Best value subwoofer for purely music listening - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 12-17-2010, 06:10 PM - Thread Starter
DirtyDeeds's Avatar
Please advice as looking for the best subwoofer purely for music listening purposes. Do I really have to buy something around 800-900 dollars of a sub in order to get the best subwoofer for listening purposes? What others can you recommend you know is the best bang for the buck? Is rythmik subwoofer the best bang for the buck subwoofer with regards to pure music listening or are there cheaper alternatives?
DirtyDeeds is offline
post #2 of 20 Old 12-17-2010, 06:44 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
The new Lava subs are showing they are very good for the money. Check out a review for the 12" model. http://www.hometheatershack.com/foru...iscussion.html
TCARCIO is offline
post #3 of 20 Old 12-17-2010, 06:59 PM
diamonddelts's Avatar
For a smaller musical sub you could go with a Emotiva 12 or 10.
For a medium range musical sub you could go with a Rhythmik sub
For a large musical sub "I" would go with the CS 18.1 or 18.2 if your budget allows. They are big subs that perform EXCELLENT with music.
diamonddelts is offline
post #4 of 20 Old 12-17-2010, 07:06 PM - Thread Starter
DirtyDeeds's Avatar
Thanks dd. It will be for a medium sized room and as I have researched and read, Rythmik has always been highly recommended. Just looking for other options but surely it is on the top of my list. Options being a cheaper without sacrificing sound quality with regards to music listening. I will look into that emotiva sub as well. I know they are highly regarded for their value with amplifiers but never really looked into their speaker and subwoofer line. Will read reviews about it as well. Thanks again dd.
TCARCIO, I have clicked the link with regards to that lava sub. Never heard of it but will read more about it. Thanks for the suggestions.
post #5 of 20 Old 12-18-2010, 08:09 AM
taoggniklat's Avatar
I would look into the Emotiva 12", Epik Legend and HSU VTF2m3 before the Lava subs....for a music system.
taoggniklat is offline
post #6 of 20 Old 12-18-2010, 08:24 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
At under $400 (shipped), the Hsu STF-2. My STF-2 is absolutely superb with the 4-6 large drums in the grand finale and closing credits of the movie "Fame".
wwinkler is offline
post #7 of 20 Old 12-18-2010, 08:25 AM
natsp's Avatar
in regards to how big a sub to get for mostly music ,occasional movie.if the room is large with an opening to a med room,how much of a diffrence does it make if the listening area is 10 to 15 ft away from speaker/sub
natsp is offline
post #8 of 20 Old 12-18-2010, 08:52 AM
No problem man. You might also be interested in the EPIK Legend.
post #9 of 20 Old 12-18-2010, 09:48 AM
monomer's Avatar
Please advice as looking for the best subwoofer purely for music listening purposes...
Based upon the above quote, I have just a single answer for you, Rythmik.
...Do I really have to buy something around 800-900 dollars of a sub in order to get the best subwoofer for listening purposes?...
However it sounds like you're willing to compromise based upon cost, so in that case you will have others to choose from... HSU would be a personal suggestion of mine.
"For deep bass, the listener is not really listening to the speaker, but rather, is listening to the room as it is being played by the speaker."
Juicy
Doggie Jabber
monomer is offline
post #10 of 20 Old 12-18-2010, 09:55 AM
comsimat's Avatar
I've done an AB comparison with lava and legend. The legend is noticeably more musical than the lava.
comsimat is offline
post #11 of 20 Old 12-18-2010, 10:33 AM
chewbacca121's Avatar
Rythmik 100% have the F15 love it!!
chewbacca121 is offline
post #12 of 20 Old 12-18-2010, 10:36 AM - Thread Starter
DirtyDeeds's Avatar
Thanks monomer..
post #13 of 20 Old 12-18-2010, 12:20 PM
par4's Avatar
Hsu STF-2, very nice.
par4 is offline
post #14 of 20 Old 12-18-2010, 09:59 PM - Thread Starter
DirtyDeeds's Avatar
HSU stf-2 seems like a very good value. There is also the craigsub cs 10.2 which seems to be a very good value as well. I would just want to ask any of you who had experience on both, which is more musical. And also the question of placement as I would want to have it at the front beside one of the speakers. Really appreciate the responses as I am just learning. At first, I was totally into not purchasing a subwoofer and sticking to a 2.0 system as I was into the idea that subwoofers will degrade sound quality... I guess I'm totally wrong and there are multiple options for music friendly subwoofers.
I also see a number of posts asking the same question as I do and like them, I appreciate yall's help.
post #15 of 20 Old 12-18-2010, 10:39 PM
Avgass's Avatar
Liked: 35
+1 vote for a Rythmik. If you need something bigger get the F15 or F15hp. If you need to save money and have some spare time, go with one of the DIY Rythmik kits.
Avgass is offline
post #16 of 20 Old 12-19-2010, 06:47 PM
Adam-DiVine's Avatar
The Hsu is ported, the other suggestions are sealed. No problem with one over the other, just a different sound. There are not that many CS 10.2's out there, so you may have a hard time getting a comparison. You could visit http://www.chasehometheater.com and ask Craig, he has owned and ehard the subs that you are comparing.
Adam-DiVine is offline
post #17 of 20 Old 12-19-2010, 07:58 PM - Thread Starter
DirtyDeeds's Avatar
Thank you.....If you don't mind me asking, what should I be looking for? What is the sound difference between ported and sealed? What is a better match for lets say a good bookshelf/monitor speakers?
post #18 of 20 Old 12-19-2010, 08:36 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
I recently shopped for a sub for a 2.1 music system and I found more people on AVS who said sealed would be better a better choice for music (although there were plenty of votes for a good ported sub). After an exhaustive search I went with the SVS SB12-NSD for 6 bills shipped and I'm very happy. For me it came down to SVS and Rythmik.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #19 of 20 Old 12-19-2010, 08:36 PM
Avgass's Avatar
Liked: 35
Ported vs sealed is a can of worms (the debate rages) but here goes...
Ported have quite a bit more output, especially around their tuning frequency but they are also a bit bigger for the same size driver. They also have very low distortion around their tuning frequency. As such they are generally very good value for money and are great for home theatre and many enjoy them for music too. Some of the highest regarded subwoofer designs are ported.
Sealed have a more natural roll-off in the lowest frequencies. Fans of ported subs will flame me for this but - I prefer sealed subs due to what I perceive as a tighter, more accurate sound which is especially important for music. This is the effect of group delay which is generally lower in sealed subs. The following is an interesting article by Adire Audio about group delay...
http://www.adireaudio.com/Files/GroupDelay.pdf
For bookshelf/monitor speakers, sealed subs have an added advantage in that they do not suffer from port resonance when crossed over higher.
Avgass is offline
post #20 of 20 Old 12-19-2010, 08:52 PM - Thread Starter
DirtyDeeds's Avatar
Thank you for the response and also for that link. Appreciate it much.
