Bad sub Hum caused by cheap cable - AVS Forum | Home Theater Discussions And Reviews
Old 03-15-2011, 08:03 PM - Thread Starter
Thenum13's Avatar
So I ordered a 50 ft sub/rca cable from monoprice for under $5.00 When I plug it into my sub's input and turn the sub volume up I get a bad hum. I'm sure it is not a ground loop issue as I tried an isolator and it only made it worse. I tried different outlets but the problem remains. I tried a different cable and BAM it went away. I need at least a 25 ft cable and I really don't want to pay too much. Any suggestions?
This is what I was using
This is what I am considering (notice this is only 25 ft I think I can get away with this)
Thenum13 is offline
Old 03-15-2011, 09:17 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
looks like the one you're considering is a thicker cable-I've never had a problem with MP cables so maybe you got a dud?
Anything good in life is either illegal, immoral, or fattening.
holt7153 is offline
Old 03-15-2011, 09:30 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
I just used three of those cables you used to connect an analogue signal, audio and video, from a HD DVR in my second bedroom to an older non HD TV in another bedroom with no issues at all. They are also 50ft in length.
Secret Squirrel is offline
Old 03-15-2011, 09:34 PM
enricoclaudio's Avatar
Quoted: 1104 Post(s)
Liked: 1133
I been using a pair of this for the last three years without any problem.
http://www.amazon.com/Acoustic-Resea...0246328&sr=8-1
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 03-16-2011, 10:36 AM
signmastr's Avatar
Quoted: 12 Post(s)
Contact MonoPrice. They will probably just send u another cable. Very good customer service.
signmastr is offline
Old 03-16-2011, 04:01 PM
Speedskater's Avatar
Quoted: 20 Post(s)
Make one yourself using a co-ax like Belden #8241F, it has a heavy low resistance shield.
Kevin
Speedskater is offline
Old 03-16-2011, 06:54 PM - Thread Starter
Thenum13's Avatar
I would just like to point out that almost all my cables are from monoprice I've never had a problem with them. One bad $4.75 cable does not change my opinion of them at all.
Thenum13 is offline
Old 03-16-2011, 07:16 PM
dnoyeB's Avatar
It must be a damaged cable, I'd try another.
If you move the speaker right next to the AVR, and have the cable all bundled in one spot instead of stretched across the room, do you still get the hum?
Exactly how high are you turning the volume?
Signature.
dnoyeB is offline
