The New Master List of BASS in Movies with Frequency Charts - Page 508 - AVS Forum | Home Theater Discussions And Reviews
 7100Likes
Old 03-04-2014, 05:05 AM
Skylinestar's Avatar
Quoted: 1077 Post(s)
Liked: 187
@Flageborg @J_Palmer_Cass
could you please post the time frame for that Drive scene?
Skylinestar is online now
Old 03-04-2014, 07:16 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
Originally Posted by J_Palmer_Cass View Post
That looks about right, but your time scale is very long. Couple of minutes on that waterfall.
Is that waterfall taken from the Drive Bluray? There are no Chapters with streaming so it is hard to guess where that waterfall starts.
Give me a start time and I will take a look.
You said 4 minutes and 45 seconds into the movie. That would not be chapter 5. Also, Flag shows content to 1 Hz and your graph has nothing below 27 Hz.
Dunno about the streaming deal (what's the audio format?) but that stripe down to DC on your graph is def not on the BR version. I wouldn't use the streaming audio for a reference against the BR.
I can see without graphing that what I've been saying about frequency resolution will hold true in this scene, which is not a low frequency effect, but is a complex synth keyboard music score. I'll bet real money that instead of a full frequency spread from 27-60 Hz there are instead a dozen or so frequencies and they're all being blurred into a single horizontal pixelated stripe with you settings.
So, you'll get a getter separation in time (possibly, we'll see), but you'll never be able to distinguish what frequencies make up the composition... not even approximately. As far as the amplitude separation goes, that will be apparent on the amplitude graph and more accurately at that with my settings.
I don't connect my measurements PC to the internet but I wouldn't trust the stream anyway.
I have some time later today so I'll pick up the BR and graph it. In the meanwhile, let's get the time stamp right so we're all on the same page. Start at 0:04:45 and go to 0:05:20. That should fit in your 35 second window and we'll all have the right scene for comparison.
bossobass is offline
Old 03-04-2014, 08:23 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
MemX is offline
Old 03-04-2014, 08:43 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Yes, the streaming audio is 2.0, so the Bluray will be different. I may buy the disk so I have the correct audio file.
I have a newish Windows 8 laptop with wide screen display. The audio chip used is in the link below. Not sure about that 0-1 Hz area action, but it comes and goes in the same time period every time I do a waterfall. Bin bandwidth is about 1.4 Hz with my settings.
Audio chip details for my laptop sound.
http://www.conexant.com/Product/Audio/pchdaudio/CX20672/Pages/default.aspx
Here is a new waterfall of Drive starting at 4 min 45 sec from laptop microphone. The scroll interval was set to automatic 87.5% overlap.
Here is a second waterfall for the same scene in Drive. In room measured with laptop microphone.
Different settings were used in SL for this waterfall.
J_Palmer_Cass is offline
Old 03-04-2014, 08:54 AM
Quoted: 393 Post(s)
Liked: 118
Originally Posted by MemX View Post
Not a bad movie, and the sound track is pretty good.
Drive was nominated for Best Sound Editing in 2011.
Old 03-04-2014, 09:09 AM
MKtheater's Avatar
Quoted: 1597 Post(s)
Liked: 1124
BTW, my spec lab waterfalls using the laptop mic is too low under 20hz. It drops off pretty good as compared to my calibrated behringer mic. The c-weighted RS meter has more low end as well. It is closer to a RS meter with no c-weight which is really low. This actually makes me happy because it means I am closer to having the low end than what I have shown. I have a mic coming that does not need cal files and will match up with my behringer and RS c-weighted mic. Then I can really see what my in room is really doing. Some day I might have to just suck it up and buy a flat to 2hz no cal file mic.
Marantz 7702 Atmos
MKtheater is offline
Old 03-04-2014, 11:56 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
A little bit less of the graphic gore and I think it would have been perfect - did we really need to see body parts destroyed? What's wrong with our imagination?
But I digress...
MemX is offline
Old 03-04-2014, 04:43 PM
Quoted: 393 Post(s)
Liked: 118
Yes, and here is a picture from beginning of scene....
I found that scene. Near the 49 minute time stamp. Your waterfall is accurate (sub 20 Hz content). Not much going on in that scene. Just talking and back ground noise (audio recorded outside).
Old 03-04-2014, 04:47 PM
Quoted: 393 Post(s)
Liked: 118
Do you have the Dell audio icon on the bottom Windows 8 task bar? If so, make sure all the options are set to OFF!
Old 03-04-2014, 06:01 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 667
I have the ACOPacific PS9200 Kit with the 7012 mic. It's the mic B&K and others use to create a mic cal file, and is flat to 2 Hz. The kit has a choice of mic, the preamp/PS/windscreen/adaptors and a sturdy case with compartments for all of the above.
http://www.acopacific.com/PS9200kit.html
I just sent a quote request for current $$ and freight. I'll ping you when I get that info so you'll have it either way.
popalock and MemX like this.
Old 03-04-2014, 06:15 PM
MKtheater's Avatar
Liked: 1124
Marantz 7702 Atmos
Old 03-04-2014, 06:17 PM
MKtheater's Avatar
Liked: 1124
I disable of the dc offset, noise, and anything else. I just hit disable all but that is in properties of the recording box when you right click the volume icon.
Marantz 7702 Atmos
Old 03-04-2014, 11:52 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5357 Post(s)
Liked: 4264
Let me know what you find out, Dave.
Scott Simonian is offline
Old 03-05-2014, 12:42 AM
jchong's Avatar
Quoted: 12 Post(s)
Liked: 32
Originally Posted by lefthandluke View Post
at the risk of groans, i thought the bass in "gravity" really "pulled me into" the movie...
Clearly the Orbit shifter is the most appropriate sub to watch this movie with.
jchong is offline
Old 03-05-2014, 02:26 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Hey Bosso,
They have four mic options in that kit, going from the webpage - is there a preferred / best model number to select?
Many thanks!
MemX is offline
Old 03-05-2014, 05:21 AM
popalock's Avatar
Quoted: 1236 Post(s)
Liked: 1723
+1.
PM sent Dave.
popalock is offline
Old 03-05-2014, 05:35 AM
Quoted: 393 Post(s)
Liked: 118
Are you going to spend over $1,500 for a microphone, power supply and preamp?
2006 list price noted in link below. Scan down the page to get by the blank section. The mike and power supply kit went for $1750 and up in 2006!
http://mixonline.com/wnamm2006/new-products-guide/microphones-2006/
Old 03-05-2014, 06:01 AM
Quoted: 393 Post(s)
Liked: 118
I suspect that we have different sound hardware. When you right click the volume icon you get into the more or less standard audio control area.
Dell audio (if you have it) can be found in Windows 8 by going to Control Panel, Hardware and Sound. If you have Dell Audio, you will see an icon that says Dell. I set all the options to OFF.
Old 03-05-2014, 06:18 AM
MKtheater's Avatar
Liked: 1124
I will check it out.
Marantz 7702 Atmos
Old 03-05-2014, 02:31 PM
audiofan1's Avatar
Quoted: 1652 Post(s)
Liked: 1675
Anyone watch or graph" The Grandmaster" ? I would love to see comparisons of the DD5.1 english vs. Chinese DTS MA i found the DD 5.1 mixed had the better bass but it may have had to do with the perceived High/mid or channel level bump in the DTS MA track. The overall mix was fantastic with stellar directional cues and great use of the LFE with great room penetration and nice sweeps. As a movie? if martial arts are your thing, its a must see and belongs in the collection as I found it a masterfully done movie and even if its not see it anyway wink.gif
audiofan1 is offline
Old 03-05-2014, 02:34 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
I have the Grandmaster ordered from Amazon and it should be on my porch tomorrow. Do you have the version Amazon sells or the Hong Kong version. I've heard there are two versions?
sojodave is offline
Old 03-05-2014, 03:38 PM
audiofan1's Avatar
Liked: 1675
I got my copy from Netflix but will purchase soon wink.gif, it was the 108 min US version , from what i understand the HK version is 130 min, despite this, I loved the movie and if opportunity presents I would love to see what was omitted from the US release smile.gif
Old 03-05-2014, 04:10 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3515
I have it and watched the first 15 mins yesterday. Fantastic bass so far. I was just too tired to watch since it has subtitles.
Brian Fineberg is offline
Old 03-05-2014, 04:34 PM
audiofan1's Avatar
Liked: 1675
I watched late night as well and opted for the english version as I didn't want the subtitles to put me down! This was good due to the fact when I do my soundtrack confirmation and noticed the DTS MA I switched to it but back as I found the DD 5.1 more pleasing, It was late and the volume was at 33-26 db with Dynamic EQ offset to 5 ! I'll have to compare at reference when I purchase .
Old 03-05-2014, 04:42 PM
Liked: 3515
I have the English version and it still had subtitles. Could I choose a different track?!
Old 03-05-2014, 06:52 PM
audiofan1's Avatar
Liked: 1675
Perhaps ! there were 2 available on the Netflix rental, english DD5.1 & chinese DTS MA.
Old 03-05-2014, 07:07 PM
audiofan1's Avatar
Liked: 1675
Whilst in the mood for more ! I may checkout "Saving General Yang" tonight ,It was recommended a few pages back and it seems Netflix has it available for streaming wink.gif
Old 03-05-2014, 07:11 PM
bao01's Avatar
Liked: 24
Can someone point me to list of chapters/scenes for good bass in Tron Legacy? I could not find on first page.
thanks
B&W 802 Diamond mains, B&W HTM2 Diamond center, B&W 804 Diamond surrounds, Parasound HALO A 51, Krell KAV-300i , Integra DHC-80.3 pre-pro, two JL Audio Fathom f113 subs, Panasonic TC-P65VT50 65" plasma
bao01 is offline
Old 03-05-2014, 07:48 PM
MKtheater's Avatar
Liked: 1124
Enter the grid and go all the way to the bike battle. Even some eye candy in between. Then you can jump to the club scene and then the air battle scene to the end.
Marantz 7702 Atmos
Old 03-05-2014, 07:58 PM
bao01's Avatar
Liked: 24
ok - thanks
bao01 is offline
Alien Vs Predator Blu Ray , Amazing Spiderman Ultimate Edition , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Back To The Future 25th Anniversary Trilogy Digital Copy Blu Ray , Batman Begins Blu Ray , Battle Los Angeles Blu Ray , Battleship , Black Hawk Down Blu Ray , Blu Ray Movies , Bolt Blu Ray , Braveheart Blu Ray , Captain America The First Avenger Two Disc Blu Ray Dvd Combo Digital Copy , Casino Royale Blu Ray , Clash Of The Titans Blu Ray , Cloverfield Blu Ray , Conan The Barbarian Blu Ray , Daredevil Directors Cut Blu Ray , Death Race 3 Inferno Blu Ray , Devil Blu Ray Widescreen , Disneys Wall E Blu Ray , Dredd 3d Blu Ray Digital Copy Ultraviolet , Fantastic 4 Rise Of The Silver Surfer , Fast Five Blu Ray , Finding Nemo , Flight Of The Phoenix Blu Ray , Gamer 3d 3d Blu Ray Blu Ray Ultraviolet , Ghost Recon Future Soldier Xbox 360 Game Ubisoft , Hanna Blu Ray , Harry Potter The Order Of The Phoenix Playstation3 Game Ea , Hellboy Science Of Evil Playstation3 Game Konami , Hitman Digital Copy Blu Ray , Hot Fuzz 2 Disc Special Edition Region 2 Dvd , How To Train Your Dragon Two Disc Blu Ray 3d Dvd Combo , Hurt Locker Blu Ray , Immortals Blu Ray , Inception Two Disc Edition Blu Ray , Iron Man 2 Single Disc Edition Blu Ray , Iron Man Blu Ray , Jack The Giant Slayer Blu Ray 3d Blu Ray Dvd Ultraviolet Digital Copy Combo Pack , Jurassic Park 3d 3d Blu Ray Blu Ray Dvd Digital Copy Ultraviolet , Kill Bill Volume 1 Blu Ray , Kung Fu Panda 2 Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Kung Fu Panda Two Disc Blu Ray Dvd Combo , Last Stand Blu Ray , Live Free Or Die Hard Blu Ray , Looper Ultraviolet Digital Copy Blu Ray , Machete Blu Ray , Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Marvels The Avengers , Matrix , Max Payne Unrated Edition Blu Ray , Monsters Vs Aliens , Mr Brooks Blu Ray Blu Ray 2009 , Ninja Assassin Blu Ray , Olympus Has Fallen Blu Ray , Oz The Great And Powerful Blu Ray 3d Digital Copy , Oz The Great And Powerful Blu Ray Dvd Digital Copy , Pacific Rim Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack , Piranha 3dd Blu Ray , Pirates Of The Caribbean At Worlds End , Pirates Of The Caribbean At Worlds End Three Disc Blu Ray Dvd Combo , Pirates Of The Caribbean Three Movie Set Curse Of The Black Pearl Dead Mans Chest At Worlds End Blu , Prince Of Persia The Sands Of Time Blu Ray , Project X Blu Ray Dvd Combo Ultraviolet Digital Copy , Rambo Blu Ray , Real Steel Two Disc Blu Ray Dvd Combo , Resident Evil Afterlife Blu Ray , Resident Evil Apocalypse Blu Ray , Resident Evil Retribution 3d Two Disc Combo Blu Ray Ultraviolet Digital Copy , Room Equilizer Wizard Rew , Sherlock Holmes Blu Ray , Skyfall Blu Ray , Skyline Blu Ray , Star Trek Blu Ray , Star Trek Into Darkness Blu Ray 3d Blu Ray Dvd Digital Copy , Star Wars , Subwoofers , Sucker Punch Two Disc Extended Edition Blu Ray , Super 8 Two Disc Blu Ray Dvd Combo Digital Copy , Svs Pb2000 , Terminator Salvation Two Disc Directors Cut Blu Ray , The Cabin In The Woods , The Dark Knight Bd Live Blu Ray , The Dark Knight Rises Limited Edition Bat Cowl Blu Ray Dvd Combo Ultraviolet Digital Copy , The Hunger Games Blu Ray Digital Copy , The Incredible Hulk Blu Ray , The Incredibles Four Disc Blu Ray Dvd Combo Digital Copy , The Last Airbender Two Disc Blu Ray Dvd Combo , The Lord Of The Rings The Motion Picture Trilogy The Fellowship Of The Ring The Two Towers The Retur , The Pacific Blu Ray , The Raid Redemption , The Ultimate Matrix Collection Blu Ray , The Worlds End Blu Ray Dvd Digital Hd With Ultraviolet , Thor Two Disc Blu Ray Dvd Combo Digital Copy , Tomorrow Never Dies Pierce Brosnan Blu Ray Dvd James Bond , Total Recall , Toy Story 3 Blu Ray , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , Transformers Revenge Of The Fallen Two Disc Special Edition Blu Ray , Triangle Blu Ray , Tron Legacy Two Disc Blu Ray Dvd Combo , U 571 Blu Ray , Underworld Awakening Ultraviolet Digital Copy Blu Ray 3d , Unstoppable Blu Ray Digital Copy , Valkyrie Blu Ray , War Of The Worlds Blu Ray , Windtalkers Blu Ray , World War Z Blu Ray 3d Blu Ray Dvd Digital Copy , World War Z Blu Ray Dvd Digital Copy , Wrath Of The Titans Blu Ray , X Men Origins Wolverine Two Disc Ultimate Edition Blu Ray , X Men Origins Wolverine Uncaged Edition , X Men The Last Stand Blu Ray , Xxx , Zombieland Blu Ray
