The New Master List of BASS in Movies with Frequency Charts - Page 376 - AVS Forum | Home Theater Discussions And Reviews
 7137Likes
Old 10-17-2013, 11:58 AM
audiofan1's Avatar
Quoted: 1661 Post(s)
Liked: 1688
Originally Posted by Toe View Post
So Audiofan, now that we know your above speculation is not accurate and the mixes actually are identical, have you figured out what was making the 5.1 mix seem inferior in your setup? As Nube said, whatever post processing you were using is the most likely answer. I am now curious what post processing you used on the 5.1?
I plan on a second viewing this weekend to see as it was half way through when I switched tracks. As for processors I use a Marantz 8801 to which I bitstream from an Oppo 105 with Audyssey engaged and no Dynamic EQ. Nube may be right on the way the 8801 matrixed the 7.1 soundtrack. I would consider my setup very discerning of the smallest differences which is something that can be love or hate at times, the main difference here was a more spacious bubble vs. the tightly confined sound of the 5.1 mix which seemed to leave very little room for variation within the soundfield itself , now there is nothing wrong with that and it still sounded good but I did notice when increasing the bass level which was there, the overall loudness drowned out any pitch definition which I found switching to the DTS MA7.1 track restored and sub gained significant punch and more jolts through the concrete, this could merely be a difference of the timing or delay due to the matrixing and that extra 1 db! who knows! but it did give me what I consider 3.5 to 4 star bass wink.gif
audiofan1 is offline
Old 10-17-2013, 12:17 PM
Reddig's Avatar
Quoted: 170 Post(s)
Liked: 309
Originally Posted by nfraso View Post
Continuing the trend of filtered ULF, Man of Steel:
Damn so depressing!
JBL Pro Cinema/PSA subs/Crown power/Sony SXRD projection/Elite screen/Seatcraft Granadas
MANCHESTER UNITED!!
Reddig is online now
Old 10-17-2013, 12:24 PM
Reddig's Avatar
Quoted: 170 Post(s)
Liked: 309
Originally Posted by wth718 View Post
Yep, that's about what I heard. Most disappointing bass of the year. Not WORST (that would be The Hobbit) but most disappointing because so many of us had high hopes.
The Hobbit has been one of my biggest audio disappointments to date. Especially considering how good the LOTR trilogy sounds. Weird how HT mag scored it perfect IIRC as well as some others.
spidey.joe80 likes this.
MANCHESTER UNITED!!
Old 10-17-2013, 12:32 PM
Toe
Toe's Avatar
Quoted: 1500 Post(s)
Liked: 1871
What I was curious about was what type of post processing you used for the 5.1 track to take it to 7.1? The mixes are the same so whatever differences you are hearing is most likely due to whatever processing you are using to take the 5.1 to 7.1. If you listen to both tracks as they are, the only difference you should be hearing should be with whatever taking the track from 2 surrounds to 4 surrounds does for the surround info. In my setup for example this is very little since I sit right in the sweet spot where all my speakers are calibrated to which gives good stereo type effects for just 5.1 creating the illusion of pans and sounds coming from behind the listener where there are no speakers. The difference between this and actually using all 4 of my surrounds is not much because of this.
I am still curious though what post processing you are using to matrix the 5.1 to 7.1? I use PLIIx.
Toe is online now
Old 10-17-2013, 12:49 PM
audiofan1's Avatar
Liked: 1688
The selection was done in the 105 , the 8801 will still read out DTS MA with the number of channels displayed regardless of its a 7.1 or 5.1 or 6.1 unless another processing mode is selected such as Dpl II, multi ch stereo, DTS neo etc... But in this case it just matrix the rears of a 7.1 sound track into two without any further processing I'm aware of! I will confirm this later to be sure.
Old 10-17-2013, 12:56 PM
Toe
Toe's Avatar
Liked: 1871
Sorry, I misunderstood what you were doing. So you have a 5.1 setup and you are taking the 7.1 track and downmixing to 5.1? I think the same point still stands that the differences you are hearing are not due to a difference in the tracks since they have been verified to be the same mix, but rather due to whatever the downmix from 7.1 to 5.1 is doing.
Toe is online now
Old 10-17-2013, 12:58 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Originally Posted by lovinthehd View Post
Curious, can your software overlay one graph onto the other?
Here's nube's measurements compared:
He's right, no appreciable difference.
Thanks, looked to be a bigger difference than looking at it this way, altho since we're looking at a whole movie in a snapshot, arent' some of these differences significant?
lovinthehd is offline
Old 10-17-2013, 01:07 PM
nfraso's Avatar
Liked: 172
Hard to say, we'd have to do waterfalls of individual scenes. Doesn't seem worth it at this point considering both versions are equally poor ULF-wise.
Remember, it would only take one moment in one scene of something considerably different (say a single 15Hz hit at -25dB) to have that peak line shoot up in one version vs the other, and as you can see, it didn't.
nfraso is offline
Old 10-17-2013, 01:18 PM
audiofan1's Avatar
Liked: 1688
Kinda what I'm thinking as well !
Old 10-17-2013, 02:35 PM
mo949's Avatar
Liked: 1134
Originally Posted by audiofan1 View Post
The Ralphs review is dead on plus the vast array of comments on this one, but I did find the DTS MA 7.1 mix to sound better to my ears ( even having a 5.1 playback setup) which was more spacious sounding vs. the tighter bubble of the 5.1 mix, add top notch visuals and a soundtrack that lends itself well to the on screen content which was big and there you have it wink.gif
So you agree with Ralph that its a 5/5 on the bass, but then you say the bass is 3.5-4 / 5? You don't have to please people if its a 5/5 you can say so here too - you are entitled to your opinion.
mo949 is offline
Old 10-17-2013, 02:38 PM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
What differences? The green line and the orange line trace each other so closely that the majority of the Peak line (the top line) has turned yellow. The differences that occur rarely (where you can actually see a separate orange and green line when the graph is expanded) are so small, they're only fractions of a db. That's the peak line, so we're talking about the highest levels at any time in the movie.
Max
djbluemax1 is offline
Old 10-17-2013, 02:51 PM
audiofan1's Avatar
Liked: 1688
I tried to distinguished this already when this came up with STID, the criteria is different but I will try again to clarify. On the review thread its as a whole to which sound tracks are gauged and do believe my comments refereed to how the bass lended itself to the movie as a whole to which I agreed with Ralph, now as for singling out its bass in this particular thread , its well known its filtered but I did like the content that it did have and would err closer to the 3.5 rating to which my subjective listening experience warranted. if you wish to imply something else then you're mistaken by a long shot wink.gif
two separate threads, keep that in mind when reading post in various threads, as I may post in the video thread as well biggrin.gif
Old 10-17-2013, 02:55 PM
mo949's Avatar
Liked: 1134
Nothing implied. I just wasn't aware of your multiple standards since you didn't mention it. You should stick up for your own opinion is my only message.
mo949 is offline
Old 10-17-2013, 03:06 PM
audiofan1's Avatar
Liked: 1688
eek.gif Some say I'm too opinionated biggrin.gif you should read the reviews that I didn't agree with Ralphs ratings when they were over or under but when I agree, I agree and don't back track . I do appreciate where you're coming from on this but I my standards between to the threads are different, as this one is in regards to bass only .
Old 10-17-2013, 03:10 PM
Brad Sutliff's Avatar
How is the bass in iron man 3and this is the end? Going to check them out tonight
Onkyo TXSR607, Mythos 8 Center, Studio Monitor 350's, Klipsch S-10 surrounds, Bic F12 sub
Epson Home Cinema 8100 Projector
Brad Sutliff is offline
Old 10-17-2013, 03:15 PM
mo949's Avatar
Liked: 1134
I just watched iron man 3 and it was suprisingly light on bass. I tried to run the sub hotter by 3db, but it wasn't the volume of it imo but the credibility of the impacts that just didn't line up like I remember in the first iron man.
mo949 is offline
Old 10-17-2013, 03:33 PM
quattroatl's Avatar
Liked: 29
Originally Posted by soundmusic View Post
Man, Cloverfield had got to be the worst movie I have ever seen! I almost threw up at the end because of all the stupid jerky motion it has. And worst yet, the story was so incredibly dumb. In fact, I completely forgot what that movie was about. I wouldn't care if the movie has extremely low bass. If the story is terrible, then it's just not worth watching or listening to.
And to compare Cloverfield to Pacific Rim is like comparing crap to quality. Absolutely no comparison at all!
I agree wholeheartedly about Cloverfield being a terrible movie. The same goes for Battle LA which I would never buy. I bought Cloverfield for $8.00, and it was $8 wasted. Bad movie with even worse herky-jerky camera work. Great bass, but so what?
At first, Pacific Rim was a disappointment for me. After a second and third viewing, I give PR credit for being a clean wholesome movie with some cool giant robots. Does it have awesome bass? No. But the movie can be watched a few more times, where movies like Cloverfield and Battle LA would never get pulled out of its cases except for the few bass demo scenes.
quattroatl is offline
Old 10-17-2013, 03:46 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
This is precisely the point I bought up a little while ago in this very thread I believe. It doesn't matter if the movie has ulf in it. If it's bad, it needs to be left alone. Content needs to be paid attention to. We should not be rewarding those who make terrible movies just because they took some of the money they could have spent making a viewable movie on bass. There are too many others out there struggling to make good movies that deserve that money much more.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
Old 10-17-2013, 04:43 PM
nfraso's Avatar
Liked: 172
You're in the wrong thread then. Just take a gander at the title.
By your logic, we also shouldn't be "rewarding" those who make good movies just because they didn't bother to give us some quality bass.
It's hilarious that you think they took some of the money that could have been spent on making it a "better" movie and instead "spent" it on bass.
Most of the time, all they would have to do is NOT apply a damn HPF; they could save time and we'd all be happier.
By the way, Cloverfield has a 7.1 rating on IMDb and 77% on Rotten Tomatoes. Your minority opinion means little. rolleyes.gif
wth718, spidey.joe80 and missyman like this.
nfraso is offline
Old 10-17-2013, 04:49 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5386 Post(s)
Liked: 4305
Yup. This thread is called, 'List of bass in movies'.
wth718, Reddig and missyman like this.
Scott Simonian is online now
Old 10-17-2013, 04:51 PM
jarretc's Avatar
Liked: 130
Exactly, the only reason I subscribed to this thread was because it didn't base the movies off of people's opinions that I don't give a flying ($#! about. If I cared what people thought about a movie I'd read one of the reviews on this site or another site.
Reddig, spidey.joe80 and missyman like this.
Denon X4000
Power Sound Audio (MT-110 / MTM-210C / MT-110)
Oppo BDP-103
Dual Power Sound Audio Triaxes
Sony KDL60W630B
jarretc is offline
Old 10-17-2013, 05:29 PM
kemiza's Avatar
Liked: 92
Is this your post? http://www.avsforum.com/t/1333462/the-new-master-list-of-bass-in-movies-with-frequency-charts/10980#post_23823959
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
Old 10-17-2013, 05:42 PM
Vader424242's Avatar
Quoted: 79 Post(s)
Liked: 65
You are right vader. Most subs have filters in them already to protect them. Also, most home audio equipment have features designed to compress the dynamic range to keep the volume down. No need to mix those features in.
Thanks, mo949!
Kinda figures that the studios, in their infinite wisdom (insert sarcasm here...), would tailor to the Best Buy/Wally World audio crowd, and leave true audiophiles (and wanna-bees... like me) out in the proverbial cold...frown.gif
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
Old 10-17-2013, 06:25 PM
Freniata's Avatar
Watching a movie is no different then eating a stake or salad!
****WARNING****
I'm speaking for me "a Basshead" I'm not a "purist"
Every movie I watch has lots of bass...some more than others.
The thing is I'm not a "purist" and that's fine with me, cause it's personal taste, period!
I like (love) lots of bass.
So what do I do?
Very simple...if I want my meat to taste more (To my liking) I will ADD more salt or more sauce or more spice...key word here "ADD"
If I want my salad to taste more (To my liking) I will ADD more salt, pepper, salad dressing...etc.
I think you get my drift!
When I watch a movie I ADD more bass...it's so easy to do it's mind bugling.
This (AGAIN...is my opinion only) is how I enjoy my movies (by ADDING more bass if needed!)
Enjoy the movies guys...just add a little here and there...it's so simple biggrin.gif
With that said how could one not enjoy PR running the subs hot! I completely loved it. Pure orgasm for me.
For me there's nothing wrong with fixing something to your liking...especially when it's so simple to do
Sincerest regards,
A basshead
Freniata is offline
Old 10-17-2013, 06:45 PM
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
As for Cloverfield, I don't have that movie nor will I ever want to play that garbage on my HT system! I would rather play My Little Pony a 1000 times before even considering playing that crap. I really don't like JJ Abrams. I think he is one of the most talentless director there is. When he first promoted Cloverfield, I thought it was going to be a really great alien/sci-fi movie. My expectation was very high. But when I finally watched it, it was a disappointment at a gargantuan scale! It was a complete waste of money and time! The story was so lame. I don't even know what I was watching! All I can see is just fast moving images throughout the whole movie. I wanted to barf in the middle of the film. If the movie came with warnings like bring a barf bag, you'll need it not just for the fast motion but for the movie itself, then that's fair. But I was caught blindsided by how horrible it was. Hence my hatred towards the movie and the director.
WOW!
You can watch My Little Pony a 1000 times!!!
Man, I am about to die laughing again! hahaha
I think we can all agreed that soundmusic does not like the director JJ Abrams. lol
Just kidding with you soundmusic.
soundmusic likes this.
mantaraydesign is offline
Old 10-17-2013, 06:51 PM
Quoted: 133 Post(s)
Liked: 33
Since Halloween is coming up. What are some spooky movies with some scary BASS you can recommend?
I just watched the movie Evil Dead (2013) in blu-ray and the bass was definitely a scary BASS. Perfect for Halloween!!
Old 10-17-2013, 06:57 PM
Toe
Toe's Avatar
Liked: 1871
A few of my favorites that I have watched this year are Monster House, Cabin in the Woods and 30 Days of Night. Wish The Haunting was on blu........might just have to rough it with the DVD version video and that awesome DTS track.
mantaraydesign likes this.
Toe is online now
Old 10-17-2013, 07:12 PM
Reddig's Avatar
Quoted: 170 Post(s)
Liked: 309
+1
Exactly boys. Its all about the bass content on this thread. I think its cool for us to add our two cents about wether or not we like the movie. But refusing to watch a movie thats less than stellar but has incredible audio performance is just not in the spirit of being a bass head and/or audiophil. Also the extreme pleasure we get from enjoying the high performance of our systems and pushing them to the limits. Damn I gotta go watch a movie!
MANCHESTER UNITED!!
Old 10-17-2013, 07:23 PM
Reddig's Avatar
Quoted: 170 Post(s)
Liked: 309
****WARNING****
So what do I do?
Sincerest regards,
A basshead
That is indeed the beauty of owning your own setup!
MANCHESTER UNITED!!
Old 10-17-2013, 07:27 PM
cuzed2's Avatar
Quoted: 192 Post(s)
Liked: 248
I agree, also if you put enough salt on your "stake", it will almost taste like meat
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
