Need help buying a subwoofer that is less that 13" tall - AVS Forum
post #1 of 3 Old 11-29-2010, 07:11 PM - Thread Starter
pigeonnest's Avatar
My Infinity tss 1100 sub crapped out and I need a sub asap, it sounds terrible without one.
I have a large living room it's 28' x 18' and flows into another room 12 x 12.
We recently put I piano in the only corner a sub can go.
My problem is I am trying to find one to put in this stone planter beside my fireplace it can only be 13" tall but can be up to 3 feet long or 2 feet wide.
I don't wan't to spend more than $200 to match my tss 1100 system.
The only time I really like it to bump is when I listen to music, as my tv has no speakers and the stereo is used full time. It gets preety anoying hearing sponge bob thumping and rumbling all day.
Most of what i have found under 13" tall is only 8" speakers. I am thinking of buying this Cerwin Vega dual 8's VE-28S - I can get that for about $200 shipped. My only concearn is that its only 125w rms.
I was also debating a polk psw111 I can get for $150 shipped.
Or I could get this 10" Paradigm PDR-10 v.4 10 , I found for $149 shipped and lay it on it's side. or maybee the 2 of the 8" Paradigms for $100 each?
pigeonnest is offline
post #2 of 3 Old 11-30-2010, 05:19 PM - Thread Starter
pigeonnest's Avatar
bump
post #3 of 3 Old 11-30-2010, 05:55 PM
Luke Kamp's Avatar
Liked: 92
You would be slightly over to around $210 with the AVS discount, but an option would be the Lava LSP10 and laying it on its side which would be fine with the front ports. I bet it would be a noticable upgrade and fit the space.
Luke Kamp is offline
User Tag List
