BIC F12 or Polk PSW505 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-05-2011, 02:36 PM - Thread Starter
rafareyes's Avatar
Hello everyone,
New to the forum and the audio world.
I have read many threads in the forum regarding this two subs but I have not been able to get a clear idea of which one is better.
I see that they are both similar on specs, except that the PSW505 has 300 watts rms while the F12 is 150 watts. This means that the PSW is in fact more powerful?
Many people recommends other subs instead of this two. But if you have to choose one of them which one would it be the F12 or PSW505 and why?
Specs (copied from amazon):
F12
* Design: Front-firing 12-inch, 475-watt peak powered subwoofer
* Frequency Response: 25Hz - 200Hz
* Sensitivity: 90dB
* Drivers: 12-inch injection molded woofer with heavy duty surround
* Magnetic Shielding: Yes
* Gold-Plated Terminals:Yes
* Recommended Power: Built-in Amplifier Power: 475 watts Dynamic Peak, 150 watts RMS continuous
* Impedance: 8 ohms
* Dimensions: 17 x 14-3/4 x 17-1/4 inches (HxWxD)
* Weight: 42 pounds each
* Warranty: 5 years parts and labor
PSW505
Hi-Roll Surrounds to support longer excursion High current 300 Watt Continuous (460 Watt Dynamic) power amplifier Frequency Range - 23 Hz - 160Hz Adjustable low pass crossover, phase switchand volume control for perfect blending with any main speakers Unfiltered LFE input Magnetically shielded Auto on/off circuit that automatically turns your subwoofer on when it senses a program signal. When no signal is present, the amplifier turns off within 15 minutes Sturdy Feet keep the sub from sliding across the floor when played at high volumes Unit Dimensions - 16-1/8H x 15-1/8W x 18-3/16D; Weighs 56 pounds Warranty - 5 Years Parts and Labor Speaker; 3 Years Parts and Labor Amplifier Subwoofer cable required; not included.
Thank you for your help.
rafareyes is offline
post #2 of 13 Old 01-05-2011, 02:48 PM
Elisha's Avatar
Quoted: 308 Post(s)
Liked: 241
You gain 3 decibels each time the wattage doubles.
Not double the power.
Plus it also depends on the sensitivity of the driver as well. The F12 is 90dB which isn't bad. If the Polk is lower, then there's noting much to gain.
Elisha is online now
post #3 of 13 Old 01-05-2011, 03:11 PM - Thread Starter
rafareyes's Avatar
so there's no real difference?
post #4 of 13 Old 01-05-2011, 03:17 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
Skip the Polk. Here is a review. This sub has nothing down low.
http://www.hometheaterhifi.com/volum...er-4-2005.html
The Polk may do OK with music but as you can see in the review it takes a crap below 30hz. That's where most of the HT fun stuff happens.
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is online now
post #5 of 13 Old 01-05-2011, 03:19 PM
benclement11's Avatar
For under $200 the BIC F12 is always the most recommended.
Polk subs are also the ones I see people talk badly of the most.
I have the BIC F12... I like it.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #6 of 13 Old 01-05-2011, 03:22 PM
Elisha's Avatar
Quoted: 308 Post(s)
Liked: 241
For a sub claiming 23Hz, that is pretty sad numbers.
post #7 of 13 Old 01-05-2011, 03:52 PM
mr stroke's Avatar
Quoted: 64 Post(s)
Liked: 26
i have both of those subs(except the 10" version of the Polk)
and the BIC sounds better IMO
mr stroke is offline
post #8 of 13 Old 01-07-2011, 09:00 AM - Thread Starter
rafareyes's Avatar
I ordered the BIC. thanks for the advice everyone.
post #9 of 13 Old 08-03-2012, 05:19 PM
mfrey0118's Avatar
I too am considering these two subs. My only concern is the RMS for the Polk is much better than the BIC...
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #10 of 13 Old 09-17-2012, 08:56 PM
Ironlion32's Avatar
I was going back and forth on these two, but am pretty sure I'm going to grab the BIC this weekend. Unless I magically decide that I'd rather spend the extra $150 and get the klipsch reference 12. Even then, I think the BIC may sound just as good for much less money.
Ironlion32 is offline
post #11 of 13 Old 09-17-2012, 08:56 PM
Ironlion32's Avatar
post #12 of 13 Old 09-17-2012, 09:03 PM
Ironlion32's Avatar
Sorry for the repeat posting. It wasn't showing until I did a refresh and I don't know how to delete. biggrin.gif
post #13 of 13 Old 11-24-2012, 08:54 PM
Buckweb's Avatar
Further question: If I'm solely listening to music which sub would be better?
Buckweb is offline
