Will two PB13Us generate useful infrasonics? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 50 Old 02-04-2011, 05:44 AM - Thread Starter
DanLW's Avatar
Liked: 37
Right now I am leaning towards eventually getting two PB13 Ultras as they seem to be the only commercially available option in my price range that can get me to 10Hz. But will that 10Hz be useable?
My room is about 1800 ft^3, and enclosed. Eventually when we get a new house, I plan to build my own theater room to roughly the same volume, and it will be an enclosed room. So according to the SVS site, I should get room gain of around 15db.
Now, according to tests done at Home Theater Shack, the PB13U can hit 96db at 10Hz before seriously compressing. (My original idea was to run it in sealed mode, but compression really kicks in in that mode for some reason.)
So, am I right to assume that 96db + 3db (for a second sub) +15db = 114db at 10Hz? Is that loud enough to be "audible", or would I need more?
I know, I know, DIY is the way to go. But when I looked at possibly building my own, by the time I've purchased the good driver, the amp, the signal processing, and the materials, the PB13U looks to be a just a few hundred dollars more. To me, thats not too high a price for a proven design that I know works as intended.
So, will two PB13Us generate useful infrasonics? Or if infrasonics is my goal, do I really need to just get something cheaper for my 20Hz+, and DIY a subsubwoofer?
DanLW is offline
post #2 of 50 Old 02-04-2011, 05:48 AM
penngray's Avatar
Liked: 47
"My room is about 1800 ft^3"
"will two PB13Us generate useful infrasonics?"
YES but really the power of the PB13 design is only down to its tuning point, anything underneath is just gravy and definitely controlled by a high pass filter.
Now going from useful to insane infrasonics takes exponentially more displacement down low. Only sealed designs with large displacement will give anyone the ability to get meaningful single digit output because they do not have a sharp rolloff like ported designs.
penngray is offline
post #3 of 50 Old 02-04-2011, 06:04 AM - Thread Starter
DanLW's Avatar
Liked: 37
Wow, thanks! You and Bosso are the reasons I asked this question. At first I was all excited that I could get 10Hz response from a commercially available system, but then I remembered you guys saying that the really low stuff needs to be re-produced quite loud to be meaningful. But I don't remember exactly what those levels needed to be.
I realize that to really delve into single digits, I will need either a rotary, or a wall of drivers. That's quite out of my price range, unless I come across a ton of money. For single digit response, I plan on getting tactile transducers.
DanLW is offline
post #4 of 50 Old 02-04-2011, 06:15 AM
penngray's Avatar
Liked: 47
If you can get sick room gain like MKTHeater's room. Your room seems like it might because of its size (what are the dimensions).
You can get single digit performance with comercial choices, it just costs more $$$ but 2 PB13s are close to $3500 shipped already, right? Have you considered a quad pack of HSU ULS-15s ?? or maybe a couple CHT 18.2s?
FWIW, Bosso is the expert, Im just one of his "lacky" students
penngray is offline
post #5 of 50 Old 02-04-2011, 06:18 AM
sb1
sb1's Avatar
Quoted: 420 Post(s)
Liked: 361
Dual CHT 18.2's in that room might work. He could get three for a few hundred over dual Ultras if I'm not mistaken (plus shipping, though). I've never heard the CHT's, though.
EDIT: I may be wrong on the price of the CHT's... Yeah, I just looked. A little more expensive than that. Duals would be a cheap way to get a sealed design that MK is pleased with, though.
Stephen.
Chances are very good that I was drinking when I posted the above.
sb1 is offline
post #6 of 50 Old 02-04-2011, 06:27 AM
penngray's Avatar
Liked: 47
Yeah, DUAL 18.2 gives him 4 18" woofers, limited Xmax is the only down side but they are the ONLY dual 18" designs offered right now.
penngray is offline
post #7 of 50 Old 02-04-2011, 06:33 AM
Warpdrv's Avatar
My room is 17-1800^3 and my single Seaton Submersive is showing response into the very low teens if not single digits, but then again I won't trust any measuring equip to faithfully measure that low... A (decent) single 18" will do nicely into the low teens as well, how much infrasonics you want even below there IMO is kinda silly but to each their own.... there is more then enough rumble down to 10hz, much less 15.... I personally don't really give a hoot about hitting content that low....
Warpdrv is offline
post #8 of 50 Old 02-04-2011, 06:37 AM
Ed Mullen's Avatar
Quoted: 128 Post(s)
Liked: 347
If you run the PB13U in Sealed mode, it can generate about 90 dB @ 10 Hz @ 2M GP without significant compression. Distortion is quite high at that SPL though, so I'd prefer to use 80 dB where THD is ~30 %, which is right about where the CEA-2010 limits would be (it pulled 87 dB @ 12.5 Hz which was Ilkka's lowest CEA-2010 test frequency).
In Sealed mode there is a high pass, but it doesn't take effect until <10 Hz (you can see this from Ilkka's graphs - there is no premature roll-off) and is basically there to protect against spurious infrasonic junk in the single digits.
A pair of them will add 6 dB @ 10 Hz in-room, even if they are not co-located, due to the length of the wavelength in question. This will pretty much be the case for all frequencies below the modal-pressure transition frequency in your 1800 ft^3 room, which is probably around 30 Hz.
In a perfect world, each near-field boundary will add 6 dB (but it's usually more like 4-5 dB with lossy walls), so if the subwoofer is corner loaded in 1/8 space with a quasi-nearfield ceiling boundary, expect maybe 10-12 dB of boundary reinforcement (which is not the same as room gain).
The acoustic transfer function (i.e., room gain) of your room depends on the layout and boundary integrity, but if the room is enclosed and pretty solidly contructed, 13-15 dB of room gain (relative to the modal drive level) at 10 Hz is entirely plausible (my own HT has 17 dB of gain at 10 Hz).
So depending on the listening position relative to the subwoofers, I wouldn't be surprised if you saw the following SPL at 2 meters from the subwoofers:
80 dB
+ 6 dB (duals)
+10 dB (conservative boundary gain estimate)
+13 dB (conservative room gain estimate)
109 dB (at least). This is usable SPL at the listening position at reasonable THD levels.
With that said, I feel 10 Hz output is highly overrated from a subjective perception standpoint. Response to at/near single digits can provide a palpable thickness in the air and foundation to the soundtrack. And if max SPL is not the first priority, then running your subs in Sealed mode can/will provide a satisfying playback experience.
With that said, if you want much more output and lower THD over the 13-40 Hz band, running the dual PB13U in the 16 Hz mode will provide a much more viscerable experience, without sacrificing much in the 10-13 Hz band.
The nice thing is that you have a choice with the PB13U - Sealed, 16 Hz, 20 Hz, and also three room gain corner frequency settings with two slope choices (six possible combinations) so you are sure to find the best combination for your particular application, room acoustics, and preferred level of slam/impact.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #9 of 50 Old 02-04-2011, 06:44 AM
floridapoolboy's Avatar
Why not try this... keep your present sub, and augment it with Buttkickers! It's extremely expensive to get to 10hz with subwoofers, and the results are often not worth the effort in terms of amount of useful content that low. The Buttkickers can handle all frequencies below 20hz, and give you the tactile infrasonics you seek at a fraction of the cost of multiple huge sealed subs. http://www.amazon.com/ButtKicker-BK-.../dp/B0006FK42S
floridapoolboy is offline
post #10 of 50 Old 02-04-2011, 06:50 AM
penngray's Avatar
Liked: 47
Originally Posted by Ed Mullen View Post
With that said, I feel 10 Hz output is highly overrated from a subjective perception standpoint. .
Blah!!
Im disappointed if Im lacking it these days. The room compression from it is just insane. I can always tell what system does not do below 15Hz, there is definitely a different feeling. YMMV
I own 2 buttkickers that are mounted to my platform where my 4 HT chairs sit. IMO, there is a huge difference between them and what displacement does to a room. Definitely a cost factor involved if there isn't the DIY opportunity (Remember $2K gets you insane output in the DIY world with and IB installation)
penngray is offline
post #11 of 50 Old 02-04-2011, 06:58 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I'd be curious to see the measurements of a single ULS-15 vs a single PB-13 in sealed mode given the significant box size and amp advantages of the PB-13.
As for the OP, having had a single PB13 in a 1700cubed room with a couple open doorways, it is very, very impressive. I also have significant room gain from 10hz or so up to 20hz. If you could fit two of those in the room, it would be very impressive.
Mind you, I'm sure 4 ULS's, or 2 of the CHT subs would as well (if you don't mind the aesthetics of them).
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #12 of 50 Old 02-04-2011, 07:35 AM
Ed Mullen's Avatar
Quoted: 128 Post(s)
Liked: 347
Blah!!
Well I did say I can surely perceive it, but it's more like icing on the cake when viewed in the larger perspective. Take care of 15-80 Hz first and worry about 7-14 Hz octave last. Since I have so much room gain, I'm a natural candidate to run sealed mode, and that's how my dual PB12-Ultra/2 are usually configured. Flat to ~10 Hz and plenty of output for my typical listening levels (-10 to -15 MV setting depending on the DVD). The novelty of 'reference level' playback wore-off years ago for me - I'm firmly in the 'comfortably loud' camp, with lots of dynamic headroom and low distortion and no artifacts.
Ed Mullen
SVS
post #13 of 50 Old 02-04-2011, 07:40 AM
Ed Mullen's Avatar
Quoted: 128 Post(s)
Liked: 347
Send me an email - I have a full data suite on that sub.
Ed Mullen
SVS
post #14 of 50 Old 02-04-2011, 08:08 AM
Kimwyn's Avatar
there is a member on these boards (counsil i think his name is) who has 4 PB13Us and 4 epik empires, if im not mistaken. is it safe to say he would be able to get into the single digits range easily and with useable output?
Kimwyn is offline
post #15 of 50 Old 02-04-2011, 08:19 AM
sage's Avatar
Here's some emperical: 2 PC13 Us in 16hz tune, 2800 cu/ft room, and I could feel the 10hz signal in 'Irene Irene' from BHD. That doesn't suck. I'm using the room gain comp, which is going to to reduce that a bit anyway.
sage is offline
post #16 of 50 Old 02-04-2011, 08:22 AM - Thread Starter
DanLW's Avatar
Liked: 37
I have considered the ULS-15s, but not the CHT 18.2s. In fact, I spent lots of time in the ULS thread today reading about them. My main concern is it seems like they may run out of headroom faster in the most demanding of scenes. Also, I considered that if the SB13U has more output than the plus, then the ULS would also have less output than the VTF-15. So I considered the 15s, but given their early rolloff in the Audioholics test, it looks as if even in sealed mode, a pair of VTFs would not go quite as deep as the SB13Us.
For me, duals is the way I really want to go. I'm acoustically treating my room, so a good room response is important to me. I do plan to do treatments for bass, but from what I've read, bass trapping combined with dual subs is even better.
Originally Posted by EdMullen View Post
The ability to have multiple tuning options is definitely attractive. I'm hoping that with such a small room, even in sealed mode, I will be able to have both the subterrenian lows and smack you in the chest mids. I guess I will just have to play around with them once I do get them and see what puts the biggest on my face.
Also, I really do appreciate your taking the time to provide advice in a public format for the whole world to see. Given the level of scrutiny on this forum, it reassures me that you're giving me solid advice, and not a marketing line.
Well, my current sub is a Klipsch RW12-D with a blown power supply. I think it blew because I plugged it into a 220V-110V transformer, but the transformer's hot and neutral were reversed. (German outlets can be plugged in either way, and the only way to know which way is right is with a polarity tester) Also didn't help that the ground was floating. I have since fixed that issue. I do plan to buy a dual voltage amp from OAudio to fix it. But in the long run, I consider my Klipsch sub much the same way I consider my Primus 150 speakers: Not bad, but not great.
The earliest I would be able to possibly acquire the subs would be next year. We should be out of debt this year, and should get a really nice tax return next year. At the very least, I may buy one ultra and get the next down the road. For speakers, haven't decided yet. I'm narrowed down to systems centered around either Klipsch RF'7s, Paradigm Studio 100s, or Axiom M80s. If I knew for sure the Axioms would perform as well as the Klipsch/Paradigm products, it would be a no brainer. But I'm really leaning towards Klipsch due to their sensitivity and 30Hz extension. Whether Klipsch as we know it still exists by the time I'm ready to buy is another question entirely.
After reading around on Audioholics site recently, I've determined that I want to try crossing over my speakers at 40-50Hz, if at all. The reason I might not cross over the mains is so that when I do install actuators, they will only actuate on the .1 LFE effects, and not on low frequencies in the movies background music.
DanLW is offline
post #17 of 50 Old 02-04-2011, 08:40 AM - Thread Starter
DanLW's Avatar
Liked: 37
I'm usually in that camp, if not a little lower since my wife usually watches movies with !me. Although I have been able to watch at -15 instead of -25 now that we are in a house without vaulted ceilings, and with acoustic treatments on the front wall. It seems that the acoustic treatments really do make movies sound less noisy so that they can be played louder without being "loud". I hope to be up to -10 once all the treatments are up.
Mens movie nights where we can all convince the women to do something else will be when that dial creeps up towards 0. As it is now, my Primus 150s won't do reference. There is a scene in Stargate: Ark of Truth which is a tweeter torture test. There is a prolonged high frequency tone during a torture sequence (not sure if the characters were being tortured, or the audience). Anyhow, I had to turn my reciever down past -10 to stop the tweeters from popping!
DanLW is offline
post #18 of 50 Old 02-04-2011, 09:43 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Try the last 15 minutes or so of "How to Train Your Dragon" if you want to test the infrasonics. Just make sure whatever subs you have can in fact handle it, or at least know when to turn the volume down.
pbc is offline
post #19 of 50 Old 02-04-2011, 09:55 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
I'm not sure I'd want to run any of those speakers at 40hz/50hz x-over. If they are rated to 30hz, the lowest I'd cross them at is 60hz. Though with dual PB13's, 80hz is the lowest I'd go.
pbc is offline
post #20 of 50 Old 02-04-2011, 10:42 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
There is no question about it, the SVS products are killer, and their output numbers still hold up today as many enthusiasts use them for benchmarks to shoot at. The Ultra is one of the finest subs in the world.
Penn touched upon it, however it can't be overstated, a diy IB install would get you easily into the single digits for much less than your stated budget. The Cult of the Infinitely Baffled kindly welcomes anyone seeking to plunge the depths.
Before one adds in room gain or boundary gain, 110db@10hz@1m@225w can be had out of a combo of the EP4000, and four IB3-18s from Fi(Blueprint). That's well under the stroke limits of the driver, and 225w is used for an EP4000 8 ohm/channel output (2-4ohm 18s, in series). Regardless, these numbers are conservative. In room, at the listening position, levels of 115-120db@10hz wouldn't be unreasonable to expect depending on room and boundary gain specifics.
If high levels of 10hz is what you're after, here are two avenues to get there; Multiple small sealed, IB. An IB is a hard to miss target, then again so is small sealed. However, small sealed requires some measure of skill to make them aesthetically pleasing, and they require signal shaping and tons of power to overcome the small box. An IB on the other hand, gets to utilize all that free extension by not having to overcome the air spring, nor do they need gobs of power either. Additionally, an IB alignment doesn't need a big powerful motor assembly that accompanies the needs of a small sealed. An IB merely requires a modest magnet and vc, thereby keeping cost way down. An IB is excursion limited, whereby a small sealed is thermally limited.
Penn, Bosso's lackey, he's got both. A four driver IB array, and a small sealed with the finest LF driver in the world. He could answer your questions regarding specific differences. Back OT.....A quad array of HSU 15s would be killer. That's a very high quality driver. As your well aware, multiple sub locations within the room address modal distribution, thereby smoothing the overall response. So there is significant merit to multiple small sealed. Sounds like you have some time before this purchase. You're already ahead of the game by educating yourself and asking the right questions.
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #21 of 50 Old 02-04-2011, 11:31 AM - Thread Starter
DanLW's Avatar
Liked: 37
Right now we are renting, so IB is out of the question. But if I did decide to simply repair the Klipsch and buy the speakers first, I could do an IB when we buy a house when we get back to the States. The issue there is, by that time I will still have at least 10 years left before I retire, so I will probably have another couple moves ahead of me. We plan to buy a house when we get back, an an unfinished basement which I can finish into an ideal home theater is high on the priority list. I can leave a finished basement behind, and it would add value to the house. But an IB sub is tricky. Unless I could convince the buyers to pay $15K extra to leave the theater intact as a working theater (speakers, amplifiers, projector, etc.), I would want to take the equipment with me. And if the next place we end up in won't support an IB system, I'm stuck either storing or trying to resell the stuff. So portability is high on the priority list.
So then there is the small sealed sub. To match the output of the two PB13Us, I suppose I would need four. (I'm not going to presume I can create two subs equal to two PB13Us on the first attempt) So, pop on over to DIY Cable, and get four Tempest X-2 15" woofers ($285*4=1440), four 1000W sub amps ($395*4=1580) Then I suppose I need a Velodyne SMS 1 for $415. So far my total is $3,435. Two PB13Us delivered is $3800. A ULS15 Quaddrive would be $4000 plus shipping. So for me, DIY sealed doesn't make sense. Although I suppose I could come close to a PB13U using an 18" driver. Two 18" sealed subs would cost maybe 3/4 the cost of a PB13U. But would I be sacrificing "clean, tight bass"? Again, looks like the extra cost associated with two PB13Us goes to peace of mind of knowing I have a proven product. If I built my own, I would always wonder if I did it right, and without having a proven product to A/B it with, I wouldn't know.
Don't get me wrong. If I could DIY for 1/4 the price, I would go for it. But at 3/4 the price, it is quite a gamble.
DanLW is offline
post #22 of 50 Old 02-04-2011, 11:56 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 672
Hi Dan,
Long post. Since I don't post much, I have to cram a lot into each post. But, I include pretty pictures and crazy stuff like the facts, so, at the very least, it's usually fun enough to wade through.
Hey, we all have our faults.
And, please don't buy into all of this "more visceral", "mid bass slam" Bah-Low-Knee.
Infrasonic content on soundtrack and hi-rez music discs is a very recent phenomenon in human history. It has become an extremely sophisticated art with many of the technical secrets being closely held by the top artists in the field.
Accurate playback of that content in one's home is even more recent. Like any new sensory experience, it is not best served by the initial blurting of some popular adjectives and quick subjective judgement from the vocal majority.
My take has always been that of the objective enthusiast. Keith Yates sums it up well for me:
One last point: If you've got the dough and real estate to spare, don't shrug off the sub-20Hz content I've shown in the reference waterfall plots as unintended artifactssay, scraps of subway rumble or HVAC noisethat somehow slipped through the filters during the mixing process. The content is program-related and meant to be there.
Of course, he's only partially right. The "real estate" and "dough" comments are not so correct. I currently use less real estate than any of the subs that have been or will be mentioned in this thread. And, the cost is less than many enthusiasts spend on what they and their guests sit on while they watch a movie.
Over the past decade, I've spent more time studying the physics of infrasonic sound, comparing actual content to actual reproduction of that content in various rooms at the listening position, objectively through measurements and spectrographs and subjectively through listening sessions, than anyone.
Here is a recent exercise which compared a scene from HULK that has rather huge <10 Hz content. The subwoofers were configured to 3 different in-room responses; flat to 4 Hz, flat to 10 Hz and flat to 23 Hz. The methodology for asking unsuspecting listeners if they notice any difference and, if so, to describe the difference, will always be the subject of endless debate. Nevertheless, in my experiences with this sort of thing, based upon, if nothing else, the large number of sessions, source and audience diversity, they are conclusive.
The spectrograph lets one "see" what what presented:
In looking for accuracy in bandwidth, response linearity, compression, HD and SPL, the spectrograph, when coupled with a measurement rig that's accurate to 4 Hz, allows direct comparison of the direct analysis of the ones and zeroes from the DVD players SW output to what is presented by the subwoofers at the listening position with a high enough degree of accuracy. This scene with a gargantuan low frequency effect from the state-of-the-artist Randy Thom on the recent BluRay release of How To Train Your Dragon illustrates:
Now, you could drag the sub outside, run progressive sine sweeps until its tongue is hanging out, take the results and do some hypothetical math and post your opinion as to whether or not the sub is enough in some particular room. But, that's not going to be nearly as accurate an analysis as the above graph, so why waste the huge effort and virtual ink?
OPINIONS FOLLOWS:
I would say that the dual PB13 system in 1800 cubes should do a very good job to 10 Hz in 10 Hz ported mode. Below 10 Hz, I have no opinion because there is nothing available from the company on which to base an opinion.
Comparing the PB13 to the Chase stuff is a chuckle. SVS has been around since the beginning and this sub has been scrutinized from head to toe for years. Chase has been in and out of subwoofer business partnerships many times since I've been a member here, all of which have been short lived. And, despite the CHT people's claims of "a wealth of data', I have seen nothing to date to corroborate that. The PB13 is a very well designed and built subwoofer. The Chase stuff is the worst looking I have ever seen.
In fact, looking at all of the current commercially available subs, I would probably only recommend the SVS stuff or Seaton's SubMersive. Of course, my opinions in this matter are as biased as it gets. I view threads like "Audioholics Ultimate Subwoofer Shootout" as needing to be retitled to something like; "The Results Of Audioholics Special Olympics For Subwoofers".
The only system I can guarantee will get the job done in your room is the following, but that's mostly because there is no pertinent data for other systems and, quite frankly, I just don't care much about any other system:
I visit here and post regarding new and existing source material, how one might get the best from his existing sub, in-room and low frequency reproduction fact and theory and have rarely, if ever, engaged in which sub is the most-bestest one.
Bosso
bossobass is offline
post #23 of 50 Old 02-04-2011, 12:33 PM
Kimwyn's Avatar
^^^and where would that be available????
Kimwyn is offline
post #24 of 50 Old 02-04-2011, 12:53 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
It's not, I think Bosso's simply saying "his system" is the only one he would "guarantee" would provide "infrasonics" below 10hz because empirical data for all the other subs discussed simply doesn't exist. I.e., no one can comment on sub 15/10hz "ish" frequency response for subs where the data isn't available to prove it.
Further, I don't know of many (any?) enthusiasts outside of Bosso that actually have the measuring equipment that would accurately measure below 15/20hz.
I would still maintain that Dan would be incredibly pleased with the output of dual PB13's in his room (assuming he does not want to try DIY, which I usually presume is the case for people posting in the non-DIY forum so I don't bother bringing it up), and provide him with the ability to "seal" them if he wanted to get a feel for what I'm guessing 3 to 4 ULS-15's would provide. Save for the added smoothing in the frequency response the additional subs would provide benefit-wise.
pbc is offline
post #25 of 50 Old 02-05-2011, 02:29 AM - Thread Starter
DanLW's Avatar
Liked: 37
Bosso was the second to mention "How to Train Your Dragon". I have that on Blu Ray... when I first saw that, there was a scene near the end where I was certain there was some uber low content... unfortunately, even my Klipsch was out at the time.
I really hope I can get these next year!
On a slightly different topic, whats the word on possible structural damage? The house we live in in Germany is quite possibly over 100 years old. Our landlord doesn't know the age, and he grew up in the house! There are pictures of the theater room in this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1291876
Note that it looks a bit better now. I have since put up more wiring conduit, and organized the cables.
In the front left corner, white dust comes out of the ceiling when we walk around up there. I'm certain a couple SVSs will exacerbate this problem. That, and many of the floors are uneven. I wish I knew how these houses are constructed.
DanLW is offline
post #26 of 50 Old 02-05-2011, 05:06 AM
penngray's Avatar
Liked: 47
Good luck
I have almost all the designs.
IB array with 4 Q18s.
Two 11 cuft ported TC2000 15" subs
two LMS5400 sealed 3.5cuft designs + 4000Watts each.
I have 2 PRs + AV15X but I never built the box instead I used the AV15X woofers as bass bins making my mains full range.
I will be working on a 12Hz tuned monster horn design this year when I rebuild my HT room.
Your point about the quad ULS-15 system is a good one but I will go more generic then that. I think a quad pack of any propular subwoofer choice is the best way to get output and smooth in room response.
There is no replacement for displacement, that is not just a nice catch phrase its just the absolute truth about subwoofer low frequency performance add to that Toole, etc go to great lengths in explaining how adding subs will naturally smooth out the response curve.
If people want to know if they can have low end performance they simply have to findout the liters of displacement your sub system is putting out. My IB system does almost 27liters of displacement, as a reference point One PB13 does under 5 liters.
This does not mean the PB13 is a bad choice, its a great sub. It was the first comercial sub to really dig deep and go loud (with low distortion). Ilkka and the experts online found it be very impressive and again TWO PB13s in your room are going to be pretty damn good.
penngray is offline
post #27 of 50 Old 02-05-2011, 05:21 AM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Ok Penn I am having a brain fart this morning and you have piqued my interest. How do you determine total liters of displacement?
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #28 of 50 Old 02-05-2011, 05:32 AM
penngray's Avatar
Liked: 47
Displacement p-p (liters) = 2 * surface Area (cm^2) * xmax (mm) .
penngray is offline
post #29 of 50 Old 02-05-2011, 05:42 AM
Quoted: 41 Post(s)
Liked: 44
Thank you sir. I need one more piece of clairifcation and that would be how do you measure the surface area of the cone? I feel like such a dufus this morning. Or can that info be found somewhere if you know which driver is being used? Also doesn't the enclosure contribute to the equation?
Hometheatergeek
aka AL
My Current System
post #30 of 50 Old 02-05-2011, 05:43 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Curious, has the xmax been published for the PB13 driver or are you just estimating (i.e., a few mm here or there won't make a big diff in the calc)? I don't recall seeing it (but haven't looked at the specs in ages!).
pbc is offline
