The New Master List of BASS in Movies with Frequency Charts - Page 319 - AVS Forum | Home Theater Discussions And Reviews
 7139Likes
post #9541 of 27560 Old 08-11-2013, 03:33 PM
audiofan1's Avatar
Quoted: 1663 Post(s)
Liked: 1691
Originally Posted by wse View Post
What brands can do 5Hz would JLAUDIO FATHOM F 113 go that low?
My KK DXD12012 has measured output down to 2.5 .
audiofan1 is offline
post #9542 of 27560 Old 08-11-2013, 03:37 PM
jlpowell84's Avatar
Quoted: 1710 Post(s)
Liked: 739
Pretty sure a lot depends on the room. Closed sealed room with multiple sealed subs. Or some ability of serious output like the OS partnered with some generous room gain. I plan on someday doing a smaller dedicated room built with sub performance in mind. Prob just one row of seating, sealed room, constructed with all of the traditional soundproofing, de coupling, double drywall type stuff. But sticking a few submersives or sealed Captivators in a small room should do the trick. Or like 8 SI 18's...
jlpowell84 is offline
post #9543 of 27560 Old 08-11-2013, 03:37 PM
Toe
Toe's Avatar
Quoted: 1517 Post(s)
Liked: 1883
Originally Posted by audiofan1 View Post
Ain't that for sure ! even though I can get around 84db down to around 4-5 hz which can be felt on WOTW it would be something to hear it at full reference but not somthing high on my list , perhaps when I get a second and talk myself into a third and fourth ! It will be nice! but these days as long as the point comes across and is conveyed , I'm good .
Thanks for proving my point. biggrin.gif In all due respect, 84db is not even worth mentioning and the point is nowhere close to coming across at those anemic levels. Don't take offense to that, it is just reality and I am in the same boat as my PB13s fall off in the low teens and don't do anything in the single digits either. Maybe some DIY is in both our futures. My BKs hit single digits, but I'm sure its not the same as the subs doing it. smile.gif
Toe is online now
post #9544 of 27560 Old 08-11-2013, 04:16 PM
audiofan1's Avatar
Liked: 1691
DIY far down the road for me did a lot as a teen for car audio, I have always wanted to design and build my own floorstanders though and a sub afterwards if all is well with them maybe indeed. As for ULF output in those single digits you can add some room gain and Audyssey boost to that number I gave as the measurements were out into the room and its a bit better wink.gif but in the end I'll end up with a second while i wait out a decent priced hdmi 2.0 spec settled 4k FP, which might mean I may have 4 by then biggrin.gif
post #9545 of 27560 Old 08-11-2013, 04:49 PM
jchong's Avatar
Quoted: 12 Post(s)
Liked: 32
Originally Posted by MKtheater View Post
In LOTR:FOTR when the Balrog falls there is a shutter effect that is so cool. I don't know how low that is but Madaeel actually had me pause the scene and asked what the hell was that? That sealed the deal on a multiple sealed system for him! Just little things like that I never felt with my ported or horn systems.
What does this "shutter effect" sound or feel like? Gotta find that scene and test it out in my system.
jchong is offline
post #9546 of 27560 Old 08-11-2013, 05:09 PM
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
What is DIY and where can you buy them? Is there a website link you can provide? Thanks!
mantaraydesign is offline
post #9547 of 27560 Old 08-11-2013, 05:40 PM
audiofan1's Avatar
Liked: 1691
mantaraydesign likes this.
post #9548 of 27560 Old 08-11-2013, 05:44 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
I am not understanding the graphs you guys are showing me. So is the PINK color on the graph shows the Lowest bass like below 20Hz?
For the movie War of the Worlds, how low does that movie really produce in the lowest bass? Is it like 11Hz or lower?
This might help you to understand the SpecLab Graphs:
bossobass is offline
post #9549 of 27560 Old 08-11-2013, 05:57 PM
Quoted: 133 Post(s)
Liked: 33
LOL!!
I thought it was a brand name! I guess I should ask where can you buy parts to build a custom subwoofer?
post #9550 of 27560 Old 08-11-2013, 05:57 PM
Quoted: 133 Post(s)
Liked: 33
post #9551 of 27560 Old 08-11-2013, 06:04 PM
jlpowell84's Avatar
Liked: 739
LOL!!
This is an frequently used site
http://www.parts-express.com/
post #9552 of 27560 Old 08-11-2013, 06:06 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
It's quite simple to build a system that reaches reference level to 3-5 Hz. I've been enjoying it for 11 years and have posted exhaustively on the subject on this forum and the DIY subs forum.
Here's a subwoofer reproduction of Irene from BHD at the LP at reference level vs the direct inject digital version showing a virtually exact reproduction with no audible compression or distortions:
Here's the same system showing 112dB at 5 Hz at the LP with virtually no compression, which is more than enough to play any disc in my room:
Note the native response (outdoors or close-mic response) of the sub in the dashed trace. The rest is "room gain", which every room has.
The key (and the point everyone seems to fail to note in these discussions) is to make sure that your signal chain is feeding 5 Hz to the subs and the subs amplifier(s) are flat to 5 Hz.
Most signal chains (Player, if using analog out, AVR SW out, external EQ, amplifier) roll off between 5-20 Hz at varying rates and the roll off of all of the components in the chain are additive. So, no 5 Hz in, no 5 Hz out. No amount of amp power or driver displacement will change that.
post #9553 of 27560 Old 08-11-2013, 06:32 PM
jlpowell84's Avatar
Liked: 739
post #9554 of 27560 Old 08-11-2013, 07:08 PM
Quoted: 133 Post(s)
Liked: 33
Thanks for the link!
I really would not know where to even begin building a custom subwoofer from this website. Maybe some of you can help me if I provide some details of what I would like.
I am looking to build an 18" driver subwoofer with an External amp. I did not see any external amps from Parts Express but I am looking for something like between 1000 watts amp or more powerful.
I probably should not ask these questions within this thread though.
post #9555 of 27560 Old 08-11-2013, 07:14 PM
Mrkazador's Avatar
Quoted: 259 Post(s)
Liked: 388
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-7094
The EP4000 is probably one of the most popular pro amps for powering subs. It is a little expensive now so I would go with  the iNuke 3000 with DSP for a little more cash.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-748
http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-6706
Mrkazador is offline
post #9556 of 27560 Old 08-11-2013, 07:15 PM
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
Watched Oblivion last night at -10 MV, and then replayed bosso's SL scenes at reference...
At -10, I would have put it in the 4.5 category...at reference, it definitely hangs with all the big boys and gets my nod for a 5! As many others have said, the bass has a lot of variation, which is always cool. However, what really makes it great IMO, is that when it delivers those big bass scenes...it DELIVERS it! Each scene has plenty of ULF that really add to the realism...this is where most movies fall short. There's a depth and weight to all those ULF scenes, which really make it outstanding. I don't think TIH and WOTW are as consistent in delivering ULF on nearly every big scene... Additionally, there is no mistaking that this has HOT levels of bass throughout the movie.
My favorite scene however is one that no one has referenced yet. It happens at 1:52:21 or so when they are entering to see Sally. It starts with a higher frequency sine wave, and then at the time that the time stamp hits, it goes very low...it's pretty much all by itself too. If I had to guess, it's centered around 13-14hz or so...might be lower even. In my room, this is a great 'wobble' effect. (I'd love for someone to graphs this scene!)
Overall, the movie was decent...but the bass was killer. Also, the overall audio track and surrounds were unbelievable. Instabuy in my book! biggrin.gif
missyman likes this.
dominguez1 is offline
post #9557 of 27560 Old 08-11-2013, 07:37 PM
Quoted: 133 Post(s)
Liked: 33
So if I want to do the Dual subwoofer setup, I need to buy 2 external amps correct? Let me put it this way, each external amp is for 1 subwoofer? Let say if I want to make 6 subwoofers, I need to buy 6 external amps correct?
post #9558 of 27560 Old 08-11-2013, 07:39 PM
MKtheater's Avatar
Quoted: 1637 Post(s)
Liked: 1165
WOTW has more ULF just based on the graphs, higher levels of it too. I have not seen this movie yet as my system is down until my new build is finished.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is online now
post #9559 of 27560 Old 08-11-2013, 07:42 PM
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
What are you building now?
post #9560 of 27560 Old 08-11-2013, 07:48 PM
wse
wse's Avatar
Quoted: 2083 Post(s)
Liked: 758
Yes, my dream as well just two rows of seats I need six seats:) I think I will just use 4 subs one in each corner of the room, but on the other hand the largest screen I can get plus at least 11 speakers probably self powered studio monitors like the FOCAL SOLO6 Be. This will minimize the number of boxes, just a Pre/ pro with OPPO BDP-125 in a few years I intend to be no more than 7 feet away from each speaker smack in the middle smile.gif
wse is online now
post #9561 of 27560 Old 08-11-2013, 07:50 PM
wse
wse's Avatar
Liked: 758
WOTW goes to <1 Hz in the scene I posted. eek.gif This might help you to understand the SpecLab Graphs:
THANK YOU very helpful
wse is online now
post #9562 of 27560 Old 08-11-2013, 07:59 PM
MKtheater's Avatar
Liked: 1165
I member came by today and bought all 12 drivers or all 6 subs after two demos! I forgot how awesome they were built! These little suckers were very heavy at 200 pounds each. He will post his impressions of my room and the experience of getting this into a small SUV or crossover. I did say bring a bigger vehicle! Anyways I played at reference with the bass 8 dBs hot with LOTR:FOTR and 5 dBs hot for WOTW. They wondered why so many complained about reference being too loud or sounding bad! Man those subs were built extremely well.
I am trying out IB for the first time with those 24's!
Marantz 7702 Atmos
Speakers- TBD
post #9563 of 27560 Old 08-11-2013, 08:01 PM
MKtheater's Avatar
Liked: 1165
Oh yeah, my new wedge 10 surrounds are awesome but did no realize how big they are! Holy Snikey's!
Marantz 7702 Atmos
Speakers- TBD
post #9564 of 27560 Old 08-11-2013, 08:13 PM
duc135's Avatar
Quoted: 155 Post(s)
Liked: 225
A single amp can power one or more drivers depending on how much power each driver needs and the resistance of the coils. For example, my new build in progress will be four sub drivers connected to a single amp.
duc135 is offline
post #9565 of 27560 Old 08-11-2013, 08:45 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Bassobass what sub setup do you have?
Currently, this one. Still tweaking, little by little. Have been very busy this year and really haven't had the time to run through it completely yet.
The signal chain is -3dB @ 3 Hz. I'm using the OPPO 105 as a pre/pro/player into the signal shaper I designed and built that's flat to DC. 8 X 15" long throw drivers, approx 36 liters of displacement and 1-9KW peak amp for each stack.
I capped the scene you're talking about, but I missed it when I loaded the flash drive to bring the caps from the Dell to the Mac. I believe you are exactly correct in the 10-15 Hz assessment. When I get a sec, I'll upload it and we'll see...
I capped 1:52:06 to 1: 53:04 and know exactly what you're sayin'.
post #9566 of 27560 Old 08-11-2013, 11:48 PM
eNoize's Avatar
Quoted: 40 Post(s)
Liked: 89
Oblivion was fantastic in terms of bass -- good, decently entertaining story otherwise. However, I don't know that I'd go as far to suggest it's a contender against 'WotW,' 'TIH' or 'FotP.' Still, it's an excellent soundtrack and loads of fun. My vote is at around 4 or 4.5
Here's what it looks like between 01:52:00-01:53:00, listening at -10 Warning: Spoiler! (Click to show)
"Welcome Home Jack" - when Jack finally meets Sally
And then, here's the grand finale between 01:55:00-01:56:00 Warning: Spoiler! (Click to show)
"Sally Explodes" - when Jack denotes the bomb
M. Enois Duarte
High-Def Digest
eNoize is offline
post #9567 of 27560 Old 08-12-2013, 07:14 AM
Cowboys's Avatar
Liked: 107
Wow, these look handsome. Which drivers are those?
Cowboys is offline
post #9568 of 27560 Old 08-12-2013, 07:27 AM
MKtheater's Avatar
Liked: 1165
www.bossobass.com
Marantz 7702 Atmos
Speakers- TBD
post #9569 of 27560 Old 08-12-2013, 07:29 AM
MKtheater's Avatar
Liked: 1165
The wobble effect happens with the fall of Balrog as well. I bet it is 10-15hz but I have to spec lab it, now that I can! The only thing I could do right now is spec lab things.
Marantz 7702 Atmos
Speakers- TBD
post #9570 of 27560 Old 08-12-2013, 07:37 AM
dominguez1's Avatar
Quoted: 969 Post(s)
Liked: 710
There is also a great suspense bass line somewhere in the 17:00 - 19:00 mark. It is when he is in the Skav hideout and is searching for the drone. As he walks up to the drone there is another subtle shutter/wobble effect that is very cool. I love those subtle, tension builder, ULF effects!
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
