Official Chase Home Theater Owners Thread - Page 30 - AVS Forum | Home Theater Discussions And Reviews
post #871 of 882 Old 05-12-2017, 04:49 PM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
Update: 2 of the three SA 100 amps went bad....any recommendations?
Dr_jitsu is offline
post #872 of 882 Old 05-13-2017, 08:33 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 713
Get an external amp like the I Nuke 3000 DSP.
derrickdj1 is offline
post #873 of 882 Old 05-16-2017, 09:51 AM
JimWilson's Avatar
Quoted: 1500 Post(s)
Liked: 1991
I have an SA-1000 if you're interested in a direct replacement. PM me for info.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #874 of 882 Old 05-16-2017, 11:26 AM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
Hi Jim. Given the track record of these amps I am not sure I would buy another. I am wondering if they are worth repairing.
I should probably try working with them a bit on my own first, although I have zero technical ability.
I did my own wiring, but hired someone to tune my system.
Dr_jitsu is offline
post #875 of 882 Old 05-16-2017, 11:27 AM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
https://www.bhphotovideo.com/c/produ...reo_Power.html
Dr_jitsu is offline
post #876 of 882 Old 05-16-2017, 11:44 AM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
Fixing a Dayton SA1000's hum.
Just as I thought, it seems these amps are not very durable. I got 4.5 years out of them. That durability is probably better than average for most Chinese manufacturing (unless Taiwan, which actually is pretty good quality) which I knew when I purchased them.
Dr_jitsu is offline
post #877 of 882 Old 05-16-2017, 12:29 PM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
OK, just did some dumb guy trouble shooting. The hum is actually more of a hiss, and it is coming from the sub itself.
Dr_jitsu is offline
post #878 of 882 Old 05-17-2017, 06:24 AM
JimWilson's Avatar
Liked: 1991
Is the sound something new or has it been happening for awhile?
post #879 of 882 Old 05-17-2017, 02:32 PM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
Hi Jim, thanks for the help.
Maybe 6 months. I tried isolating the cables a bit and also plugging the amps into my "sound conditioner" with no luck.
I still have 2 active 18 inch subs.
Dr_jitsu is offline
post #880 of 882 Old 05-17-2017, 04:59 PM
JimWilson's Avatar
Liked: 1991
Is it possible you have the infamous cable TV ground loop issue? I know the PE amps are highly susceptible to that.
post #881 of 882 Old 05-17-2017, 11:35 PM
Dr_jitsu's Avatar
Quoted: 77 Post(s)
Liked: 62
Possibly. Any advice is appreciated. https://support.native-instruments.c...Buzzing-Sounds-
I have one amp powering 2 subs that is fine and it is separate outlet.
Dr_jitsu is offline
post #882 of 882 Old 05-18-2017, 07:59 AM
JimWilson's Avatar
Liked: 1991
I bought one of these to isolate the cable line and it worked very well. Hum is now gone.
