The New Master List of BASS in Movies with Frequency Charts - Page 394 - AVS Forum | Home Theater Discussions And Reviews
 6843Likes
Old 11-09-2013, 10:27 PM
buddhamus's Avatar
Quoted: 108 Post(s)
Liked: 80
Originally Posted by KevinH View Post
Yes......XT32'd but am not running the OSs hot at all. Then I've used Omni Mic to measure total response and have nice response below 20.
Hmmm, could be a difference the way it sounds on a horn loaded sub vs sealed.
I know ported subs don't sound great to me on ULF's. Haven't heard a horn sub though!. Maybe someone on here could chime in with some more insight.
buddhamus is offline
Old 11-09-2013, 11:01 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
datranz is offline
Old 11-09-2013, 11:14 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
Just rented Cloud Atlas on BD from Redbox. Any graphs up for it?
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
Old 11-10-2013, 02:00 AM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
Originally Posted by Tom C View Post
I watched it a couple of nights ago. It's kind of like this: G44
On lousy days I put something like OHF on and I'm grinning ear to ear. biggrin.gif Those vibrations seem to have a soothing effect.
What's OFH?
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 11-10-2013, 02:23 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
lovinthehd is offline
Old 11-10-2013, 04:39 AM
bestgochens's Avatar
good,I have heard in any movie. Also you do need to add Percy Jackson and the Olympians to the 5 star list. Other than that it is a very good list.thanks for your sharing.
bestgochens is offline
Old 11-10-2013, 05:54 AM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
Not running the OS hot at all? No house curve? Not even the "THX" recommended +10db LFE bump?
This is your OS:
This is your OS calibrated flat:
Scott Simonian likes this.
popalock is offline
Old 11-10-2013, 08:01 AM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
This is your OS:
Haha. No I haven't touched anything after running Audyssey. I could bump up the sub trims 2-3 each...just haven't felt the need to.......yet. wink.gif
-Kevin
JVC DLA-X550R projector/GIK Acoustic room treatments
Screen Innovations Black Diamond Zero Edge 1.4 110" 16:9
Marantz AV7702mkii pre-pro/Wyred4Sound 5-channel amp
Oppo BDP-105
JTR 3TX LCRs/Single8 HT-LP surrounds/2 RA Gamma21 master/slave pairs
KevinH is offline
Old 11-10-2013, 08:59 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
A
after just getting xt32 and audyssey cal. I noticed with REW i needed to bump up the sub 4db. Sounds awesome!!
Brian Fineberg is offline
Old 11-10-2013, 09:24 AM
KevinH's Avatar
Quoted: 192 Post(s)
Liked: 71
Originally Posted by Brian Fineberg View Post
A
I leave Dynamic EQ on right now, but for those w/ Audyssey and running their subs hot, do you still leave Dynamic EQ on for when listening below ref, or do you turn it off full time?
-Kevin
Oppo BDP-105
KevinH is offline
Old 11-10-2013, 10:32 AM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
My understanding on Dynamic EQ is that it will boost bass when you are listening at low volume, but once you start cranking the volume up, D EQ is not actually engaged.
In my case, I originally set D EQ off and I was running the subs hot. Later, I decided to turn D EQ on and let the subs at the levels calculated by Audyssey.
As many thing is in Audio and Video, IMHO is just a matter of personal preferences. I'm happy with this result, but perhaps tomorrow I'll change my mind.........tongue.gif
cr136124 is offline
Old 11-10-2013, 11:22 AM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 895
I leave dynamic eq off and run +6 hot. Dynamic eq sounds awful in my room. The bass from the sub sounds very boomy and hollow at any volume, but worse when turned up.
Reddig likes this.
ambesolman is online now
Old 11-10-2013, 11:24 AM
Liked: 3514
Same here. dynamic Eq off for me
Reddig likes this.
Old 11-10-2013, 11:43 AM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
That is Ok Brian...........nobody is perfect!
cr136124 is offline
Old 11-10-2013, 12:10 PM
mo949's Avatar
Liked: 1113
I thought most receivers automatically applied the +10db LFE bump regardless of audyssey.
mo949 is offline
Old 11-10-2013, 12:12 PM
pokekevin's Avatar
Liked: 102
I did experiment running dynamic eq off in my room and the bass did sound "cleaner" but it lost the output frown.gif I keep dyn eq on at ref level 5db.
pokekevin is offline
Old 11-10-2013, 12:19 PM
BrolicBeast's Avatar
Quoted: 1088 Post(s)
Liked: 1131
When my general listening volume was around -15db, I kept Dynamic EQ on while running my subs hot.  Once I started to listen at reference volume, I turned it off because I didn't need it anymore.  I think the higher the master volume is set, the less Dynamic EQ has to alter the signal.
BrolicBeast is offline
Old 11-10-2013, 03:03 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
Originally Posted by Roger Dressler View Post
What's OFH?
Roger,
I created a list of many common bass movie acronyms for that very question - it's linked in my signature. If you have signatures turned off, you can find it at this link:
http://www.avsforum.com/t/1333462/the-new-master-list-of-bass-in-movies-with-frequency-charts/9780#post_23651174
I try to keep it updated with the most common bass movie acronyms I see, but if you have suggestions, I'll consider adding them. smile.gif
nube is offline
Old 11-10-2013, 03:21 PM
Liked: 710
Originally Posted by nube View Post
Roger,
You've topped my AVS Hero of the Day list! Thank you for resolving OHF, and for saving me from more headscratching in future. smile.gif
nube likes this.
Old 11-10-2013, 03:28 PM
Liked: 3514
Ha! I just realized w my new denon that it had dynamic eq in and it sounds fantastic!! So i guess i am perfect lmao!!
Xt32 is amazing!
Old 11-10-2013, 03:32 PM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1038
Yep, same here, Dynamic EQ off and I am running +7
Reefdvr27 is offline
Old 11-10-2013, 04:03 PM
Liked: 3514
Help decide tonights movie rewatch...
OHF OR dredd?
Old 11-10-2013, 04:16 PM
Cowboys's Avatar
Liked: 107
Xt32 is amazing!
and you came from XT? Can you elaborate 'amazing'? What is the things you notice? Thanks.
Cowboys is offline
Old 11-10-2013, 04:19 PM
Liked: 3514
Yes came from XT. Super flat response.
And ot really tamed any reflections i had. Much crisper details. Zero musdyness
Just sounds like a higher end sound
Old 11-10-2013, 04:23 PM
Cowboys's Avatar
Liked: 107
^^are you getting all of that going from XT to XT32? Are you using a miniDSP or similar on top of XT32? Do you notice your speakers sound better too? Between Dredd and OHF, try OHF first.
Cowboys is offline
Old 11-10-2013, 05:23 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
OHF OR dredd?
I vote Dredd. Neither are Oscar winners, but Dredd is the better movie. Barely.
its phillip likes this.
nube is offline
Old 11-10-2013, 05:26 PM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
I didn't know they recommended +10? I run my dual submersives +3 and scenes like the super lycan or the Hulk final fight are RIDICULOUS! I couldn't imagine +10 though, that would be way too much and way overbalanced after Audyssey. I will say I have to turn up after Audyssey even with my house curve and dynamic EQ on. Movies +3 and music is +6-9...
A
Dynamic EQ has ZERO effect at reference. It is a sliding scale per volume. Imagine a flat line horizontally, then imagine a line creating an acute triangle that at reference is flat but the farther it goes back to the left it drops. That is dynamic EQ. I couldn't imagine not using it.
You could just leave it on because like I said no effect at reference. But if you want some quieter subtle music while you sit down and check emails or surf AVS and have it at -30 or whatever below you would want it.
I run dual submersives +3db hot, dynamic EQ on and a rising house curve to 30hz then flat on back to the singles...
jlpowell84 is offline
Old 11-10-2013, 05:39 PM
Liked: 3514
I use audyssey on top of minidsp. It teally takes the pEq of the dsp and runs with it
When i had xt it really messed up my FR
With xt32 everything just sounds much clearer from bass to mids to highs. Glad i made the upgrade. Worth every dime
Think ill rock some 3d dredd for tonights rewatch movie (we need more movies to be release smile.gif )
Old 11-10-2013, 05:41 PM
cr136124's Avatar
Quoted: 70 Post(s)
Liked: 695
+1
Classroom scene.................nice!
cr136124 is offline
Old 11-10-2013, 05:46 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 442
It's almost guaranteed that your AVR or pre/pro automatically adds the +10dB to the LFE channel if you're using bass redirection with a crossover frequency. That's why running +10dB hotter would be overkill for most people.
As for your frequency graph, it looks nice, but can you post one that just goes from 5Hz to your XO frequency, with no smoothing, so I can drool over it? wink.gif No need to remeasure to do that, FYI. You can just load the measurements in REW and resize the display to the frequencies you want.
cr136124,
Totally +1 on the classroom scene, although I might have to +3 to the Washington Monument scene in OHF. wink.gif
nube is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
