The New Master List of BASS in Movies with Frequency Charts - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 7139Likes
Old 09-22-2011, 04:57 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Originally Posted by FilmMixer View Post
While infrasonic material is fun/cool/impressive/etc... it is so room and system dependent to recreate faithfully in different environments, even on dubbing stages, that to use it as a story telling device is not something that should be counted on... filtering off material below 20Hz is fairly common practice for some FX mixers... it's actually fairly good production practice for the reasons I just mentioned..
I'll see if I can ask the original mixer what his intension is/was... I also just visited the room at Fox where this work was done, and I can also inquire about their practices, etc... I will let you all know if I hear anything...
I do not own the Bluray of M&C, but the Bosso Bluray spectrograms look like the LFE channel is either missing or the disc is being played back as 5.0 content.
The loud action effects of the DD/DTS version of the DVD were heavy in the 30 to 50 Hz area on the LFE track. The Bluray version does not show any action there at all. That is hardly the infra area.
J_Palmer_Cass is offline
Bass Enabler
Scott Simonian's Avatar
Quoted: 5494 Post(s)
Liked: 4424
I just think it's odd that this was specifically for the BD release. Who knows if there was significant infra content in the theater but the dvd definitely has it in spades.
Just... odd.
Scott Simonian is offline
Old 09-22-2011, 05:09 PM
FilmMixer's Avatar
Quoted: 1768 Post(s)
Liked: 2185
To me, those two pictures don't look "right" if they are indeed the exact same time and playback level, compensation for DN, etc....
I've put out my feelers.. I'll let you guys all know what I find out.
FilmMixer is online now
Old 09-22-2011, 05:28 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Thanks FM!
Any chance you could find out why Tron:Legacy has so much clipping? Was it the remix that Kosinksi (sp?) did?
JSS
maxmercy is offline
Old 09-22-2011, 05:33 PM
FilmMixer's Avatar
Liked: 2185
Originally Posted by maxmercy View Post
Thanks FM!
JSS
I don't think that Kolinski did the remix all by himself..
I am going to see Gary, who mixed the film, at the beginning of November... we will have a nice long talk about it then..
Old 09-22-2011, 06:20 PM
Bass Enabler
Liked: 4424
Awesome! Thanks, FilmMixer.
Old 09-22-2011, 06:24 PM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
Looking forward to it....
JSS
maxmercy is offline
Old 09-22-2011, 08:16 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
I'm sure we'd all appreciate hearing the responses about that. I have to say, though, having both versions, the difference in realism and storytelling is night and day in that particular opening cannon fire sequence. The DVD's DTS mix is immersive, potent, and thrilling. If you've ever heard big cannons fired up close and personal in real life, this is a reasonably accurate presentation of the effects on the ears and body, and it really sets the tone of the movie. The BR mix is flat, dry and lacking by comparison.
nube is offline
Old 09-23-2011, 08:32 AM
Ricci's Avatar
Quoted: 205 Post(s)
Liked: 518
Back when all of the discussion over the dissapointment with the M&C BR was going on didn't a member from overseas (France?) post spectrum plots that seemed to indicate that their version was not filtered in the same way as the NA version?
Ricci is offline
Old 09-23-2011, 09:08 AM
Bass Enabler
Liked: 4424
It was the French audio track that I believe is unfiltered. It's on the US Blu-ray disc.
Old 09-23-2011, 09:52 AM
Quoted: 393 Post(s)
Liked: 118
Is there more than one M&C Bluray for the US?
The audio in this version is called better than the DVD per the customer reviews!
Quote: "The audio is the real spark that ignites Master and Commander, bringing life to the action. This was apparent even in the DVD version, but the Blu-ray goes beyond the excellent sound quality of the earlier release."
http://www.amazon.com/Master-Command...ef=pd_cp_mov_1
Old 09-23-2011, 09:58 AM
mojomike's Avatar
Liked: 30
The typical customer doesn't have bass below 30hz.
mojomike is offline
Old 09-23-2011, 10:38 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 234
yep, ...but if you make it for them they're happy,..we freaks are pissed
make it for us, everybody's happy
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 09-23-2011, 10:58 AM
Ricci's Avatar
Quoted: 205 Post(s)
Liked: 518
So we just watch the French version with subtitles and all is well.
Ricci is offline
Old 09-23-2011, 11:01 AM
Bass Enabler
Liked: 4424
Better off just watching the dvd, in that case.
Old 09-23-2011, 11:08 AM
Quoted: 393 Post(s)
Liked: 118
The 2011 version is English only!
Old 09-23-2011, 11:14 AM
Quoted: 393 Post(s)
Liked: 118
Actually, I don't think I care about ever "watching" M&C as a movie any more. These days I just use the DVD when I need a reference audio track.
Old 09-23-2011, 12:32 PM
BiGBADDABOOM's Avatar
I wonder what it would sound like if you stripped the English center channel and swapped it into the French DTS-HD MA track.
I imagine if you swapped the French LFE channel into the English track you wouldn't recover all of the low end. Unless someone knows where all of that <35Hz was placed.
Someone fluent in more advanced audio wizardry could probably swap out <50Hz on all channels and probably be ok with the vocals.
BiGBADDABOOM is offline
Old 09-23-2011, 01:06 PM
mojomike's Avatar
Liked: 30
Swapping the English center for the French one can mostly work, but not all dialog comes from the center. Sometimes it can come from offscreen left or right or sometimes even from behind. There are also sometimes intentional echos if the setting calls for it. The echos would sound odd in French.
It is common for pirated Russion DVD's in 5.1 to be dubbed over by English center channels and it works to a varying degree. (So I've heard)
It would work better to dub the LFE from the DVD over the LFE from the Blu-Ray. Or else, The entire DVD sound could be dubbed over the Blu-Ray sound. You would give up lossless, but gain the full bottom.
mojomike is offline
Old 09-23-2011, 01:11 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
I think in the French version they turn and run instead of fighting though.
btinindy is offline
Old 09-23-2011, 02:09 PM
That's what I was thinking, I guess it might work but would sound pretty strange at times.
If an LFE swap would solve it, you would source the French Blu-ray as it has French DTS-HD MA (assuming it's unfiltered like the French lossy track on the US BD).
The question then is whether the LFE channel contains the ULF or the main channels, or both.
Old 09-23-2011, 02:15 PM
Mpray1983's Avatar
Maybe someone could mux a copy with the French DTS-MA LFE track onto the English DTS-MA. Way beyond my skills but I'm sure someone like scubasteve could pull it off.
Mpray1983 is offline
Old 09-23-2011, 02:28 PM
That much is easy enough, decode the DTS-HD MA into discrete WAV with eac3to, swap the LFE and either pack into LPCM or encode back into DTS-HD MA (requiring the DTS encoder of course).
What may be more difficult is if the missing ULF is in the main channels or both the mains and LFE.
Old 09-23-2011, 03:36 PM
Mpray1983's Avatar
Could you take just the center Channel out of the English and swap it with the french version?
Old 09-23-2011, 06:02 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 666
Actually, the French version is yet a 3rd soundtrack, completely different from the English BR and original DTS DVD versions.
Here is the scene where Crowe is deafened by the cannonball hits on his ship. The French version has much more ULF to DC and a droning 4-6 Hz addition. Remember, I mic'd this, and was only good to 5 Hz back then. I can't find the direct-from-player screenshot, but it had content all the way down.
Bosso
bossobass is offline
Old 09-23-2011, 07:15 PM
upstate-avfan-da's Avatar
Quoted: 83 Post(s)
Liked: 41
Sorry to interject in MC talk.
Just wanted to give a vote on Ep V on blu ray, at least 4.5 maybe looking like a possibility for a 5. These destroyer fly by scenes are full of nice LFE. Just half hour in and the quality of the audio seems better than Ep IV so far.
PS might have to buy MC to see what all the discussion in about.
Bit by the upgrade bug, limited by the WAF
upstate-avfan-da is offline
Old 09-23-2011, 09:25 PM
Test123455's Avatar
I finally got a new sub, and can vouch that The Hulk definitely deserves a 5. The sequence with the sonic cannon scene (the whole part before and after too) is unreal!
Test123455 is offline
Old 09-24-2011, 06:41 AM
Toe
Toe's Avatar
Quoted: 1604 Post(s)
Liked: 1958
A few votes......
Thor, 5 stars. Yeah I know about the 20hz filter, but this one still deserves a 5 for amount, variety and pure LFE output.....awesome!!
Star Wars OT.....4 stars. Amazing for films of this age, but pale in comparison to the better/best modern LFE tracks.
Toe is online now
Old 09-24-2011, 07:22 AM
gwsat's Avatar
Quoted: 2586 Post(s)
Liked: 2870
Originally Posted by Toe View Post
A few votes......
I agree that the Thor BD has great LFE but then my HT audio system is capable of reproducing bass frequencies down to "only" 18Hz.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is offline
Old 09-24-2011, 07:44 AM
kemiza's Avatar
Liked: 92
Are the 2008 & 2011 M&C BD identical?
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
