Help: Velodyne VDR12 LFE input shocked me and is humming - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-06-2011, 02:09 PM - Thread Starter
fnthawar's Avatar
Hey guys, I've been doing research on Ground Loops as my new Velodyne VDR12 definitely has a humming noise (and gets louder as I increase the crossover). While that is the one concern the other concern is the current it's pushing through the wire.
W/o connecting the LFE input to anything, if I touch the end of the RCA wire, there's definitely a current flowing from the sub through the wire. Is this normal?
I did some reading on directional sub wires, etc. to get rid of the ground loop humming, but I'm still concerned that live current is flowing through that wire.
Farhan
fnthawar is offline
post #2 of 6 Old 02-06-2011, 06:21 PM
DanLW's Avatar
Liked: 37
Sounds like a floating ground, meaning the ground is not grounded. Does the sub have the third plug going into the AC outlet in the wall? If so, does it also have the third plug where the AC cord plugs into the sub? If there is a ground plug all the way to the sub, you need to check your outlet. Your ground may have come loose. The best way to do this is to get an outlet tester. Small device that plugs into an outlet, and has three lights on it that tells you if the outlet is wired correctly.
If there is no ground going into the sub, then the sub derives its ground from the RCA wire which is grounded through the reciever (hopefully)
it is best not to plug or unplug an input to a sub with the power on. Leads to nice loud pops which could cause damage.
DanLW is offline
post #3 of 6 Old 02-06-2011, 06:32 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
When working around standing water make sure you're wearing rubber footwear.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #4 of 6 Old 02-07-2011, 04:21 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
http://www.parts-express.com/wizards...lator&x=31&y=7
If in a hurry, purchase one at Radio Shack.
wwinkler is offline
post #5 of 6 Old 02-13-2011, 09:23 AM - Thread Starter
fnthawar's Avatar
Thanks for your help guys. As it turns out, I did have my sub powered off, but the current was still flowing through. Odd.
So I purchased a few things, hopefully one will solve the problem.
* Ground loop isolater from Monoprice (suggested above)
* longer higher quality sub cable (right now I have shorter cables that are extended)
* RCA splitter, to try the L/R inputs instead of LFE
I'll report back once MP ships all my stuff. Thanks again, looking forward to less hum and less shock
Farhan
fnthawar is offline
post #6 of 6 Old 02-21-2011, 11:29 AM - Thread Starter
fnthawar's Avatar
Alright the humming has been greatly reduced. It's mostly due to a higher-quality cable w/o extensions.
I'm still miffed that there is current flowing through the wire (even when the power is off) so I'm thinking I need to duct-tape or heat-shrink both the Sub side and amp side as just touching the connector causes current to go through your hand
fnthawar is offline
