Dual DTS-10's and dual CS 18.2's - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 718 Old 11-24-2010, 09:00 AM - Thread Starter
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1119
Originally Posted by mojomike View Post
That's the best looking response curve I've ever seen from your room. I'm amazed that you didn't quit upgrading right there.
Which one? My newest one is actually better but I did not turn it up yet. That eD graph was 10 db increments and the new one is 5db.
Marantz 7702 Atmos
MKtheater is offline
post #92 of 718 Old 11-24-2010, 09:18 AM
mojomike's Avatar
Liked: 30
I'm referring to the old 8-18" curve.
mojomike is offline
post #93 of 718 Old 11-24-2010, 09:33 AM
musicaddict's Avatar
mk, do you still like the danley's? Have you or anyone else heard the jtr orbit shifter? I have seen some pics of the outside of the orbit shifter but it doesn't look like a horn compared to the danley (haven't seen the insides of the orbit shifter though).
musicaddict is offline
post #94 of 718 Old 11-24-2010, 09:41 AM - Thread Starter
MKtheater's Avatar
Liked: 1119
If you look closer you will see that graph goes from 121-122dbs to 110 dbs, so +/-6 dbs. The newer one goes from 85-92dbs or +/-3.5dbs.
Marantz 7702 Atmos
post #95 of 718 Old 11-24-2010, 09:42 AM - Thread Starter
MKtheater's Avatar
Liked: 1119
Never heard the OS. Yes, I still like the Danleys.
Marantz 7702 Atmos
post #96 of 718 Old 11-24-2010, 09:45 AM
mojomike's Avatar
Liked: 30
Good point, but still it looks so smooth and extended.
mojomike is offline
post #97 of 718 Old 11-24-2010, 09:47 AM - Thread Starter
MKtheater's Avatar
Liked: 1119
I will post the same graph with 10db increments. It did go from 5-80hz and this one goes from 8.79-72hz. Let's wait for the front placement. I will try to get each set flat as possible(with placement) and see if I can fit all 4 up there(that will be very tricky if impossible).
Marantz 7702 Atmos
post #98 of 718 Old 11-24-2010, 10:17 AM
spanish68's Avatar
The idea of running the Danley's together vs separate with the 18.2 is an interesting one. Perhaps letting the Danley's work below the 30-40hz range and running the 18.2 above the 30-40hz range will be your best set-up. You get the killer low end the Danley's provide with the improved mid-bass of the 18.2. It should make your room bass integration easier to set-up too (not having to dial in two separate brand subs) doing the same frequency. Anyways, have fun testing both methods and sub placement options in your room.
spanish68 is offline
post #99 of 718 Old 11-24-2010, 10:18 AM - Thread Starter
MKtheater's Avatar
Liked: 1119
I think you are right but I have to try out all the options.
Marantz 7702 Atmos
post #100 of 718 Old 11-24-2010, 01:13 PM
t6902wf's Avatar
Time for a bigger room, break out the backhoe!
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #101 of 718 Old 11-24-2010, 01:33 PM
penngray's Avatar
Liked: 43
Like others have mentioned already, We should be aware that MKs rooms is like no other I have seen measurements from. He has the best room for low frequency gain meaning you put any quality sub in that room and he is going to have great low frequency peformance. We have seen measurements from similar designs in other rooms that do not remotely match his room.
Sadly, His performance and conclusions are not going to match ours.
penngray is offline
post #102 of 718 Old 11-24-2010, 01:36 PM
penngray's Avatar
Liked: 43
He will come full circle at some point
Nothing can replace displacement down low.
penngray is offline
post #103 of 718 Old 11-24-2010, 01:41 PM
Decadent_Spectre's Avatar
Quoted: 322 Post(s)
Liked: 144
Is the room/positioning removing all of the mid bass from the Danley or is it EQed that way? Its natural outdoor plots show a rising response in the mid bass rather than vice versa.
Decadent_Spectre is offline
post #104 of 718 Old 11-24-2010, 01:43 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
I agree, but right now with 4 18's and 2 dts-10's extension is not difficult. Wait until I put them in front. I will admit that sealed subs are much easier to get flat in my room because wherever the tune is on a ported sun creates a huge peak in my room.
Marantz 7702 Atmos
post #105 of 718 Old 11-24-2010, 01:55 PM
penngray's Avatar
Liked: 43
Extension with that much displacement is easy and your room is just amazing.
If you are still going to run them together, I do not see why putting in front together is beneficial. Other then doing some measurements for others. There is a lot of tweaking that is needed to get them to play properly together do you have the ability to set individual delays??
I would place the 18s around the room to smooth out the upper bass response.
penngray is offline
post #106 of 718 Old 11-24-2010, 02:00 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
Penn, I already got them +/- 3.5 dbs from 8-72hz together without EQ the way they are.
Marantz 7702 Atmos
post #107 of 718 Old 11-24-2010, 02:02 PM
penngray's Avatar
Liked: 43
Right, so the move to the front to combine them all is just a test?
penngray is offline
post #108 of 718 Old 11-24-2010, 02:09 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
Yes, I really want to see the Danleys orientated differently as I remember having them much flatter. I think I was moving them around for the best sound and ended up like this but I never measured them here.
Marantz 7702 Atmos
post #109 of 718 Old 11-24-2010, 02:59 PM
spyboy's Avatar
Liked: 47
So, even though you moved the DT's around till you found the best sound, you are going to move them for best looking FR graph? Or am I missing that the 18 inchers are going to somehow negate the best sound placement you got without the 18's?
spyboy is offline
post #110 of 718 Old 11-24-2010, 03:05 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
...... He has the best room for low frequency gain meaning you put any quality sub in that room and he is going to have great low frequency peformance. We have seen measurements from similar designs in other rooms that do not remotely match his room.......
Another nice, small, bunker like, high PVG room, is Japan Dave's on the Seaton forum.
He is aproaching it with ample LF displacement.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #111 of 718 Old 11-24-2010, 03:17 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
Best sound without knowing how much midbass I was missing. I am experimenting right now. I do want to make an apples to apples comparison and I will run the DTS-10's with a 5hz amp as my ashly's rolloff at 10hz so they may go even deeper in my room. I don't think so because I have used the EP-4000's with them and I think they rolled off at the same spot.
Let's keep this fun. I know I am having fun. When I tried the SHO-10's and knew going in that my JBL should be better, I have the same idea with this.
Marantz 7702 Atmos
post #112 of 718 Old 11-24-2010, 04:25 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
"LTD02, the question why was for this:
When my CS 18.2's were flattened and leveled matched to the Danleys they still did not have the same amount of low end brute force. They were +/-5dbs to 7hz to my XO. That is the why, if both systems were flat to 7-9hz and level matched they should both have the same low end, no?"
no. the danleys are somewhere around 12db more sensitive at 20hz than an 18.2, so the 18.2's will require almost ~15-20 times as much power to hit the same spl. the massive low end grunt coming out of your danleys when eq'd the same as the 18.2's is likely the result of this higher spl capability and to a lesser extent either a lack of amplifier clipping or a lack of power compression in the drivers themselves. a fairer 20hz fight might be two or three 18.2's vs one dts-10. danley built them large precisely to achieve high sensitivity at low frequencies.
[edit: had to re-adjust the numbers. i keep forgetting that danley uses 2.83v, not 1w sensitivity.]
Listen. It's All Good.
LTD02 is offline
post #113 of 718 Old 11-24-2010, 04:42 PM
LTD02's Avatar
Liked: 2577
just so that it is clear to everybody, craig's approach to the cs18.2 design, in my humble opinion, is very, very good. it is a winner in its class.
LTD02 is offline
post #114 of 718 Old 11-24-2010, 07:03 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
Thanks LTD02. Here is my next question. Assuming I have enough amp power for either design(I do) and I am not running max spl's(I am not) setting both subs to the same level and having a similar response curve they should hit say 120 db's at 20hz when called upon because neither are at their limits, no? I put the CS 18.2's purposely in the back corners because I get a 10db boost back there compared to the front so any advantage the Danleys have should be wiped out. I guess I can leave the CS's where they are and get them flat and then orientate the DTS's so they are flat and then compare. To be honest with my room the advantage should go to the cs's with that 10db gain. I am going to test this first.
Marantz 7702 Atmos
post #115 of 718 Old 11-24-2010, 08:21 PM
LTD02's Avatar
Liked: 2577
"Here is my next question. Assuming I have enough amp power for either design(I do) and I am not running max spl's(I am not) setting both subs to the same level and having a similar response curve they should hit say 120 db's at 20hz when called upon because neither are at their limits, no?"
mk, i kind of hate to say this, but i'm thinking that your assumptions may be wrong on this one and maybe even your measuring technique. how did you establish that you have enough amp power and that neither your subs are clipping nor your speakers compressing from high current?
the first step would be to eliminate differences in placement. measure both subs in the same spot.
the second step would be to eliminate differences in e.q. as you have posted, yours are huge. this affects frequency dependent efficiency. the sealed subs will require a lot of eq (low end boost) relative to the dts subs.
the third step would be to eliminate differences in the amplifier (i.e. pick one and swap it between the subs.)
now measure each one and see how it performs.
the danley is going to have a ton more low end efficiency (in the bottom octave and a half or so 10-30hz).
predicted is a cleaner, meaner, lower, louder subjective sound. this is what you report. no surprises here.
LTD02 is offline
post #116 of 718 Old 11-25-2010, 06:08 AM
penngray's Avatar
Liked: 43
Maybe my HT 2.0 project should include modifying my room height to get higher PVG.
penngray is offline
post #117 of 718 Old 11-25-2010, 08:06 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Man the attention to detail in Japan Dave's room is on another level!
gpmbc is offline
post #118 of 718 Old 11-26-2010, 10:09 PM - Thread Starter
MKtheater's Avatar
Liked: 1119
I am hearing a more pronounced low end from the Danleys because I have a huge peak there. I am right now moving them all over to bring down that peak. Moving 2 300 pounds subs all day is not fun but all this time the Danley's low end has been 10-15dbs higher than its midbass. When I compare other subs to them they all lack the low end due to this giant peak. I am posting some graphs to show what I mean. The Danleys do not lack any midbass, it was just the position in my room. I have moved them to 4 different locations and now hauling them in the back just to measure them. I want to bring down that peak and then listen to see if that was the difference.
Marantz 7702 Atmos
post #119 of 718 Old 11-27-2010, 05:55 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I use those furniture slider pucks and it makes moving mine pretty easy.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #120 of 718 Old 11-27-2010, 08:29 AM - Thread Starter
MKtheater's Avatar
Liked: 1119
I have to lift them up above my steps. I am putting them in the back to measure them.
Marantz 7702 Atmos
