bye.
shumi_9 is offline
Old 04-12-2012, 04:49 PM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 44
Originally Posted by shumi_9 View Post
Ok,
No really that green trace looks great.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
Old 04-12-2012, 04:52 PM
saltysteven's Avatar
That's exactly true! That's how I have it now. I'm just working around blending everything. Still looking for less low and more mid for music only. Movies I think will be ridiculously awesome!
saltysteven is offline
Old 04-12-2012, 05:38 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Ok,
this is it guys, I can not squeeze any more out of it, given the middle of the room LP constraint. +/- 2.5 db across the entire FR, I will take it!! Lengths of subs increased from 10.8 feet (both) to 11.2 feet (both). Any additional increases in length started causing a significant drop in frequencies higher that 80 Hz.Blue curve is pre Audyssey, green is post. Darn shame that the Eqing causes a lot of bass extension to go bye bye.
I am really impressed how flat the response is even without EQ. Audyssey is only applying a few dB corrections here and there for the subwoofer. +/- 2.5 dB down to 13, 14 Hz is quite fantastic!
dr_hsu is offline
Old 04-12-2012, 05:42 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
With the SPL meter, measure the response at your listening chair. Map it from 20 Hz up to 200 Hz. Try to adjust the sub level so the average of 31.5 to 63 Hz is the same as 100 - 200 Hz. If the Yamaha has multi-band equalizers that applies to the subwoofer out, you can use those to try to smooth out the response. (I do not have any Yamaha so I don't know the details).
Forgot to mention this is assuming an 80 Hz crossover. You basically want the subwoofer average output to be similar to the average output of your main speakers near the crossover.
dr_hsu is offline
Old 04-12-2012, 05:52 PM
shumi_9's Avatar
Quoted: 12 Post(s)
Thanks guys....I did forget to mention I have approximately $5000 worth of Acoustic Science room treatment products...
shumi_9 is offline
Old 04-12-2012, 05:59 PM
the Son's Avatar
Awww. Hopefully tonight's dream is your 15H gave birth to three more 15Hs and you end up with a 15H quad drive...
My pair had twins!
the Son is offline
Old 04-12-2012, 06:13 PM
SQAudiophile's Avatar
Holy bass nuggets! That is sweet.
SQAudiophile is offline
Old 04-12-2012, 06:25 PM
Venomous's Avatar
Originally Posted by hometheatergeek View Post
I'm sorry but where did you read or learn this? My subs impressed a sound engineer who was over my house last weekend. I played him some of the 16Hz info on the first track on the Hsu CD. I have a yammy and used Ypao to setup my system then fine tuned the subs after running Ypao. In fact some of the other installs that I have done using Audyssey required sub adjustments after the auto cal ran. This requires adusting trim levels and distance settings to get the subs in perfect phase with the main speakers. He was so impressed he thought one of my ULS-15s nearest to the LP was turned off.
It's quite easy to take your own measurements with REW and a calibrated mic. See where your bass lands with ypao from 30hz to 5 hz... Then look at how many db's are being measured between those spectrums. I'm not the only one seeing this with ypao either. Seems everyone and there mother with ypao setups are in denial about it and coming out of the woodwork to attack me about it.
It's easy to solve this problem by eqing the sub yourself. If your sound engineer buddy was so impressed with your ypao sub EQ settings, he would be further impressed with a manual calibration done on your subs.
Venomous is offline
Old 04-12-2012, 06:39 PM
rwe416's Avatar
I am looking at getting an SPL meter. I have the Denon 2112ci avr. What do I do to set things using the meter? Sorry for the newb question but I am trying to learn. I have read the threads but still confused. Is there one that gives step by step instructions?
rwe416 is offline
Old 04-12-2012, 07:22 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Originally Posted by the Son View Post
My pair had twins!
Sweet! I see you had the top two in sealed mode. Any reason?
dr_hsu is offline
Old 04-12-2012, 07:45 PM
sputter1's Avatar
Liked: 42
They are fake Two are real and two just have the grills.
sputter1 is offline
Old 04-12-2012, 07:50 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
That is a very realistic looking fake
dr_hsu is offline
Old 04-12-2012, 08:47 PM
jsgrise's Avatar
Quoted: 233 Post(s)
Liked: 137
Sounds like a wet dream to me!! XD
Dedicated HT | FRONTS: Sonus Faber Venere 1.5 CENTER: Sonus Faber Venere Centre SURROUNDS: Sonus Faber Venere Walls RECEIVER: Marantz SR-7010 SUBWOOFERS: DUAL 18" Dayton RSS460HO Custom Build | Behringer iNuke 6000DSP | Velodyne SMS-1 DISPLAY: JVC D-ILA RS-46 w/ 128" 16:9 1.4 TREATMENT: Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
Old 04-12-2012, 09:41 PM
the Son's Avatar
Yup. I had an issue with placement of 2 subs and all my AV gear. 2 custom racks took care of it for me. I don't like my design, but the aesthetics worked out perfect!!
The "port plugs" are black felt to cover the fake ports. Here's my thread with more pics:
http://www.avsforum.com/avs-vb/showthread.php?t=1385689
the Son is offline
Old 04-12-2012, 09:53 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Wow, really cool job!
dr_hsu is offline
Old 04-12-2012, 10:34 PM
the Son's Avatar
Thanks!!
the Son is offline
Old 04-13-2012, 04:31 AM
Quoted: 40 Post(s)
Liked: 44
My subs were calibrated manually by a professional....ME. I am not some fly by night joe six pack. I installed HTs professionally in a previous job. I did installs before there even was Auto Calibration software so I am very versed in doing manual calibrations. Your statement that it robs the output below 30Hz is nonsense when I look at the graphs with my ULS-15s. I have strong 16Hz output. So the process with YPAO is to let it run then finely adjust the settings after it has finished.
Your statement "Seems everyone and there mother with ypao setups are in denial" is because they are taking the defaults when they run the Auto cal. There are actually three different EQs to choose from....Flat....Natural...and Front plus the fourth setting of EQ Off. In order to get the proper EQ for a particular room all of the EQ should be tried and measured. In fact with the memory settings on the Yamaha it is wise to run all four different EQs then save each one, were by you can change the EQ on the fly.
So with all of that said I will bow out of this thread since I do not own the VTF-15.
Hometheatergeek
aka AL
My Current System
Old 04-13-2012, 04:33 AM
eric-t's Avatar
The mic equipped with an Anthem receiver is very accurate and nice. It's made of metal and not a cheap plastic version.
Attachment 243420
eric-t is offline
Old 04-13-2012, 09:33 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
You do NOT have to own a 15H to contribute on this thread! Please continue to contribute....
dr_hsu is offline
Old 04-13-2012, 09:37 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Attachment 243420
I certainly hope so - at that price, I would expect a high quality mic. More importantly, if they can provide a calibrated mic, that would be best. Even if the mics have large unit to unit variations, as long as the receiver has the calibration curve, and can use it to compensate, you are fine. Unfortunately I don't think any of them do that...
dr_hsu is offline
Old 04-13-2012, 10:09 AM
eric-t's Avatar
ARC does.. Each mic has the mic calibration file included in the included cd. If you ever get a new mic, one must remember to install the new file that comes with it. Another words, the software is married to each mic.
eric-t is offline
Old 04-13-2012, 10:31 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
Attachment 243420
At one time, the Audyssey mics and RS SPL meter were considered fairly accurate in competent hands. I don't know if that is the general AVS collective consensus anymore.
There was also a an interesting thread with tests against a calibrated mic.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
Old 04-13-2012, 12:28 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
That is good to know! Sounds like they know what they are doing.
dr_hsu is offline
Old 04-13-2012, 01:02 PM
Venomous's Avatar
Yeah typical response... Ypao sucks eqing subs, pure and simple. Isn't the point of autocal to do less work? Just manually calibrate it like I said earlier....saves yourself a headache. Run ypao without the sub and go back to calibrate it at the end. It will probably save yourself an easy hour if not more.
This is where audyssey shines. It eq's subs pretty damn good on auto cal. Hell the whole system autocals pretty damn well.
I'm quite aware of the EQ options in ypao. I may not be a professional in the business but dont assume we're all stupid. If you were able to learn how to calibrate and the hundred others on this forum, I'm sure we have too. Ignorance is bless isn't it?
Venomous is offline
Old 04-13-2012, 01:32 PM
Quoted: 40 Post(s)
Liked: 44
Why are you such an angry poster? I never called you stupid or anyone else. Unless you have the latest Audyssey with XT32, the older versions, MultiXT and EQ2, could also mess up when EQing the low end and required additonal tweaking to get it right. You're quite the character.
Hometheatergeek
aka AL
My Current System
Old 04-13-2012, 03:18 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
What are the hard facts about YPAO's sub EQing? Does anyone have any graphs? Any technical info on how YPAO handles subs? I have read a lot of speculation about YPAO's abilities or lack thereof for subwoofers, but I haven't seen anything concrete from Yamaha or measurements from anywhere else.
shadyJ is offline
Old 04-13-2012, 04:19 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Yes, some before/after auto EQ curves would be interesting.
dr_hsu is offline
Subwoofers , Hsu Research , Hsu Vtf 15h Subwoofer
