Connecting sub to stereo amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-25-2011, 03:33 PM - Thread Starter
Heinrich S's Avatar
Liked: 30
Hello,
I need some advice as I'm really not clued up on this stuff. I want to connect my subwoofer to a stereo amp. It has speaker terminals at the back. I assume these are 'high level' speaker connections ?
Do I connect cable from these speaker terminals on the sub to the speaker terminals at the back of my stereo amp ? Is that it ? Or must I feed cable from the sub to the stereo amp and then back to the speakers ? Just a little confused. I'm sure it's a simple process so if someone could please offer some advice.
I assume.....connecting cable from sub speaker terminals to stereo amp terminals would be ALL that is required but if someone can please clarify it would be appreciated. Thanks !
Heinrich S is offline
post #2 of 9 Old 04-25-2011, 03:43 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
How it's usually done, is to hook up the speaker outputs from the receiver to the speaker level inputs of the subwoofer ( which are probably becoming uncommon.)
There are options that would allow for use of a sub with only line level inputs, but I will assume you are talking about subs with speaker (high level inputs.)
Then hook the sub speakers outputs to the speakers.
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 9 Old 04-25-2011, 04:08 PM - Thread Starter
Heinrich S's Avatar
Liked: 30
Do you mean connecting from the speaker outputs from the receiver to the speaker terminals at back of the sub ? What would happen if I just take cable from the subwoofer speaker terminals to the back of the stereo speaker terminals ?
I assume so. It has the speaker terminals...red and black...so that's high level. Am I correct ? I have a Jamo Sub300.
post #4 of 9 Old 04-25-2011, 04:20 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 456
Yes,
Same thing.
Yes.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #5 of 9 Old 04-25-2011, 04:43 PM - Thread Starter
Heinrich S's Avatar
Liked: 30
Thanks Kal and Michael ! I assume this is the best way to connect my sub to stereo amp ? Are there better ways, or is the method described above the most common way ?
Any pro or con to running speaker cable from amp to sub (line in), and then from sub (via line out) to speakers. I read somewhere that this is another method....that you connect cable from amp to sub and then to speaker. Not sure why one would use that method vs the simpler one that was described above (simply connecting cable from sub amp terminals to stereo amp terminals)
post #6 of 9 Old 04-25-2011, 05:11 PM
Quoted: 672 Post(s)
Liked: 456
IMHO, there are better ways but, afaik, you do not have any other options with your amp......or do you?
As I said, same thing.
Kal Rubinson
post #7 of 9 Old 04-26-2011, 02:04 AM - Thread Starter
Heinrich S's Avatar
Liked: 30
I think if you gave me some options I might be able to tell you if my amp has them ?
Why do some people go the extra step to connect cable from stereo amp---sub amp----back to speaker when it's the same as sub amp to stereo amp ? Just trying to understand why people use the longer method. Sorry, do not intend to be a nuisance.
post #8 of 9 Old 04-26-2011, 07:04 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
If you are using just a stereo amplifier then they do not have any bass management features. IOW there is not a built in feature for you to set the crossover in the amplifier so that the sub gets everything below 80Hz and the main speakers get everything above 80Hz. So what you have to do, in this case, is run the speaker level output from the amp to the sub which is sent the full frequency signal from the stereo amp. The sub has a built in crossover. The sub will extract only the signals that are below the crossover you set on the Jamo and then the remaining frequencies are then passed on to the speaker level outs to the main speakers (which are still powered by the stereo amp not the subwoofer amp). This is how most subwoofers were setup before the AVRs started to add Bass management. This setup alows the stereo amp to work with less effort because the main speakers are now only required to play the higher frequencies. Hope this helps you understand a little better how to use speaker level inputs.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #9 of 9 Old 04-17-2015, 02:24 PM
Liked: 0
So what you're saying is even if there are two sets of outputs on my amp, which could go directly to bookshelf speakers and a sub separately, its more efficient and will separate the frequencies better if I use one set of amp outputs directly to the sub and then connect speakers to the sub? What splitters or adaptors are needed to do this? Thanks!
pbody27 is offline
