Need musical sub recs, ~$150, $200 max - AVS Forum | Home Theater Discussions And Reviews
post #1 of 25 Old 03-29-2011, 12:52 PM - Thread Starter
hbfs's Avatar
I have poked around these forums a bit and have found many recommendations for the BIC V1220 and the BIC F12, but I have also seen comments saying that they are better for HT rather than music. I will be using the sub for music 80-90% of the time. What other options do I have for a more musical sub in the price range?
Also, how do the V1220 and F12 compare with each other?
hbfs is offline
post #2 of 25 Old 03-29-2011, 01:00 PM
benclement11's Avatar
There is good reason for this.
It is easier to make a cheap sub that goes boom reasonably loud for home theater than it is to make a sub that is accurate. With that budget you won't have much luck finding a tight musical subwoofer. I don't know what your expectations are though...maybe you'll like it. I didn't so I dropped $1200 on a Rythmik instead.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #3 of 25 Old 03-29-2011, 01:02 PM - Thread Starter
hbfs's Avatar
I realize that my budget is very restricting, but I would hope that there are still handful of subs that are reputable and perform reasonably well for the price. I'm not expecting anything amazing. Any recs?
hbfs is offline
post #4 of 25 Old 03-29-2011, 01:13 PM
kesando's Avatar
Liked: 31
You can check out the LAVA LSP8 $197 before 15% AVS discount:
http://www.lavasubs.com/8_inch/power...subwoofer.html
Some have said that Lava subs do well with music considering the price. I plan on picking up two 12" subs for my bother's new system
You can save up a little bit more and check out these:
HSU STF-1 $269 + s/h
http://hsuresearch.com/products/stf-1.html
Outlaw Audio M8 (on sale right now for $224 shipped
You best bet is the Emotiva Ultra 10 for 329 shipped:
http://emotiva.com/ultra_sub10.shtm
kesando is offline
post #5 of 25 Old 03-29-2011, 01:17 PM - Thread Starter
hbfs's Avatar
I'll check out the Lava sub, thanks!
I really can't stretch my budget past $200, though.
How would the 8" driver compare to the BIC 12" drivers?
hbfs is offline
post #6 of 25 Old 03-29-2011, 01:37 PM
kesando's Avatar
Liked: 31
I would suspect the BIC subs to play deeper and a bit louder at the expense of some SQ with music. Can you spring for the 10" at $209 after discount? That way you get better extension and impact when you watch the occasional movie
kesando is offline
post #7 of 25 Old 03-29-2011, 01:53 PM - Thread Starter
hbfs's Avatar
I might, I'll look into it, thanks! I'm still open for more recs, just exploring my options here.
hbfs is offline
post #8 of 25 Old 03-29-2011, 02:17 PM
NuSoardGraphite's Avatar
Quoted: 322 Post(s)
Liked: 295
hmmm...this thread is interesting for me as well. When I decide to go searching for Subs, my budget will likely be around $200 maximum as well. Although I'm not expecting a sub that is capable with both movies and music, mainly I will be getting it for enhanced movie sound effects etc.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #9 of 25 Old 03-29-2011, 04:46 PM
texraider's Avatar
I have both, dual BIC F12s and dual Lava LSP10s. Its true the F12s are more geared for HT and go deeper, they give you a bigger boom but they are a little limited when it comes to music. The Lavas are more of a musical sub, they don't go as deep as the BICs but they are smoother and punchier when it comes to music. Other than that, your pickings are kind of slim when it comes to a $200 max budget.
texraider is offline
post #10 of 25 Old 03-29-2011, 04:47 PM
texraider's Avatar
I would go for the BIC F12 over the Lavas for HT use.
post #11 of 25 Old 03-29-2011, 04:59 PM - Thread Starter
hbfs's Avatar
I'm very interested in the LSP10's now. Anyone have experience with LSP08's?
hbfs is offline
post #12 of 25 Old 03-29-2011, 05:40 PM
texraider's Avatar
I'm not sure if you know this, but they will give you a generous 15% discount if you email Lava and tell them you are a member here at AVS. They will give you a unique code and this will bring down the price on their subs a little more for you. They are a friendly group and got good customer service, so email them and say hi.
post #13 of 25 Old 03-29-2011, 06:12 PM - Thread Starter
hbfs's Avatar
Oh yes, it was mentioned earlier in this thread. That's what's enabling me to consider the LSP10's with my budget! I'm still wondering how the LSP08 and other subs compares though, for use in a room at most 15' x 15' x 12'.
hbfs is offline
post #14 of 25 Old 03-29-2011, 06:31 PM
kesando's Avatar
Liked: 31
The output of the LSP10 should be deeper, louder and better able to handle a larger room. I personally would only use the 8" in a bedroom setup.
If I'm not mistaken, I believe Lava recommends the 10" for music
kesando is offline
post #15 of 25 Old 03-29-2011, 06:50 PM - Thread Starter
hbfs's Avatar
Hmmm.. I will be using the sub in a bedroom for the forseeable future.. if budget wasn't such a tight issue for me, I would go for the LSP10 straight away, but now I'm conflicted!
hbfs is offline
post #16 of 25 Old 03-29-2011, 06:54 PM
kesando's Avatar
Liked: 31
Give Lava a call and see what they say. I would still go with the 10 as you will less likely have to upgrade later. Either way you should be happy.
kesando is offline
post #17 of 25 Old 03-29-2011, 07:43 PM - Thread Starter
hbfs's Avatar
If it is relevant, I should mention that this is for a PC setup to pair with my Audioengine A2s.
hbfs is offline
post #18 of 25 Old 03-29-2011, 08:10 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Lava's are not what I'd call a musical sub. They are fun for HT but they aren't going to be all that great with music. The cheapest musical sub that's been suggested is the Emotiva Ultra 10". That will be your best bet. Stay away from ported subs for music. In that price range they're going to be one note wonders.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #19 of 25 Old 03-29-2011, 08:16 PM - Thread Starter
hbfs's Avatar
I have taken a look at that already, and it is way out of budget. I guess what I mean by musical sub at this price range is a relatively musical sub compared to the other options I have within budget.
hbfs is offline
post #20 of 25 Old 03-30-2011, 04:42 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It's going to be really hard to find a musical sub at that price. At your budget I think your mostly going to get boomy, flabby sounding subs. Perhaps you could wait a while and save up a bit more cash?
post #21 of 25 Old 03-30-2011, 11:15 AM - Thread Starter
hbfs's Avatar
That's not an option, as I plan to make a purchase in the next few days. Right now, I am pretty much set on the Lava LSP10 with the AVS discount, which is already slightly stretching my budget. However, I am still open to suggestions if you think there's a better musical sub within my budget for less than the LSP10!
hbfs is offline
post #22 of 25 Old 03-30-2011, 11:40 AM
kesando's Avatar
Liked: 31
Have you read the Audioholics review on the 12" model?
http://www.audioholics.com/reviews/s...sp12-subwoofer
perhaps this will help you decide
kesando is offline
post #23 of 25 Old 03-30-2011, 11:57 AM - Thread Starter
hbfs's Avatar
Yes, unfortunately the LSP12 is out of my budget.
hbfs is offline
post #24 of 25 Old 03-30-2011, 12:37 PM
kesando's Avatar
Liked: 31
No I meant to read it as source to help give you an idea of what you can expect from the LSP10
I you can spend no more than around $200 then the Lava will probably give you the best music SQ for the money Is the Emotiva a better sub? YES. However if the review of the LSP12 is to be believed, you would be hard pressed to find a sub with descent music SQ and "midbass punch" at your price point other than the Lava. I say go for it. If you don't like it then Lava has a generous return policy.
Otherwise you can stretch a bit more and get the Oulaw M8 at $224 though I am unsure of how much better (if any) it is over the Lava.
kesando is offline
post #25 of 25 Old 03-30-2011, 07:44 PM - Thread Starter
hbfs's Avatar
Thanks! Unless something comes up in the next day or two, I will be purchasing the LSP10.
hbfs is offline
