The Official HSU VTF-15H Thread - Page 92 - AVS Forum | Home Theater Discussions And Reviews
 17Likes
post #2731 of 5283 Old 05-11-2012, 01:54 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Originally Posted by Mike Lang View Post
Sure, this is quick & ugly but should have all the info...
You may want to try with the door to the back unfinished room open and the door to the unfinished storage room behind the entertainment center closed. May give you better deep bass.
dr_hsu is offline
post #2732 of 5283 Old 05-11-2012, 01:57 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
OK, will do.
Thread title has been updated based on feedback.
Mike Lang, Administrator
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Join the AVS Forum Club and help support the site. Help Support AVS Forum Sponsors.
AVS Forum is not sponsored by or in any way affiliated with AV Science Inc.
Mike Lang is offline
post #2733 of 5283 Old 05-11-2012, 09:22 PM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
OK, will do.
Congrats on the duals, should definitely notice a difference. Warning: Going to have to put some time aside, because after you watch your first movie will have to watch your entire collection again. I have never put the feet on my pair sitting on carpet and padding over concrete.
PS: Thanks for updating thread title.
Luke Kamp is offline
post #2734 of 5283 Old 05-11-2012, 09:24 PM
pokekevin's Avatar
Liked: 102
OK, will do.
Finally haha
pokekevin is offline
post #2735 of 5283 Old 05-13-2012, 07:05 AM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
I wonder if I'll even still need the Buttkickers.
post #2736 of 5283 Old 05-13-2012, 10:02 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Probably not!
dr_hsu is offline
post #2737 of 5283 Old 05-15-2012, 02:41 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
The plasma stand has been rebuilt and I'm ready. FedEx says two more days.
So with two of them next to each other, do I still want them each set to 1 port open EQ1, Q=0.7 for Audyssey?
post #2738 of 5283 Old 05-15-2012, 04:49 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Yes, you still want to do that. After Audyssey calibration, I would set them to two ports open, EQ2, Q=0.3.
dr_hsu is offline
post #2739 of 5283 Old 05-15-2012, 05:03 PM
pokekevin's Avatar
Liked: 102
Wow! They fit perfect! Very clean set up!
post #2740 of 5283 Old 05-15-2012, 05:12 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
Those are still my old Energy subs.
I made the shelves above them adjustable for a custom fit once they arrive. They'll need to go up higher than that.
post #2741 of 5283 Old 05-15-2012, 05:14 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
Will do. Thanks!
post #2742 of 5283 Old 05-15-2012, 05:18 PM
pokekevin's Avatar
Liked: 102
2 ports for max output? Don't want the extension?
post #2743 of 5283 Old 05-17-2012, 06:03 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
For most programs, bass does not go that low. Due to room gain in the low bass, a lot of times even in two ports open mode you get strong bass down to below 20 Hz. In our demo room, with two ports open, we get bass flat down to 16 Hz. In the two ports open, EQ2, Q=0.3 mode, you have more headroom. For program that does go ultra low, by all means set to one port open, EQ1.
dr_hsu is offline
post #2744 of 5283 Old 05-17-2012, 04:38 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
They're both in place but I haven't had much time to play with them yet.
A couple oddities:
Audyssey turned them way down to -13.0db making them barely noticeable compared to my old Energy subs. No idea what Audyssey had those set to.
While side by side, you can see than one is hitting MUCH harder than the other even though they are both at two ports open, EQ2, Q=0.3, level at 9 o'clock.
post #2745 of 5283 Old 05-17-2012, 04:46 PM
oztech's Avatar
Liked: 101
A couple oddities:
Some people myself included when level matched have had to turn the sub gain down to 8:30 so AVR output would be close to -2 or -3.
Not sure why the difference in the two subs have you tried swapping the inputs or cables.
oztech is offline
post #2746 of 5283 Old 05-17-2012, 05:29 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
A couple oddities:
You need to gain match the subwoofers first. Also, you need to set the subwoofer level lower. When Audyssey sets the subout at -12, it means the gain on the subs are set too high. Set the subs to 8 o'clock instead.
To gain match, place one sub in one spot. Mark the spot so you can place the second sub in exactly the same position later. Play a 50 Hz test tone. Adjust the receiver's volume to get 80 dB on a SPL meter placed 1 m in front of the sub (volume on the sub set to 8 o'clock). Now move that sub out pf the way and put the second sub in the same location. Play the same tone and adjust the volume on the second sub to get the same 80 dB reading. Now they are gain matched.
dr_hsu is offline
post #2747 of 5283 Old 05-17-2012, 07:07 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
I'll dust off the old Radio Shack meter as soon as I get a chance and report back how it went.
post #2748 of 5283 Old 05-18-2012, 01:12 PM
Administrator
Administrator
Mike Lang's Avatar
Quoted: 883 Post(s)
Liked: 697
OK, gain matching @ 50 Hz to 80 dB starting with the sub that was hitting harder dialed back to 8 o'clock put the "weaker" sub at about the 9:30 mark to match.
Audyssey now has the subs set to -8 instead of -13.
I also ditched the Y-adapters that were splitting my receiver's one sub output to both subs and the Buttkicker amp and threw in an Audio Authority 985U I wasn't using anymore in hopes of getting a better signal to everything.
I haven't had a chance to play any real material yet today but fingers crossed.
post #2749 of 5283 Old 05-18-2012, 11:42 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
If Audyssey set it to -8, it's better to lower the volume on the subs further. I feel more comfortable with the sub out level on the receiver between -3 to +3.
You do not have to both subs in the same location. Just run the subs one at a time. Turn on sub 1. Play the 50 Hz tone and place SPL meter 1 ft in front of it. Turn up the receiver's master volume to get 85 dB. Turn down the subwoofer volume to get 80 dB. Turn off sub 1 and turn on sub 2. Place SPL meter 1 ft in front of sub 2. Adjust master volume on receiver to get 85 dB. Turn down subwoofer volume on sub 2 to get 80 dB. Now both subs are 5 dB lower in output. Re-run Audyssey (with the subs at 1 port open, EQ1, Q=0.7) and now it should have the sub out at -3. After Audyssey re-run, set to two ports open, EQ2, Q=0.3.
dr_hsu is offline
post #2750 of 5283 Old 05-20-2012, 11:49 AM
rwe416's Avatar
I ran audyssey on my Denon 2112ci this morning and had to set the volume control almost to min. Is this right? I would run the calibration and check where the sub was set. To get it to -1.5db I had to turn the sub to almost the min setting. I ran the calibration with EQ1,Q=0.7 and 1 port open.
rwe416 is offline
post #2751 of 5283 Old 05-20-2012, 12:04 PM
asere's Avatar
Quoted: 1387 Post(s)
Liked: 269
Yes all is right including the one port open, eq 1, q7!
asere is online now
post #2752 of 5283 Old 05-20-2012, 04:04 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
That is right. The 15H has lots of gain.
dr_hsu is offline
post #2753 of 5283 Old 05-29-2012, 11:03 AM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
Well I just put an order in yesterday for the 15h to replace my Outlaw Plus and I am really excited. I was trying to hold off on ordering because I am about to move in the next month, but I am curious to hear the difference between the space I have now and the larger space in the new house. I originally wanted a HSU, but let price get in the way of my decision at the time. Oh well, live and learn!
Life is hard, be harder.
Saints is offline
post #2754 of 5283 Old 05-29-2012, 12:33 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Welcome to the Hsu family! Do post your room layouts so we can give you some placement suggestions. What receiver and speakers will you be using with the sub? If your room opens into other rooms, include the adjoining spaces in your room layout.
dr_hsu is offline
post #2755 of 5283 Old 05-29-2012, 12:56 PM
Saints's Avatar
Quoted: 14 Post(s)
Liked: 29
I will be using the 15h with a Denon 4311, Energy RC-70s, RC-LCR and RC-10s as rears. I also have some Take classics laying around for height/wides or rears which I may upgrade when I get in the new house. I will post dimensions as soon as the appraisal comes back with all of that info. The house i am in now only has one placement option which isnt optimal, but it works and is only for another month. Thanks for the welcome!
Saints is offline
post #2756 of 5283 Old 06-06-2012, 09:38 AM
South Park's Avatar
Quoted: 59 Post(s)
Liked: 118
We bought the VTF-15H a few month ago and now we matched our setup with two HB-1 MK2 Bookshelf Speakers and one HC-1 MK2 Center Channel Speaker. We found the perfect speaker stands for the HB-1 MK2 here: http://www.amazon.com/gp/product/B0006G1IJ0/ref=oh_details_o01_s01_i00 Vantage Point SSB-30BB speaker stands are the perfect fit for the HB-1 MK2 and they look just great together.
So, what about the sound? For the last 8 years we used small Energy Speakers and they were great little speakers, big in sound. Replacing them with the HSU speakers was a big step forward in sound quality overall, music and movies are much more “full” in sound and more detailed and I might say almost palpable as well. Watching “Eric Clapton's 2010 Crossroads Guitar Festival” on Blu-ray is now a totally different experience.
Using our Pioneer SC-09TX (Susano) with 80Hz crossover seems to be the best and perfect match for the speakers. On the VTF-15H still using
- 2 ports open
- EQ 2
- Volume 9:30
- Phase 0
- Q-Control 0.4
with awesome strong stomach punching mid-bass at medium to high playback levels.
Thank you HSU Team giving us a such great speakers for a small price. Kudos to you!
South Park is offline
post #2757 of 5283 Old 06-06-2012, 12:46 PM
vtnzr's Avatar
Hi guys,
Being a new father and approaching Father's Day... I gotta ask, do VTF-15h ever go on sale? Maybe free shipping or shouldn't day dream
vtnzr is offline
post #2758 of 5283 Old 06-06-2012, 12:48 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
- 2 ports open
- EQ 2
- Volume 9:30
- Phase 0
- Q-Control 0.4
Thank you so much for your kind words! Glad you loved our equipment.
dr_hsu is offline
post #2759 of 5283 Old 06-06-2012, 12:54 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Originally Posted by vtnzr View Post
Hi guys,
Sorry, no. With the price increases from our vendor, we already find it hard to maintain the current pricing. It is effectively on sale considering that we have less profit selling them now without increasing the price.
dr_hsu is offline
post #2760 of 5283 Old 06-09-2012, 11:37 AM
Stylz25's Avatar
What would you guys choose? I have the Paradigm DSP-3400 and 3200 but selling the 3200... My room is about 3000 cubic feet and its mostly for movies with gaming and some music!.....I like dual subs but I know your not supposed to mismatch subs and why I am curious on the selections. I want something that will last a very long time!
1 - Buy a SVS PB13-Ultra up front with the 3400 in the back = around $2000
2 - sell both 3400,3200 and get 2 SVS PB12-Plus's = about $3000
3 - Sell both and get 2 HSU VTF-15H's = give or take $2600-$2800 since I live in Canada
Question - Would 1 SVS PB13-Ultra beat out 2 HSU VTF-15H's?????
Stylz25 is offline
Subwoofers , Hsu Research , Hsu Vtf 15h Subwoofer
