SVS PB12-NSD DSP overkill for a 16' x 9 1/2' HT room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-13-2010, 11:41 AM - Thread Starter
Rob67's Avatar
Liked: 26
Building a dedicated home theater room 16' long and just under 10' wide (8' ceiling). Is this sub too much for that dimension or just right? Reason I ask is that it takes up a lot of real estate and I am trying to find a spot for it!!
Rob67 is offline
post #2 of 17 Old 12-13-2010, 01:00 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Getting a sub that can fill your room and more isn't overkill. It's called 'having headroom'. The less you have to drive a sub to its limits, the more refined it will perform.
In a small room, floorspace may be the restricting feature. You should also look at the PC12-NSD as an option. This has a smaller footprint, but is 35" tall. Get the one that best fits your room. Either one will kick a$$ in your HT. In your smallish room, you might also consider the SB12-NSD. You should get significant room gain down low that would give the little sealed sub quite a performance boost where it could actually outperform the big ported versions over a wider FR.
Randy
ransac is offline
post #3 of 17 Old 12-13-2010, 01:19 PM - Thread Starter
Rob67's Avatar
Liked: 26
Hi...thanks. I should have clarified that I already own the sub in the thread title! SO, I guess I am going at it from a point of view that I should either sell it and get something smaller or keep it and try to fit it in somewhere.
Any placement suggestions?
Rob67 is offline
post #4 of 17 Old 12-13-2010, 01:53 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Not too many options for placement. If you can stay out of the corners, that would help. You shouldn't need any boundary reinforcement. If you'll have space behind the seating, that could work. That is where I had mine in a similar (actually smaller) room.
Of course, you can always list it for sale and see if you get a good price for it, which you should. Then buy the SB12-NSD. Much smaller and should work very well in that size room.
Randy
ransac is offline
post #5 of 17 Old 12-13-2010, 03:33 PM
Kimwyn's Avatar
if you would call that sub overkill in a 1200^3 ft room what would you say to me who is thinking of (and should soon have) dual HSU ULS-15s in a 860^3 ft room ?
Kimwyn is offline
post #6 of 17 Old 12-13-2010, 08:17 PM
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
For a dedicated theater that size, I would say it's just right. Maybe another one down the road
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #7 of 17 Old 12-27-2010, 11:15 AM - Thread Starter
Rob67's Avatar
Liked: 26
LOL...thanks. I guess I will have to make room for it.
Rob67 is offline
post #8 of 17 Old 07-04-2011, 11:20 AM - Thread Starter
Rob67's Avatar
Liked: 26
Didn't mean to necropost but I thought I would update...I finished my room and the sub is a beast and is taking up a ton of real estate. Right now, I am hiding it behind one of my reclining chairs along a wall.
You can't see it in these photos but it is off to the right of the photo with the bookcase on the far wall. In the photo with the TV, it is behind the chair on the left...
Rob67 is offline
post #9 of 17 Old 07-04-2011, 11:31 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Nice-looking room!
I used to have a PB12-NSD (w/ BASH amp) in my relatively-large (15' x 30' 7.5' = 3,375 cu.ft.) room and it performed reasonably well in there. I can only imagine that the newer PB12 must really rock in your smaller HT space!
(I had thought of doubling-up w/ another PB12, but opted to go for new duals instead. I sometimes regret not having at least tried a dual PB12 set-up.)
BTW, you can't start a thread about buying a new sub and then, once you've bought it, not post at least one pic of it!
eljaycanuck is offline
post #10 of 17 Old 07-04-2011, 01:01 PM - Thread Starter
Rob67's Avatar
Liked: 26
Originally Posted by eljaycanuck View Post
Nice-looking room!
Here you go.
Yes, it destroys this room. LOL
The good thing is I soundproofed it pretty well. Doubled up the drywall panels, and went with 1/2" panels. Used Green Glue for dampening between the panels and the high end soundproofing insulation. This room is tucked away in my basement and you can't hear anything upstairs except minor bass. It sounds like the clothes dryer is on in the next room when a movie like Saving Private Ryan is hitting it pretty hard.
Rob67 is offline
post #11 of 17 Old 07-04-2011, 01:11 PM
Liked: 1800
Here you go.
Excellent, thanks!
I have no doubt.
Nice job with the soundproofing, and the aesthetics! Congrats!
post #12 of 17 Old 07-04-2011, 01:19 PM - Thread Starter
Rob67's Avatar
Liked: 26
Excellent, thanks!
I have no doubt.
Appreciate it...was 6 months in the making (not counting the years of building up my gear and saving to do it right!). Just calibrated the sound in the room and the TV (it's a new 60" Sammy plasma). Needless to say, my wife and I are blown out of our chairs with how much different the experience is. We still have some ambient decorating to do, though.
My system and TV used to be in our living room upstairs and it is an open floorplan with a cathedral ceiling...so the sound just goes everywhere. By bringing everything into this self contained (and sound proofed) space, you really hear all the clarity and bass as it should sound.
And, you can jam it late at night and not wake the kids who are sleeping two floors up!
Rob67 is offline
post #13 of 17 Old 05-02-2013, 11:49 AM
tristan82's Avatar
Sorry for post jacking but I have a simuluar question I have a 2008 cu ft space. And Im looking to get 2 svs pb12's to work with my 5.1 set up soon to be 7.2 currently I have a onkyo txnr809 with kef q700's up front q600 center and q300 doing rear duties might get the q800's dipoles or maybe another set of q300's I'm trying to future proof my set up cuz I will be moving into a townhouse and will then have a nice lil man cave so my question is should I get 2 pb12's or just one for now thanks in advance
tristan82 is offline
post #14 of 17 Old 05-02-2013, 12:47 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
There's no such thing as having to much bass.
For that size room, you should be running dual PB12-NSD subwoofers, at a minimum.
Never go with a single sub, regardless of the the size and shape of your room.
Multiple subwoofers smooth out the bass response and address the problem of standing waves in your room.
If you can't afford dual subs, wait until you have enough money saved up to buy two.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #15 of 17 Old 05-02-2013, 01:06 PM
steve nn's Avatar
Liked: 433
Hey Rob,
What a nice looking room and setup.. glad all your work is panning out so well for you and family. Congrats!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #16 of 17 Old 05-04-2013, 02:50 PM
CHASLS2's Avatar
Quoted: 358 Post(s)
Liked: 127
I used a PB12 NSD in a small bedroom 13x12 it was more than enough.
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #17 of 17 Old 07-23-2013, 05:29 PM - Thread Starter
Rob67's Avatar
Liked: 26
Holy necro post thread! Forgot about this post!
Thanks, been running with just that one for a long time. I really don't have any more room for another and it seems to do the job well enough for me. I am not so much an audio purist as I am a video purist so it works. Maybe, someday, when I am able to build my dream room I will do it right. This was my first stab at a media room and it has served us well the last few years.
Thanks guys!
Rob67 is offline
