Rw12d - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 02-18-2011, 05:16 PM - Thread Starter
DMSUCHY's Avatar
I just bought a RW12D to replace my old KSW 12 with a blown amp. Anyone that owns one mind giving me thier settings for movie and music? I want as much effect as I can get out of it for movies, thanks.
DMSUCHY is offline
post #2 of 18 Old 02-19-2011, 05:51 PM - Thread Starter
DMSUCHY's Avatar
Anyone with a digital sub from Klipsch? Should I be using "punch" "depth" or "flat" mode for action movie watching??
DMSUCHY is offline
post #3 of 18 Old 02-19-2011, 08:19 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
I like "punch", but that's me and I'm sure my room's totally different. I also have a sub from a different line (RSW).
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
post #4 of 18 Old 02-20-2011, 09:24 AM - Thread Starter
DMSUCHY's Avatar
Cool, Holt thanks for the input! Anyone else?
DMSUCHY is offline
post #5 of 18 Old 02-20-2011, 09:40 AM
DanLW's Avatar
Liked: 36
Judging from the names, heres what each will get you:
Punch: EQ boost probably around the 40-50Hz range.
Depth: Lower overall output, but greater extension into the low frequencies.
Flat: Flat response with no EQ applied.
It depends on personal preference. If you listen to music, you probably want punch. If you want to hear the lower frequency effects in movies, you may want depth. Flat would be the most natural response curve.
DanLW is offline
post #6 of 18 Old 02-20-2011, 09:56 AM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
This sounds about right, and there's also "music/movie/night" settings as well. If you're listening/watching to a wide variety of sources you drive yourself a little crazy switching back and forth, or you can find a good overall setting and "set it and forget it."
holt7153 is offline
post #7 of 18 Old 02-20-2011, 11:05 AM - Thread Starter
DMSUCHY's Avatar
Yep, I'm using a little higher volume and "depth" under my movie mode and less volume and flat for my "night" mode. Will run flat and do Audessey this afternoon to see what my Denon AVR puts the pass too. Thanks guys
DMSUCHY is offline
post #8 of 18 Old 02-20-2011, 01:54 PM
MAGHUNTER's Avatar
Quoted: 28 Post(s)
I use the "set it and forget it" mode on flat. I just purchased a 2nd rw 12d when Newegg had it on sale. Both are set on flat at -18 on the subs and on Denon 3310 with level at -5. I am now a believer in dual subs. They sound awesome on both movies and music!
MAGHUNTER is offline
post #9 of 18 Old 02-20-2011, 02:11 PM - Thread Starter
DMSUCHY's Avatar
Wow, very cool. I should get another but the wife would kill me and thinks it's too loud now. Thanks
DMSUCHY is offline
post #10 of 18 Old 11-24-2011, 09:24 AM
Archaea's Avatar
Quoted: 2890 Post(s)
Liked: 2487
$300 shipped today at newegg for Black Friday.
http://slickdeals.net/forums/showthread.php?t=3602986
Archaea is online now
post #11 of 18 Old 11-24-2011, 09:55 AM
spyboy's Avatar
Liked: 47
Here is a link to the Sound&Vision test of the RW-12D. It is part of a 5 sub shootout. The review of the RW-12D starts on page 4 and continues on page 5:
http://www.soundandvisionmag.com/art...ofers?page=0,3
This is about as good as you can do for $300.
spyboy is offline
post #12 of 18 Old 11-24-2011, 04:53 PM
capricorn kid's Avatar
Liked: 25
For action movies if you don't have a separate eq device,use the depth setting. It gives a boost around the 30hz region. Punch boosts up the 60hz region. Flat gives no type of boost to any range. The movies, music and night settings can be saved when you personalize them to your taste. For example, when you select movies you can scroll thru the menu and select depth...then adjust the volume to a desired level...select a phase setting...then save your settings. Then you can go to the "music" setting and adjust those to your tastes. Do the same to your night settings. Then when you are watching a movie you can simply recall your settings by selecting "movie". When you listen to music you can recall the settings by selecting "music". The sub saves whatever you last had it on. I only use mine for movies so I never touch the top panel controls. It might sound a little complicated the way I explained it but once you start using it, it is very simple.
Klipsch Synergy 3 speakers
Dual Klipsch RW 12D subs
Velodyne SMS-1
Sony STR-DG 720
Panasonic BDT 460 bluray player
Panasonic PT-AE 8000u projector
capricorn kid is offline
post #13 of 18 Old 01-31-2012, 05:30 PM
bifftannen's Avatar
So I gotta be honest....I "upgraded" to the RW-12D from a HTIB Infinity 8" sub (yes, 8") and the difference is indiscernable. seriously. I am so disappointed. Apparently folks were right about shelling out the extra $$ for a REAL sub.
bifftannen is offline
post #14 of 18 Old 01-31-2012, 06:32 PM
Kini62's Avatar
Quoted: 1441 Post(s)
Liked: 1333
4 threads
What did you do? Search for all the RW-12D threads and are going to post the same whine in everyone?
You're not going to get any help doing cr@p like that.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #15 of 18 Old 01-31-2012, 06:44 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Originally Posted by Kini62 View Post
4 threads
Wow, he did four, I seen the others but not this one...
I have a feeling he is on another forum doing the same thing.. lol
HAMP568 is offline
post #16 of 18 Old 01-31-2012, 06:53 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Check this out http://www.avsforum.com/avs-vb/showthread.php?t=1390563
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #17 of 18 Old 01-31-2012, 06:54 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
There good subs for Movies/Games, and for rap music, but not so much for rock.
HT~
2.1CH~
Joshjp is offline
post #18 of 18 Old 09-15-2012, 01:31 AM
rodeothor's Avatar
Does or have anyone used a remote control? I want to get a remote that really works the functions of the sub.
rodeothor is offline
