The New Master List of BASS in Movies with Frequency Charts - Page 451 - AVS Forum | Home Theater Discussions And Reviews
 7123Likes
post #13501 of 27531 Old 01-25-2014, 12:33 PM
MKtheater's Avatar
Quoted: 1615 Post(s)
Liked: 1143
Using the internal test tones yes. Always read your manual as AVR's and processors vary. All my gear wanted me to run 75 dBs on the SPL meter at the LP with the test tones.
BTW, Beeman is right about HT systems. You can have different experiences at reference from two different reference capable systems. Why do you think there are so many choices and why some of us have gone crazy! In my mind the ultimate HT experience would be to have 7 Danley SH-50's with 8 REXXX 18's in an IB with the correct power for all of it. Without just spending the money the challenge for me is to get as close as possible for much less! I have two relatives that have reference capable systems which I put together but my system is still much better at reference, and cheaper!
Marantz 7702 Atmos
MKtheater is offline
post #13502 of 27531 Old 01-25-2014, 12:34 PM
kemiza's Avatar
Liked: 92
Originally Posted by BeeMan458 View Post
I'm not arguing; could you help a poor old veteran see what you're posting about as I'm missing what you're thoughtfully defining.
(Navy, Cruiser/Destroyer, 71-75)
http://www.acousticfrontiers.com/home-theater-blog/2013/3/14/thx-reference-levelRight here.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #13503 of 27531 Old 01-25-2014, 12:35 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Read the info from JHaz I posted above. It explains how calibrating to 85 dB with a -20 dBFS signal results in EXACTLY the same end point as calibrating to 75 dB with a -30 dBFS signal.
Craig
nube likes this.
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #13504 of 27531 Old 01-25-2014, 12:38 PM
MKtheater's Avatar
Liked: 1143
I thought that could get too complicated for some so I never mentioned that.
Marantz 7702 Atmos
post #13505 of 27531 Old 01-25-2014, 12:39 PM
BeeMan458's Avatar
Liked: 813
"In the home it works slightly differently. Most pre-processor and audio video receivers have embedded pink noise test tones used for level setting that are recorded at -30dB relative to full scale. Using these tones the level of individual speakers are adjusted to 75dB as measured with a C weighted SPL meter at the listening position. Note that the low frequency effects signal is nearly always internally set to be to be 10dB louder than that for the speakers so that the end user's life is simplified and the subwoofer is calibrated to 75dB rather than the 85dB one might expect."
That's for calibration purposes, not reference level playback purposes as calibration programs adjust for this "intentional" adjustment.
(the pink noise is too loud at 85dB so for calibration purposes, it's reduced to 75dB)
BeeMan458 is offline
post #13506 of 27531 Old 01-25-2014, 01:05 PM
MKtheater's Avatar
Liked: 1143
Have you guys ever measured reference levels with REW to see where your AVR's reference is? What I mean is when I set my AVR's auto calibration I measured the volume at -20 dBs win a sine wave sweep. Guess what, it had the mains at 97-98 dBs during that sweep. So -10 dBs on my master volume equates to 107-108 dBs with a sine wave sweep. So when I run my AVR at -13 dBs it sounds perfect! 0 dBs would be close to 118 dBs! I always use REW sweeps for my set reference point.
spidey.joe80 likes this.
Marantz 7702 Atmos
post #13507 of 27531 Old 01-25-2014, 01:14 PM
BeeMan458's Avatar
Liked: 813
At the end of the calibration process, settings are checked and adjusted as necessary to a 80Hz crossover, all speakers set to small, using a calibrated sound meter, levels are checked and adjust according to an 85dB standard.
And then REW is used to measure, graph, check and adjust subwoofer settings.
post #13508 of 27531 Old 01-25-2014, 01:17 PM
kemiza's Avatar
Liked: 92
I see. So it should be calibrated to 85?
kemiza is offline
post #13509 of 27531 Old 01-25-2014, 01:24 PM
MKtheater's Avatar
Liked: 1143
Have you checked with the levels are on REW? I measure thru a digital connection and one speaker with subs. My AVR set all speakers to the same level including the subs! It does an excellent job however 0 dBs is not reference and shame on me I never read the manual to see how it sets reference as volume knob is concerned. No need to as I measure and find out.
Marantz 7702 Atmos
post #13510 of 27531 Old 01-25-2014, 01:28 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Only if you're using a -20 dBFS signal. What receiver do you have? What signal are you using for calibration?
Craig
Lombardi said it:
My System
post #13511 of 27531 Old 01-25-2014, 01:31 PM
kemiza's Avatar
Liked: 92
Craig
Onkyo 805. Not sure about the signal. I guess it would be -30db.
kemiza is offline
post #13512 of 27531 Old 01-25-2014, 01:49 PM
Toe
Toe's Avatar
Quoted: 1487 Post(s)
Liked: 1856
Originally Posted by KMFDMvsEnya View Post
No he is right, home theater should be calibrated to 75db.
Best Regards
KvE
Avia is 85db IIRC, right? I know when I calibrate with Avia vs my processor tones, one is at 75 and one 85, so it depends on what you are using to calibrate your levels.
My 885 uses -30db, so I would think your 805 is the same.
Toe is online now
post #13513 of 27531 Old 01-25-2014, 02:07 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Anything with Audyssey uses -30 dBFS test tones. So you calibrate to 75 with the internal test tones. However, Audyssey also uses -30 dBFS signals, so, if you run Audyssey, you don't want to use the internal test tones to re-set the levels afterwards. Audyssey's EQ filers are not engaged when the internal test tones play. The boosts and cuts of the Audyssey filters are not accounted for in the internal test tone signals even after you run Audyssey. So, if you run the test tones, reset the levels... and then reengage the Audyssey filters, the relative calibration is no longer correct.
If you want to check the levels after running Audyssey, (I can't think of any reason to do so,) you would need to use external test tones and then be sure the Audyssey filters are engaged. If you do this, you'll find that Audyssey got them correct and the levels that you reset using the internal test tones are incorrect.
Craig
Lombardi said it:
My System
post #13514 of 27531 Old 01-25-2014, 02:16 PM
kemiza's Avatar
Liked: 92
Craig
Thanks for the information. In other words back to 75db. So it depends on the calibration disc or the gear?
kemiza is offline
post #13515 of 27531 Old 01-25-2014, 02:33 PM
kemiza's Avatar
Liked: 92
Not that complicated.
kemiza is offline
post #13516 of 27531 Old 01-25-2014, 02:35 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Have you run Audyssey? If so, go back to the Audyssey level settings. They're correct.
Lombardi said it:
My System
post #13517 of 27531 Old 01-25-2014, 02:38 PM
kemiza's Avatar
Liked: 92
I don't like Audyssey. Never accurate.
kemiza is offline
post #13518 of 27531 Old 01-25-2014, 02:56 PM
BeeMan458's Avatar
Liked: 813
Audyssey automatically adjusts it to 75dB and 75dB, 85dB or 65dB, it's all the same as according to what I read today, it's all relative.
post #13519 of 27531 Old 01-25-2014, 03:00 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
So how does -20db come into play?
Consumer equipment uses built in -30 dBFS test tones for calibration purposes. The -20 dB FS test tones are used in commercial equipment used in a professional sound mixing stage.
I made up a test tone CD for testing purposes, and I generated the test tones at -20 dB FS (85 dB SPL playback level if master volume is set to reference level). I usually playback around -10 dB from the reference level setting on the master volume control, so my playback levels for the test tones come out to be 75 dB SPL. (85 dB SPL - 10 dB FS = 75 dB SPL).
105 dB SPL represents full reference playback level. The following applies when the master volume is set to the calibrated reference level setting. On my receiver, -22 dB represents the calibrated reference level setting on the master volume control.
The -30 dB FS test tone will give you 75 dB SPL (105 dB SPL - 30 dB FS = 75 dB SPL).
The -20 dB FS test tone will give you 85 dB SPL (105 dB SPL - 20 dB FS = 85 dB SPL).
kemiza likes this.
J_Palmer_Cass is offline
post #13520 of 27531 Old 01-25-2014, 03:02 PM
BeeMan458's Avatar
Liked: 813
I'm too messed up on anti-histamines to be lucid. Somewhere in my readings today, I read how it was set to 85dB but 85dB is too loud for normal humans so it's set to 75dB for bearability but internally, it's automatically adjusted for this point so 75dB, 85dB or 65dB, Audyssey internally sets everything to a 85dB standard.
(Audyssey, doesn't give a poop what people think about 75dB or 85dB. The only ones arguing are people as machines don't care about this point)
post #13521 of 27531 Old 01-25-2014, 03:06 PM
Quoted: 393 Post(s)
Liked: 118
My Sony receiver does not set 0 dB on the master volume as "reference".
Reference is about -22 dB on my master volume control.
Then again, my receiver is getting a bit old!
post #13522 of 27531 Old 01-25-2014, 03:08 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Yes.
Lombardi said it:
My System
post #13523 of 27531 Old 01-25-2014, 03:10 PM
kemiza's Avatar
Liked: 92
I made up a test tone CD for testing purposes, and I generated the test tones at -20 dB FS (85 dB SPL playback level if master volume is set to reference level). I usually playback around -10 dB from the reference level setting on the master volume control, so my playback levels for the test tones come out to be 75 dB SPL. (85 fB SPL - 10 dB FS = 75 dB SPL).
The -20 dB FS test tone will give you 85 dB SPL (105 dB SPL - 30 dB FS = 85 dB SPL).
There it is! Now it's been explained clearly. Typo in the math bro but I understand where you're coming from.
kemiza is offline
post #13524 of 27531 Old 01-25-2014, 03:13 PM
BeeMan458's Avatar
Liked: 813
Yes.
And you didn't say poop about the graphs you asked for.
post #13525 of 27531 Old 01-25-2014, 03:14 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
Watching ratatouille with my son. And wow the thunder and shotgun shots at the beginning are powerful. Not too deep from what I can tell by dynamic!
Brian Fineberg is offline
post #13526 of 27531 Old 01-25-2014, 03:24 PM
Mrkazador's Avatar
Quoted: 258 Post(s)
Liked: 386
I thought the lightning scene in Ratatouille goes down to 10hz.
Mrkazador is offline
post #13527 of 27531 Old 01-25-2014, 03:27 PM
Liked: 3515
If it does that would make sense why it's so powerful. I guess because it's so quick. I'm used to the longer 10 Hz effects such as OHF etc. smile.gif
post #13528 of 27531 Old 01-25-2014, 03:27 PM
Quoted: 393 Post(s)
Liked: 118
Corrected typo!
Note that one of the the reasons I made my own test disk is so that I can verify the calibration of my master volume control against the calibration made with the internal test tones used in my AVR. The two calibration results do match on my system.
If you have a THX rated receiver, then your results may not match!
post #13529 of 27531 Old 01-25-2014, 03:31 PM
audiofan1's Avatar
Quoted: 1660 Post(s)
Liked: 1686
^^^ wow eek.gif I haven't seen that one in awhile, I may put it in the ole que wink.gif
Torqdog likes this.
audiofan1 is offline
post #13530 of 27531 Old 01-25-2014, 03:43 PM
Tom C's Avatar
Quoted: 70 Post(s)
Liked: 72
I like to use those as demos, especially the shotgun scene. Good surround info too and when that chandelier hits the floor it's like it landed in the middle of my living room. eek.gif
LG OLED55B6P ** Denon AVR-X4200W ** oppo UDP-203 **oppo BDP-103D
HR44 DirecTV ** Panamax 5300 ** Harmony One Universal Remote
Hsu HB-1 MK2 (L, R & S) ** Hsu HC-1 MK2 (C) ** Hsu VTF-15H (sub)
Crowson Technology Level 2 Motion System
Tom C is online now
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
