HSU STF-1 amp bad. Anyone ever fixed theirs? - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2010, 06:45 PM - Thread Starter
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The BASH amp is kaput in this thing. Anyone ever had any luck diagnosing and repairing one of these amps?
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 11-21-2010, 04:53 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
All the amps are fairly similar. You probably need the service manual because it gives the details of the circuits. A few individuals have fixed theirs without a service manual. You need a volt/ohm meter and a soldering gun (along with the device that allows you to suck up the melted solder).
The main electrolytic capacitor is the first thing to look at. They deteriorate with heat and age. Also any blackened device should be replaced along with the devices on each side of it (if they test poorly).
That stated, I decided to get a PE 500w BASH amp and just replace the existing amp that I had on a 15" subwoofer. A difficulty is getting plate amps that are almost the same size as the the existing plate amp.
The PE BASH amps are on sale until December 31.
Addendum: Quick repair. I told my son to glue 2"x4"s in a rectangular shape to the back of the subwoofer. After lengthening the wires that went from the amp to the driver, he merely screwed the amp to the 2"x4"s.
wwinkler is offline
Old 11-21-2010, 06:14 AM - Thread Starter
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Ya I saw the sale on the PE amps. Very tempting. The caps were the first thing I looked at. They are fine. Pat that I'm pretty lost. Emailed HSU asking for a price on a replacement. If it's the same price as the PE then it's just a matter of swapping. Not looking forward to having to try and make a new amp fit.
Old 11-21-2010, 10:15 AM
JackOften's Avatar
You could call also. Pete's usually on top of this stuff.
JackOften is offline
Old 11-21-2010, 08:30 PM - Thread Starter
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Got a reply back. New amp $150. Ouch! I realize he's in business to make a profit but that's a bit steep for what you get. I think I'll grab one of the PE 300W BASH amps for $99 and modify it to fit. 2/3 the price and double the power.
Old 10-04-2011, 01:02 PM
99RedSi's Avatar
flyng_fool - sent you a PM - thanks!
Zoom-Zoom
99RedSi is offline
